09-17-2009, 03:39 PM
#1
No rest for the weary
Best ram for AMD platform
So i've gotten quite a few PM's as to whats the best ram for AMD platforms.....
Chopped the model out because it doesn't matter and it's no longer made but based on SPD I'm sure you can figure out what IC's they are.
OC tends to vary based on Mobo used. This is worst case scenario as they fare better on the other boards I've tested..........
Stock cooler on cpu.....Ram air cooled. Stock voltages for everything else.
Vdimm set 1.70 Measured Real 1.68v Rated 1.65v
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
http://www.livestream.com/chewsdisasterarea
Originally Posted by Sampsa
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
09-17-2009, 03:55 PM
#2
XIP
I'll be the first to look like an idiot. Elpida Hyper?
09-17-2009, 03:58 PM
#3
Micron's D9GTR ?
__________________
Originally Posted by dinos22
SuperPi is like caviar. It's an acquired taste.
Originally Posted by K404
"My Backup is bigger than Your Backup"
Live Extreme Overclocking Thread
09-17-2009, 04:06 PM
#4
Xtreme Cruncher
It's hyper, GTR is terrible at 1.65v and all real GTR/GTS kits were rated at 1.85v-1.9v
__________________
#5
Brotherhood
That BBSE...very hard D9GTR run high with tight timing and low vdimm...
09-17-2009, 04:10 PM
#6
Good news and Bad news.
Good news 1st
It's MHN-E Hypers.
Bad News ( for your wallet )
It's MHN-E Hypers
I think you would be hard pressed to push BBSE that far
I have 4 sticks of BBSE to bin in the very near future.
Still on the lookput for an affordable tight latency 1700+ 4 gig solution, will keep you posted but for now hypers are the only game in town.
__________________
heatware chew*
09-17-2009, 09:39 PM
#8
Originally Posted by Blueflame
Those are the 4 sticks on the way.....I would suggest not pulling the trigger until I test them...
We ordered 2 sets he has the other 2 sticks and is having no luck at rated.
__________________
heatware chew*
09-18-2009, 01:04 AM
#9
Thanks Chew thought they might be the four sticks coming soon, I read all the forms just dont post mutch, but this has my attention hope the news is good
__________________
AMD 955
GIGa ud5p
crucial 4g kit
air cooled
09-18-2009, 02:14 AM
#10
1,68v almost 900 6-5-5... very great
__________________
Phenom II 955 c3 | Gigabyte UD5P 790fx | Ati Club3D 4850 | 1x2 OCZ Reaper D9JNL DDR3 6-5-5 1600 @2.05v | Scythe Ninja 2 & Slipstream fan 110cfm | Corsair HX850
09-18-2009, 05:50 AM
#11
trident or ripjaws ? --- 1600 CL6 1.7V is all I need
09-18-2009, 07:24 AM
#12
But which ram kit is that. Ic's is all very good, but knowing which kit it is would be better.
__________________
AMD Phenom II 965 BE - 4 cores @ 4 Ghz:
Thermolab baram with 2X GT's:
MSI GD70 @ 1.5b4
OCZ Platinum AMD Edition @ 1333 6-6-5-18:
Sapphire Vapor X 4870 @ 820/1125:
OCZ Modextreme 700W PSU
09-18-2009, 07:35 AM
#13
Why does it matter? It's only the ICs that are good, and the tuning done by chew*. If you are really interested in what they are, my bet is on Corsair Dominator GT, 2 sticks of a triple channel kit, look at the SPD, 7-8-7-20 timings at rated speed, so most likely the 1000MHz kit.
Thanks for the thread chew*, I wonder who is sending all those PMs to you...
__________________
Intel E8600 // Gigabyte GA-EP45-UD3P rev 1.0 // Club 3D CGNX-G882DDC // Thermalright Ultra Extreme 120 Black // Western Digital Caviar RE WD1600YS // Thermaltake Toughpower 750W // Lian Li PC-7B PlusII // Samsung 931C
RAM: 3x2GB Mushkin Redline 998750, 2x2GB Corsair Dominator GT 2000C8, 2x1GB Cellshock 1800CL8, 2x1GB Cellshock 1866CL8, 2x2GB OCZ Blade 1066 CL5 LV, 2x1GB OCZ Titanium Alpha VX2, 2x2GB Mushkin XP2-6400 996561, 2x1GB Patriot 6400 CL5, 4x512MB Corsair 8000UL, 5x512MB Corsair 5400UL, 2x1GB Corsair Dominator 6400C4D, 1x1GB Corsair 6400C3, 1x1GB Corsair Dominator 8888C4D, 2x1GB Super Talent T1000UX2G5, 2x1GB G.Skill 6400 HK, 2x1GB G.Skill 6400 HZ, 2x1GB Crucial Ballistix 5300, 2x1GB Crucial Ballistix Tracer 5300, 2x1GB Crucial Ballistix Tracer 8500, 6x1GB Crucial 10th Anniversary 5300, 2x1GB Crucial Value 6400 CL5, 2x1GB FSC Value 6400 CL5, 2x1GB Cellshock 1066CL5, 2x1GB TeamGroup Xtreem 5300 CL3 and 2x1GB TeamGroup Xtreem 8500 CL5 cooled by Corsair Dominator and Dominator GT Airflow Fan
09-18-2009, 08:46 AM
#14
Xtreme X.I.P.
hows amd handling high vdimm chew?
does the imc like d9gtr style pounding?
would be a good alternative since micron can do 800+ 665 as well and is cheap these days, only drawback is its 1gbit so you need 4 sticks for 4gb or 2 dualsided sticks which wont clock as high... plus it needs 2.2v+ to max out cas6...
