XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 09-18-2009, 04:10 AM   #1
massman
www.hwbot.org
massman's Avatar
Send a message via MSN to massman
Exclamation P55-UD6 socket burn
Just a heads up for anyone running the UD6 board: both SF3D and me have had an situation where the socket seems to be burned. My combo is still alive, but SF3D's might be dead.
I'm not pointing fingers or trying to make anyone look bad. Just a heads up; this might be an unfortunate coincidence.
massman is offline   Reply With Quote
Old 09-18-2009, 04:21 AM   #2
Benny Lodewijk
Team ID - Indonesia
Benny Lodewijk's Avatar
Send a message via MSN to Benny Lodewijk Send a message via Yahoo to Benny Lodewijk
Burnt out when benching with high vcore ?
__________________
Visit Team ID Official Blog
Benny Lodewijk is offline   Reply With Quote
Old 09-18-2009, 04:36 AM   #3
massman
www.hwbot.org
massman's Avatar
Not sure what happened - I'll wait for Petri to post his findings.
Setup still works, by the way, nothing died here:
http://valid.canardpc.com/show_oc.php?id=714433
Old 09-18-2009, 04:45 AM   #4
r1rhyder
r1rhyder's Avatar
Wow, you got Gigaburned.
r1rhyder is offline   Reply With Quote
Old 09-18-2009, 04:47 AM   #5
zalbard
Xtreme Mentor
zalbard's Avatar
Send a message via MSN to zalbard
TOO MANY PHASES?!
__________________
Donate to XS forums
>> Join Intel 4.5GHz LinX Stable Club <<
Looking for Gulftown / Westmere ES
zalbard is online now   Reply With Quote
Old 09-18-2009, 04:50 AM   #6
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
3D mark 01 WR attempts come at a price...
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
Zeus is offline   Reply With Quote
Old 09-18-2009, 05:02 AM   #7
Marco André
Marco André's Avatar
Nice to see 5.2GHz+ on 750
__________________
Originally Posted by To(V)bo Co(V)bo View Post
This is gonna be way more fun than my wifes tits.
Marco André is online now   Reply With Quote
Old 09-18-2009, 05:09 AM   #8
xdan
xdan's Avatar
Wow how the hack is still working, i mean it's burn quite bad, you've checked the performance issues may be you've lost some bandiwitdhy, or some FPS in games, i mean the pins might be for IMC or DMI..
Still it's "ULTRA DURABLE", it burns and it still works..
xdan is offline   Reply With Quote
Old 09-18-2009, 05:20 AM   #9
dinos22
...you two characters
dinos22's Avatar
i've benched 1.7v loaded with my 870 on it
no issues here hehehe
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 09-18-2009, 05:28 AM   #10
eva2000
Memory Addict
eva2000's Avatar
Yikes that looks nasty on the cpu side
Good to know combo still works, but will it burn even more while running now ???
eva2000 is offline   Reply With Quote
Old 09-18-2009, 05:31 AM   #11
Spacemaster
Spacemaster's Avatar
Send a message via MSN to Spacemaster
I think that you have problem with condensation. It is easily to make short-circuit if condensation go to the problematic plase.
__________________
Spacemaster is offline   Reply With Quote
Old 09-18-2009, 05:50 AM   #12
massman
www.hwbot.org
massman's Avatar
I had the burn a couple of days ago when I used my single stage cooling. Re-ran the setup yesterday evening under LN2 and it didn't got worse. As long as it works, I'll keep using the platform ;-).
Btw, I'm not saying this is a general UD6 error. Maybe it's a end-user up, maybe I did something that caused this. I just posted this because apparently SF3D has had the same issue.
Old 09-18-2009, 06:04 AM   #13
Pt1t
Xtreme X.I.P
Send a message via MSN to Pt1t
I know what is it ... that 's an issue from the Foxconn socket. Pin's are not solid enough and made short circuit ...
