Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Kingston HyperX Elpida Hyper Replacements
    Dec 2005
    Philly
    I bought a 3x2GB Kingston HyperX 2000Mhz Elpida Hyper based kit a while back for a new Core i7 build that got delayed. I finally built my Core i7 rig a little over a month ago. The system initially ran great at stock settings but out of nowhere I started to have memory errors and BSODS. I tested each stick individually and 2 sticks worked great, one stick would not allow the system to post at all. It is dead.
    Kingston agreed to replace my kit which I mailed out yesterday and expect my replacement kit back the end of next week.
    My questions is: Does anyone know what Kingston is replacing their Elpida Hyper based kits with?
    Will the replacement kit contain Elpida Hyper IC's or BBSE?
    4770K and 3770k
    MVI Gene and MV Gene
    2 kits TeamX 2400Mhz 2x4GB @ 2600Mhz 10-12-12--28-1T
    Asus 670GTX DCII
    Corsair AX1200 ~ Corsair TX850
    (2) OCZ Vertex 4 RAID0 ~
    Samsung BluRay Burner SH-B123L
    800D~EK Supreme HF Nickel~EK Coolstream 360~BP Matte Black Modded MCP655
    BP Mod Top V2~EK Res~Distilled Water~Silvercoils
    Dec 2007
    France
    if it's a 2000C8 kit I think so
    Kingston is a bit conservative on kits specs so I doubt they will put BBSE or HCF0 on them
    and I recently RMA a Kingston 3x1GB kit Hyper based and receive back a new one with Hyper
    May 2009
    my friend i have the same kit 3x2g and the chips are elpida bbse!
    [SIGPIC][/SIGPIC]
    -110c club
    May 2008
    by the LAMP!
    Quote Originally Posted by deachus View Post
    my kit did the same sent them back and got the 2000cl8's
    marmott is right there swaping Elpida hyper for Elpida hyper
    see marmott's images here
    I LOVE LAMP!
    May 2006
    Colorado Springs
    yep
    1
    Dec 2005
    Philly
    Yes, it was the 3x2GB 2000CL8 kit. That is great news everyone, thank you for the replies. Let's hope they send my back Hypers as well. Here are some pics of the kit I just sent back to them. I already have a G.Skill 2000Mhz BBSE kit and don't want them to swap out my Hypers for another BBSE kit. I'll post back what they send me once I receive my replacement kit next week.
    Thanks Again
    4770K and 3770k
    Asus 670GTX DCII
    -110c club
    May 2008
    by the LAMP!
    Thanks Again
    if you sent off ULT's you will get back the c8d's
    if its got ult in the code there the self exsplsive ones lol
    KHX16000D3ULT1K3 = elpida -mNh - e hyper
    you should get these back
    KHX2000C8D3T1K3 = elpida - mGh - e hyper
    i have not taken the heat spreader off yet to fully confurm there elpida mgh-e's but i trust the information marmott has given
    I LOVE LAMP!
    Jul 2009
    São Paulo, Brazil
    Hi there, first post here!
    Guys, I'd like to know, are these BBSE worse than the MHN-E Hypers (Which I've seen in soo many Hyper-Xs kits) ?
    Thanks Again
    Hi daechus, did you have any bad experiece with the BBSE based-G.Skills? Or the Hyper X just clocks better? Thanks and sorry for your bad kit
    Dec 2005
    Philly
    Quote Originally Posted by Dmitriev View Post
    BBSE can't run the tight timings that Hypers can at.
    BBSE can't run the tight timings that Hypers can like CL7 2000Mhz.
    I have had no bad experiences with my 3x2GB G.Skill Trident 2000Mhz kit. It just can't run 2000Mhz CL7 like my Hypers could. They are rated 9-9-9-24 @ 2000Mhz. The Trident kit is a great deal IMHO for $150.00US at Newegg. I only bought the G.Skill kit to use while Kingston kit is being RMA'd. Max I can run stable CL7 with G.Skill kit is 1886Mhz 7-8-7-20-1T @ 1.68v ~ QPI 1.45v
    4770K and 3770k
    Asus 670GTX DCII
    Jul 2009
    Izmir, Turkey
    Hi. One of my kingston hyper module is dead. KHX16000D3ULT1K3. I have bought it through ebay. will kingston replace my kit? how do you guys start rma process? another point, i m in Turkey. I have friends in USA. So I can send to my friends and they will send it to Kingston USA. So kingston USA will send it to my friend in USA. that is what I will plan to do. Cause Kingston turkey will not replace kits bought from USA. Any help will be really appreciated. Thanks
    Banned
    Jul 2006
    there are only two types of ic that can do 2000 8-8-8 1.65v spec right now - hypers and high binned bbse. either way, whatever you will get won't be bad
    tworule, try kingston uk and tell them it's a "prize kit", then they should rma no prob.
