Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Thread: Gskill trident + ripjaws testing on AMD
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Will get to testing later.....these are retail from newegg so nothing special about them.....
    heatware chew*
    I've got no strings to hold me down.
    To make me fret, or make me frown.
    I had strings but now I'm free.
    There are no strings on me
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Using stock cooling.
    I have my reasons.
    So anyway, hate to dissapoint you guys but I already knew these would not fare well on AMD thus why I have never reccomended them. I didn't purchase them for this system though, just figured i'd test them and break the myth/bad advice that all ram will run rated specs on all platforms.
    Hitting the reboot loop point on the giga....that tells me that I need to break out phase to push further with these. Preety sure they will crack 1800 as they did so testing single sticks but not at the most optimal timings. I can tighten some of the timings more but not the 3 primaries nor does there seem to be gains doing so performance wise.......90 ns btw.....
    heatware chew*
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Ripjaw testing cancelled.....1 stick failing test 2 in memtest underclocked........other stick is fine but can not run rated of 7-7-7 ( reboot loop with any attempt to set cas 7 )
    heatware chew*
    Jan 2009
    Nice, glad to see some testing on this RAM. My Ripjaws will not do the advertised timings, but can do 8-7-6-15 just fine. Can't wait to see what a more experienced enthusiast can do with 'em.
    ASUS Maximus VI Impact | Intel Core i7 4770k | Sapphire HD 5870 | 2x8GB Corsair Vengeance 1866 | Corsair 760AX
    Jun 2006
    COLORADOOOOO
    just got my ripjaws today! along with a ud5p.. now i am just waiting on the 965be from the "simon says contest" to test em out on AMD!! cannot wait to see your results so i can compare..
    Xtreme Mentor
    Feb 2007
    West hartford, CT
    this is a stupid question but
    can u run ddr3-2000 on AMD platform at ddr3-2000 speeds or is ddr3-1800 highest u can go???
    FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
    Asus Crosshair Formula 5 Am3+ bios v1703
    G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
    MSI 7950 TwinFrozr *1100/1500* Cat.14.9
    OCZ ZX 850w psu
    Lian-Li Lancool K62
    Samsung 830 128g
    2 x 1TB Samsung SpinpointF3, 2T Samsung
    Win7 Home 64bit
    My Rig
    Banned
    Jul 2006
    amd can't run ddr3-2000 due to imc limitations, so NO - they won't be able to run stock with amd
    Jan 2009
    Yeah... it would be virtually impossible to get 2 GHz RAM running stable on AMD... no matter how loose the timings...
    Moderator
    Nov 2006
    like to see how they go on AMD platform
    in last 3 years i never used AMD but maybe one day i'll back in black
    Xtreme Mentor
    Feb 2007
    West hartford, CT
    cool thanks.
    OCZ ZX 850w psu
    Lian-Li Lancool K62
    Samsung 830 128g
    Win7 Home 64bit
    My Rig
    Jan 2009
    Ouch... that's harsh on the Ripjaws. I do not think they are very good RAM sticks...
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Quote Originally Posted by Baulten View Post
    Nah its not that they just aren't meant for AMD. Tridents advertise right on box for Intel i7 cpu's ( which is what we got the set for )
    Ripjaws advertise for intel p55 chipset etc i5 cpu's.
    I will try the Tridents tommorow in my asus....that tends to like 4 gig dimms + elpida based Ic's a tad better.
    heatware chew*
    Jan 2009
    Okay, I'll rephrase... they aren't very good RAM sticks for AMD boards It's unfortunate no one I know has a P55 board... I'd like to see if mine will do the specified settings on the right board.
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Just so happens I have a p55 and i5 860 on the way and my own stash of binned powerchips FYI those do run 7-7-7 1600 on AMD.
    heatware chew*
    Dec 2008
    Sweden, Linköping
    Chew* how well do these sticks fare with tweaking? I know there is no way they can run stock on AMD at this time, but do you think these will do well with tight timings, or are there cheaper/better options for AMD?