__________________
***** Visit us on PCWorld.fr *****
Pt1t is offline   Reply With Quote
Old 09-18-2009, 06:15 AM   #14
Snot aap
Snot aap's Avatar
Send a message via MSN to Snot aap
I had the same problem with an Asus MF3 during a compo. Motherboard is dead, cpu is still working though. Is now also missing some "contact pads" might be something with bad contact or nog enough power pins to supply enough power when running the cpu overclocked. (Mine died during 3dmark06)
Snot aap is offline   Reply With Quote
Old 09-18-2009, 06:21 AM   #15
raju
I've knocked a pad off one of my CPU's as well same kind of location - just looking at the land diagram to see which section it is from. I suspect VTT, but not sure.
raju is offline   Reply With Quote
Old 09-18-2009, 06:31 AM   #16
hicookie
hicookie's Avatar
VCC & VSS around there, vcore does this.
hicookie is offline   Reply With Quote
Old 09-18-2009, 06:45 AM   #17
raju
Yeah just checked - A38 line.
Mine did not happen on the GB board - but board is ok (no burned socket pins though) - only 1 CPU pad is gone. Did not use any more than 1.50VID.
Old 09-18-2009, 06:48 AM   #18
crustytheclown
crustytheclown's Avatar
Oh new socket 1152!!!(massman-sf3d edition)
I hope it's just a coincidence
__________________
crustytheclown is offline   Reply With Quote
Old 09-18-2009, 07:17 AM   #19
SF3D
HWbot Crew / X.I.P.
SF3D's Avatar
Hi all!
I got the same problem, but my CPU is working just like before. Mobo does look bad, but maybe it can be fixed. Setup worked just fine until I shutted it down myself for other reasons.
My Vcore was not even that high. 1.57V maximum. Maybe the issue is load calibration or something reltated to that.
Or it might be bad set of sockets, where current is simply burning the pins down.
Well.. I hope this is just these two boards
__________________
AOCC2008 WW #5, MOA2008 EU #5, GOOC2008 WW #1, GOOC2009 WW #3, MOA2009 EU #4, MOA2009 WW #4, GB TweaKing #"5" (4,10), Ditech International OC #2 / #2, ASUS ROG OC Showdown # semifinals
SF3D is offline   Reply With Quote
Old 09-18-2009, 07:22 AM   #20
Bobbylite
Bobbylite's Avatar
are these retail boards guys?
__________________
Currently testing:
i920 @ 762 classified 4way 3x1gb Hypers
i670 @ e659 P55 classified 2x2gb 2400 cas7 G.skillz
2x Vapor-X 5870s 1000/1300 1.18v
Sdumper Uber Dual stage cascade -115 @ 304w Load
Bobbylite is offline   Reply With Quote
Old 09-18-2009, 07:56 AM   #21
massman
www.hwbot.org
massman's Avatar
Yes - retail.
Old 09-18-2009, 08:17 AM   #22
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Looks like the pins melted and the heat caused the socket to then melt. Amazing the chip still works
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is online now   Reply With Quote
Old 09-18-2009, 09:05 AM   #23
saaya
Xtreme X.I.P.
saaya's Avatar
Send a message via MSN to saaya Send a message via Yahoo to saaya
since its the edge of the socket it could very well be insulation... you do use the socket metal thing to clamp down the cpu, right? its leg is right next to those pins, and condensation will form on that metal and then possibly run down into the socket, bam... im not convinced thats what happended, but if you guys had the same thing happen at the same location of the socket... thats not a coincidence... and i doubt vcore is any diferent on those pins then on other vcore and vss pins... so i dont think its some electrical anomally that causes this...
and yeah, modern cpus are really beefy on vcore pins, vtt is their achilles heel, on vcore pins you can roast them for a while before they give up, the only nehalem cpu i heard of that died from vcore for sure was in foxconns labs and it was with 2.4v on air
instant shutdown and dead...
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
saaya is offline   Reply With Quote
Old 09-18-2009, 09:19 AM   #24
raju
yeah mine was clamped properly. I had thought about non contacting pins but that can't be right as only one pin has gone on mine while the surrounding ones are blemish free (no visibly bent pins either). I will try to take a macro pic if I can, there is very little pad left. Looks like some i5 CPU's can have issues when pushed. Mine was not even pushed that hard, I just about got it to 4.8. No moisture anywhere as the whole socket and CPU were completely sealed from the air with eraser. Just one of those things.
Old 09-18-2009, 09:31 AM   #25
Gautam
Captain Jinx
Gautam's Avatar
Send a message via AIM to Gautam Send a message via MSN to Gautam
/resists making sauna joke
__________________
Originally Posted by FUGGER View Post
I put on my shoes before I put on my pants.
Gautam is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