    Jun 2007
    Long Beach, CA
    Quote Originally Posted by EvoCarlos View Post
    I have 2 sets of these pictured --> KHX16000D3ULT1K3 = elpida -mNh - e hyper my question is I am using one set and it seemed to be running fine tell I put W7 on and I started getting BDOS screens like mad. I am wondering if one of the sticks went bad? My other set I never opened and I am thinking maybe I should just sell them on ebay as is NEW never opened and buy something else? What do you guys think? RMA first set and sell second set!
    CPU: Intel Core i7-4770K 4.8GHz
    MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
    MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31 1T
    GPU: 2 x eVGA GTX 780 SC
    SOUND KRK Rokit 5 Limited Edition White Studio Monitors
    SSD: 4 x Samsung 128GB Pro's Raid 0
    PSU: SeaSonic Platinum 1000W
    COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm 6 x Swiftech Helix 140mm Fans
    CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
    MONITOR: ASUS VG278HE Black 27" 149Hz
    O.S: Windows 7 Pro x64
    Aug 2008
    Hong Kong
    Guys one of my Sticks just went dead when under stress test of 12GB in DFI-X58-T3eH8.
    RMA'd a new kit with new model # but found out one of then sticks is acting weird.
    Test on EVGA P55 FTW Result:
    8-8-8-20 2000Mhz 1T 1.65v = Errors @ Test #7,
    8-8-8-20 1333Mhz 1T 1.65v = Errors @ Test #7,
    8-8-8-20 2000Mhz 1T 1.5v = No Errors,
    8-8-8-20 1333Mhz 1T 1.25v = No Errors.
    It appears to be bad PCB QC rather than the chip itself. So when checking if your sticks are working properly, check if the PCB can handle that voltage as well...
    For my current experiance with this baby,
    I've tested 6 sticks and all of them can pass Memtest 86+ @ 1.5vDIMM under 8-8-8-20 1T 2000Mhz.
    7-8-7-20 will need more voltage than the origional hypers which is around 1.7~1.72v.
    However clocking high to 2200Mhz while lentency remain 8-8-8-20 1T @1.65v is still PI 32M X8 Stable somehow
    Judging from it's price it's already performing well and cannot complain anymore...
    Intel XEON X5650 B1 Retail x2 3012A692
    EVGA Classified SR-2 BIOS A50
    Crucial Ballistix PC3-1333 CL6 D9GTR 2G Kit (Active)
    Crucial Ballistix PC3-2000 CL9 D9GTS 2G Kit (Active)
    Thermaltake V1R (in use, without heatpipe)
    Cooler Master Silent Pro M 1000W PSU
    Galaxy GTX 275 (Digital PWM)
    WD 10EALX
    Overclock:
    Currently running @ Default.
    Intel i7-2600K (L041C107, L048B284, L050A853)
    Asus P8P67 Pro BIOS 1305
    WC setup EK Supreme HF GOLD Edition powered by BlackICE GTX 480
    G.Skill 12800CL7D-4GBECO x2 packs
    WD 10EALX
    Intel X25-M 120GB
    MSI NGTX560Ti Twin Frozer SLI
    Overclock:
    40x100 4Ghz 1.15v [Currently testing L048B284]
    Dec 2005
    Philly
    Well guys I got my replacement kit at work this morning from Kingston. The replacement model is the one stated above by EvoCarlos
    KHX2000C8D3T1K3/6GX
    Haven't opened up or tested as they arrived at work this morning but will throw them in tonight and test them out. From the above posts it seems this is an Elpida Hyper kit.
    Here's some pics:
    4770K and 3770k
    Asus 670GTX DCII
    -110c club
    May 2008
    by the LAMP!
    Quote Originally Posted by ci2kla View Post
    my new ones wont even do 2000mhz i have tryed all combinations but non will pass spi32mb just get bsod
    i have phone'd kingston and ask what the problem is with the new sticks i am awaiting the return call
    but with lots and lots of vv's they do this not stable for anything but will boot to os
    I LOVE LAMP!
    Memory Addict
    Aug 2002
    Brisbane, Australia
    EvoCarlos interesting to see what kingston have to say. My Kingston 6GB 2000C8 original kit and rma replacement both failed, but haven't initiated the 2nd rma yet as waiting for such stock to flow down to Aussie kingston channels as well as see how these (MGH-E Hyper) do for others. Keep us updated EvoCarlos
    -110c club
    May 2008
    by the LAMP!
