Page 1 of 3 123 LastLast
Results 1 to 25 of 65
Thread: Alphacool heatmaster
    Jun 2008
    An unfortunate person is one tries to fart but sh1ts instead...
    My Water Cooling Case Build (closed)
    Never go full retard
    Feb 2008
    Vegas
    I'm pretty sure bundymania has one, but I wasn't able to get my hands on one.
    Oct 2005
    Germany / Watermasterhausen
    yeah right, i got nearly all new stuff from watercooling companies here in germany, so the alphacool heatmaster too the software is available in english since september. i would say, itīs a good product besides the Aqauero. It can handle 24 watts per channel, so you can directly attach a Laing/Swiftech pump and it has lots of features. itīs planed to bring some software updates and a mounting system for 5,25" slots
    Feb 2008
    Could you post up pics of what the software looks like?
    Jun 2008
    as i understood, i has only one channel supporting up to 24 watts. what is specification for othe channels? how does it connect to pc, if the description says it is pc independent?
    Oct 2009
    Germany
    Quote Originally Posted by Hu13caP View Post
    All channels support 24 watts! Its a pwm controller! u connect the heatmaster by the use of the USB cable! Its just a usual usb cable like a printer cable. U connect the cable at the top left corner in picture 1.
    pc independent means that u do not need continous connection with the USB cable. After u made ure setting u can remove the cable.
    one picture of the software by scamps
    source: http://www.hardwareluxx.de/community...ool+heatmaster
    Sep 2009
    Broken Arrow, OK
    Quote Originally Posted by Xandrus View Post
    Is it OK for a DDC to be run on PWM? I thought it needed pure analog power.
    Or is this really meant for fan control only?
    Jun 2008
    I think if the pwm frequency i high enought, say 22kHz and more , then it is ok. And you wont hear any buzz or winning of its motor
    Jun 2009
    Hey.
    We especially designed the Heatmaster so it can handle the DDC pumps without any problems. With this in mind the Heatmaster has, as stated above, an extrem high PWM frequency (over 20kHz which is a lot compared to other PWM controls) that is suitable to run all current DDC pumps and Fans without any of the disadvantages PWM normaly brings with it.
    Hope this clarifies the matter a bit.
    Greetz
    Dietz
    Sep 2009
    Broken Arrow, OK
    Quote Originally Posted by Dietz View Post
    Hey.
    Greetz
    Dietz
    Great. Thanks for the reply and confirmation.
    Jun 2008
    @Bundymania
    Can you tell dimensions of tid control panel itself (without mounting stuff, just circuit board) WxDxH ( hight=the highest element)?
    Jun 2009
    Hey,
    the heatmaster uses the standard 5 1/4" measures.
    The height is a bit more complicated because it varies depending on which
    cables and plugs you use to connect it to your hardware. so i cant give you something valid here, sorry.
    Greetz
    Dietz
    Jun 2008
    I mean no wires, just pcb and electric components
    Jun 2008
    Every body!!!
    Is there any manual available on-line? Or can you show the one that came with heatmaster?
    Owners of Alphacool heatmaster sound off!
    Oct 2009
    Germany
    hey,
    I just found the german manual....
    http://www.alphacool.com/shop/media/...ion_1_0_de.pdf
    If u need something special translated I will try to help u!
    Jun 2008
    hey,
    Thanx, man. Now i have something to study
    Jun 2008
    Hey. Maybe there is an english version of that manual. Now that would be wonderfull.
    I am not good at German. All i could understand was some figures and preety pictures.
    I need a G000000D de<>rus or de<>en dictionary
  18. #18
    Oct 2009
    Germany
    Sry i could not find an english version
    http://dict.leo.org/ende?lang=en&lp=ende&search=
    The google translating tool should work too!
  19. #19
    Jun 2008
    Quote Originally Posted by bundymania View Post
    yeah right, i got nearly all new stuff from watercooling companies here in germany, so the alphacool heatmaster too the software is available in english since september.....
    I bet you have the english manual too. Can you send it via e-mail?
  20. #20
    Apr 2010
    Boston, MA
    Any idea what flow meters work with the Heatmaster?
    Silverstone TJ07, Asus P6X58D Premium, i7 920, 3x2GB Corsair DDR3 1600 C7, 2x WD velociraptors 150GB RAID0,
    Hitachi 500GB SATA, EVGA GTX280 Ocd, Thermaltake Toughpower 750W; ViewSonic VX2835W 27.5" LCD.
    Blocks: EK Supreme HF, EK NB/SB 5, EK Asus X58 Mosfet Kit
    Rad: Swiftech MCR-420
    Pump: Swiftech MCP-355
    Res: XSPC Dual pump Bay (for future GPU expansion)
    Tube: Primochill PrimoFlex PRO LRT 7/16"; 5/8"
    Fittings: 1/2" BP, EK
    Fans: 7 120mm Coolermasters push/pull on Rad
    Fan Cont: Kaze server
  21. #21
    Jul 2008
    Seems almost identical to the BigNG cept it doenst support analogue and doesn't have any digital sensors?
    MM H2gO - Win 7 Pro
    2 PA120.2 Thermochill
    MCP355 w/XSPC res top
    i5-2500k @ 5.0ghz w/Heatkiller 3.0
    Corsair HX850 - M IV Gene-z
    GTX 480 w/DD 480 ni/cu
  22. #22
    Sep 2007
    Germany, Solingen
    Quote Originally Posted by masik View Post
    any standard flow meter will work with it
    Quote Originally Posted by Wolf132 View Post
    right, only pwm, but itīs working great also with normal non-pwm-fans and with a Laing/Swiftech pump
    Did a review month ago before Aquacomputer launched the powerbooster-upgrade for the Aquaeo (warning, german language):
    http://www.hardwareluxx.de/community...tt-628694.html
    Just bought one in these days again, because the Heatmaster is already end of life (Alphacool is not longer existing in the known way and nobody will be working on updates) and now itīs available for half of the usual price in Germany.
  23. #23
    Jun 2008
    scamps
    can in handle 2 ddc's?
    do you have english manual in pdf format?
  24. #24
    Sep 2007
    Germany, Solingen
    Quote Originally Posted by SpuTnicK View Post
    scamps
    I donīt think there is any english manual available at all. The software had a beta-status in general and Alphacool has already stopped development when Aquacomputer began to bring the powerbooster to market. The Heatmaster has 4 channels and each channel is able to handle 24 Watt. So you could hande 4 DDCs with it - Cum on feel the noize!
    The Heatmaster is in general an absolute fine piece of hardware and if Alphacool would have had the money and time to put some extra development inside the software and an optional display (connectors are already there) it would have been an Aquaerokiller. But I am afraid that they put all their eggs in only one basket (Yellowstone, Heatmaster, HF Cyclone...) with to little profit.
  25. #25
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    4x24W / 4 DDCs? Woahh, nice. 2 dual-ddcs for two loops . And probably via pwm pumps can be run even slower then with analog downvolting, as no more 8V minimal voltage problems. Unmaintained software strikes out everything though. Having no support for whatever next OS MS will release sounds bad for me.
    BTW, out of curiosity - does this controller work standalone without os/drivers support? And does it support power shutdown in case of pump/temp problems?