    SweClockers.com
    CPU: Phenom II X4 955BE
    Clock: 4200MHz 1.4375v
    Memory: Dominator GT 2x2GB 1600MHz 6-6-6-20 1.65v
    Motherboard: ASUS Crosshair IV Formula
    GPU: HD 5770
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    Quote Originally Posted by Smartidiot89 View Post
    Cheaper and better options are most of the time two different things!
    Thanks for the tests chew*! Just to get that right, Tridents are BBSE, Ripjaws are PSC, correct?
    G.Skill has some serious problems with quality control on their Ripjaw kits it seems, I have read about so many DOA kits here and in some German forums...
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Those are tweaked settings on the Tridents albeit not 100%. I need to toss phase on to final tune them as I can not max them out on air. Board limitation.
    I will give the asus a whirl.....I know that board likes elpida better and also does not hit a wall on air.
    The giga tends to run a very tight ship with ram, usually don't acchieve as high an OC.
    DonDan Afaik since i'm not pulling spreaders for RMA reasons ripjaws c7 1600 is PSC. Tridents from all the pics I have seen are BBSE.
    heatware chew*
  18. #18
    Memory Addict
    Aug 2002
    Brisbane, Australia
    sweet looking forward to your results... i recently received my trident and ripjaws for x58 and p55 as well
  19. #19
    Dec 2008
    Sweden, Linköping
    Quote Originally Posted by Don_Dan View Post
    Fine
    Let me rephrase, what would Chew* recommend as benching sticks I can buy? The tricky part is I know all good ICs etc. but I really have no good computerstore near me where I can handpick a few good modules... So basically I am forced to buy expensive RAM with heatspreaders I suppose my budget is around $100-ish ofcourse cheaper is always better if possible, and I'd prefer ordering inside of EU or this shop: http://www.memoryc.com/
    SweClockers.com
    GPU: HD 5770
  20. #20
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Fine
    If you want cheap benching sticks look for these......bet money they are d9 gts....your not going to find 2x2g 1800 6-6-6 in your budget though.
    http://www.newegg.com/Product/Produc...82E16820148223
    Little update......
    Tossed the tridents in my ASUS boots 1 stick.....refuse to boot with 2.....post code d5......played with timings....etc etc no luck. Will swap out with the rest of my asus boards to see if I can get one to boot.....
    Might add all my asus boards are currently pending RMA.....etc they all have issues to start with.
  21. #21
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by eva2000 View Post
    +1
    Lets see which set is better!
    Donate to XS forums
  22. #22
    Dec 2008
    Sweden, Linköping
    Little update......
    Thanks Are those guaranteed D9GTS? As said before there is no way I can go and handpick sticks
    SweClockers.com
    GPU: HD 5770
  23. #23
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    At 1.9 specced voltage they can't be much else than GTS.
    FYI the 2000 kits were specced 9-9-9 2000 1.9v.....
    heatware chew*
  24. #24
    Jun 2009
    Singapore
    nice tests chew and great results, these are very informative to amd users
    Phenom Monsta - Gallery
    AMD Phenom II X6 1055T | MSI 790FX-GD70 | Dominator 1600 C8 8GB | 4770 CF | 2xWD640GB Raid0 | 2xWD1.5TB Raid1 | Corsair HX850 |Lian-Li PC-7FW
    Enzotech Luna Rev.A | 2 x MCW60 | MCP-350 | XSPC Dual DDC Res | TFC Monsta 420/360 Limited Edition
    Canon EOS 7D | EF-S 17-55 F2.8 IS | Nissin Di866 | D-Lite4 | 17" MiniSoft | 53" Midi-Octa | 7" Reflector + 20º Grid | Explorer XT SE | Crumpler 6MDH
  25. #25
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Not over yet just becasue they can't run optimal timings for AMD doesn't mean they can't be enticing
    heatware chew*