    Quote Originally Posted by eva2000 View Post
    hey eva i will let you know i told them about this kit and its unabilty to run 2000mhz the old stuff mnh-e's would do 7-7-7-20 2000 1.66v stable so what ever the problem is with these i hope them to sort it
    what made me laff was the 2nd xmp profile 3500mhz @ 1.65v 7-8-7-20
    i told them whats the point in that it wont even run 1750mhz
    they have taken all the info from the lable on the ram so they know where and when and what chips they are im hoping there are so others by now that they will send
    i was really happy with the mnh-e's but these are just messing me about
    I LOVE LAMP!
  18. #18
    Memory Addict
    Aug 2002
    Brisbane, Australia
    There's many types of elpida hyper some do 2000mhz 7-7-7-x some do 7-8-7-x. My Corsair GT 2000C7 are 7-8-7-x varieties. So which ever you get is luck of the draw really.
  19. #19
    Dec 2005
    Philly
    Well that's no good. Let's hope I don't have the same problem with my new kit. I see you have the 3x1GB kit so I hope it's not related to my new 3x2GB kit. Will post more info and results tonight.
    Keep us posted on what Kingston has to say about your problem.
    4770K and 3770k
    Asus 670GTX DCII
  20. #20
    Banned
    Feb 2008
    Buffalo, NY
    Yes plz keep us posted... I have my 2nd kit of kingston hypers going back to them soon and I am very interested to see how these new kits OC
  21. #21
    Dec 2005
    Philly
    eva2000, when did you RMA your first kit? Just trying to find out if the batch I got today is the same batch or close to your rma kit that is dead. Or did you get your first RMA a while back?
    Will post results from my kit received today in a few hours
    4770K and 3770k
    Asus 670GTX DCII
  22. #22
    Dec 2005
    Philly
    Man I'm really having trouble getting this new kit stable at 2000Mhz CL7 or CL8. I finally got 2000Mhz 7-8-7-21-1T LinX 5 passes max mem stable with 1.6QPIv and 1.74vdimm. That much higher voltage than my original kit needed to run 2000Mhz.
    I was talking to someone earlier who told me to play with B2B which i have not done yet, its set to 0 by default on my P6T Deluxe V2.
    Any suggestions on the sub timings or B2B setting for 2000Mhz CL7 or CL8?
    Will post some results when I get home later tonight.
    EDIT:
    After reading the MadShrimp Article "Back-to-Back Cas Delay Investigated" it seems I have no chance of getting my kit stable at 2000Mhz CL7 or CL8 on this Board unless I change B2B to either 10 or 12??? I will test this when I get home and hope this gets me stable with MUCH MUCH lower vQPI and vdimm.
    4770K and 3770k
    Asus 670GTX DCII
  23. #23
    Memory Addict
    Aug 2002
    Brisbane, Australia
    I received my rma replacements from Aussie kingston distributor on June 26th so a little over 3 months ago
  24. #24
    Dec 2005
    Philly
    Thanks for the reply eva2000. That was def. a while ago and from Aussie Kingston.
    Well after testing with B2B 12 tonight I quickly got 2000Mhz 7-8-7-20-1T Memtest stable 100% with much lower voltage.
    P6T Deluxe V2
    920 D0 #3911A330
    Kingston Hyper KHX2000C8D3T1K3/6GX (Kingston USA RMA Received 10/5/09)
    20x200
    DDR3-2000Mhz 7-8-7-20-1T / B2B-12
    vdimm 1.70v
    vQPI 1.52v
    I got home, set B2B to 12, reduced vdimm to 1.70v, reduced vQPI to 1.52v and set timings to 7-8-7-20-1T and Memtest ran 100% 8 instances maxmem. I will now run LinX 10 passes and if that passes then will start lowering voltages till I get errors. Then run Prime95 x64 overnight.
    These are the first and only settings I have tried or tested tonight. Once I am done finding stability with lowest volts at these settings I will test max frequency CL7 & CL8.
    4770K and 3770k
    Asus 670GTX DCII
  25. #25
    Jun 2007
    Long Beach, CA
    Hey guys found out one of my stick went bad as well. My question is under the Kingston RMA process it is asking me this -->"Item 1: A discontinued/Obsoleted part number is entered, it can only be repaired. Please choose Repair as Type of RMA and Repair/Discontinued as Reason For Return." So they will only fix the stick now and not replace all of them? Should I call them to setup the RMA process or email it to start? I want a new complete set not thrown together and sent back to me. I see allot of guys RMAing which is better calling or emailing? Thanks