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
09-18-2009, 08:54 AM
#15
Saaya I have run up to 2.3v to a particular set of GTR that is just indestructable for prolonged periods about 5 8 hour bench sessions one of them being at the AMD austin event 2 days back to back.
GTS I have noticed degradation with even only 2.0v on particular sets from a particular manufacturer. I have another set of GTS that seems to be better quality which has been running 1800 7-6-5-15-11 1T at 2.1v for some time now.
No illfate to the cpu's and have noted no degredation to IMC's.
I actually have killed 3 cpu's total. Each time I had a low volt kit installed. 2 times the PWM failed due to condensation one time was with a delidded part just the cpu died.
The GTR's were doing 1720 6-6-5-15-11 1T at 2.3v
As far as kit you should be buying it based on your own preference......etc quality of manufacturers Bin, warranty service, whether they fit.....and lastly how they look.
As stated this "kit" had a model change.....it's now 7-7-7 1800.......it was replaced so really the model is useless to you not to mention it was from the bad batches.....which I did not want everyone to go searching for to buy
__________________
heatware chew*
09-18-2009, 09:11 AM
#16
On a side note....I had located OLD stock of 2x2g GTR.....turned out that the model # was indeed correct however what I got sent was not what I paid for......Really don't want to pay diablo's price........
If you know of a lesser "brand" source for 2x2g gtr I will give them a spin
__________________
heatware chew*
09-18-2009, 11:22 AM
#17
Xtreme kickass
chew* do you know which 2x1Gb sticks have GTR or GTS chips nowadays? Ballistix 1800 8-8-8 maybe?
I'm looking for a nice kit for a nice price for 32M runs.
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
09-18-2009, 11:23 AM
#18
of OCz Reapers 10666 6-5-5 @ 1.85v I got D9JNL...I like heatsinks . worth of half price I paid for OCz..It would be nice put those heatsinks on some modules with good ic
__________________
09-18-2009, 11:37 AM
#19
It's a crap shoot now with crucial, not to mention a crapshoot on lifespan.
Best bet is to buy 1.9-2.0v rated stuff.....we were buying 2000 9-9-9 2.0v rated stuff as it was guaranteed but that model got dropped.
Some of the new stuff could be anything, samsung etc etc....
These are a preety safe bet D9 GTS.
http://www.newegg.com/Product/Produc...82E16820104130
http://www.newegg.com/Product/Produc...82E16820104152
__________________
heatware chew*
09-18-2009, 12:25 PM
#20
Xtreme X.I.P.
wow your gts stuff wasnt very good at all eh?
1800 cas7 needed 2.1v? wow... i have jnl sticks that do 2000 cas7 with 2v... and you know jnl was a step down from gtr/gts
well i have to mention, those were the best sticks out of a few thousand i went through when i worked at cellshock hehehe
but 1800 777... i think more than half of the jnl i worked with could do that, probably 70%... and they only scale up to 1.8-1.9v... so at lower volts too...
have you tried jnl on amd? should work fine, and i think its easier to find than gtr/gts, and probably cheaper too...
i think almost all jnl did 1333 555 with 1.7v iirc, it really didnt like cas6 though iirc...
__________________
09-18-2009, 01:23 PM
#21
Nah it needs 2.1 to do 7-6-5. Does 1800 7-7-7 undervolted but on AMD 7-7-7 isn't optimal.
JNL isn't so hot on AMD, OK but nothing spectacular.
Basically what people need is 5-5-5 1333 or 6-6-6 1600 in a $100 2x2 gig kit.
If one of these Ram companies did that and the IC's worked hassle free on AMD they would have a winner.
I think I may have found GTR/GTS or GTN 2x2g gonna take a chance on em.
__________________
heatware chew*
09-18-2009, 01:55 PM
#22
Xtreme X.I.P.
i have only 1 dual sided jnl sick
was ES stuff at cellshock when i left... never tried on amd...
but if 1gb jnl works, 2gb should work too...
and in my experience dual sided ddr3 sticks, at least micron, have probs at 1600+, but timing wise they do the same as 1gb sticks... so im pretty sure 1333+ 555 is possible with jnl 2gb sticks... and jnl should be cheap... def give it a try if you see 2gb jnl stuff around!
ive had some jnl 1gb sticks up to 1500 stable with 555 and 1.7v
__________________
09-18-2009, 02:32 PM
#23
saaya, it looks good...Im waiting for Gigabyte UD5p :p Are you planing to buy amd?
__________________
09-18-2009, 10:46 PM
#24
chew, i just got these corsair sticks and it doesn't want to run at 1600 8 8 8 24 1t, now i'm trying to tighten the timings instead and so far i'm at 1466 6-6-6-18-24 1T at 1.86v. what do you think is a realistic maximum clock i can get with it and perhaps at a safe voltage?
http://www.newegg.com/Product/Produc...82E16820145267
btw, how much would that ram you tested cost like? i am still on the lookout for better modules.
09-18-2009, 11:08 PM
#25
Beats me what IC's does corsair list on there site for that Kit.
My set was about $400 total for a 6 gig kit one stick was sorta DOA.
I may have a 1600 6-6-6 2x2 gig AMD kit on the way for a review but I wouldn't hold your breath as it appears they are short on stock however very curious how they fare.
__________________
heatware chew*
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
