I bought an EVGA GTX 285 Hydro Copper and this is what I've got form EVGA.
I opened the box, that wasn't opened before i did it, and took the graphics card out of the bag to find that the card is wet from what I think is non-conductive coolant.
The next thing that I noticed was the missing 1/2" fittings that I need and that should be included in the box.
I have to connect the tubes to the top side of the card so all I have to do is to screw the fittings in the inlet and outlet on the top side.
Hmm... this doens't seem to be possible.
The opening for the fluid is only 10mm X 2mm and there are little pieces of plastic that block the already small inlet and outlet. If you screw one of the fittings in the block you don't have a 2mm opening anymore.
Is this what you get if you buy one of the EVGA top products?![]()
