After some time i was a bit benchmarking my CPU, x4 955 BE (0911EPMW), with AIR cooling CM Hyper 212, motherboard midrange MA790X-UD4 in classic miditower case, my room temperatures ranged between 21-22 C.
First i began testingmy favourite benchmarks
[First my new max validation:
4305 MHz not bad, i think, for retail Phenom II and normal room temps :twisted: . I hope higher im winter
I was sleeping and continued today:
Today was firts Cinebench in x86 WIN XP , here is each extra point hard fought.
I just broke my record by about 10 points
Than i was going to x64 win7. My previous record:
Unfortunately, i had no luck.
Despite the higher frequency of CPU, which I was able to run Cinebench, result was about 150 points lower. The problem was that busspeed 206 crashes program Cinebench. I probably third time he managed to pass, but score was worse. I have tried different settings on the 3939 MHz and 3958MHz with lower uncores it is also the original result was not enough. So perhaps another time ...
For a change, I booted into Win XP x86 and began
1M superpi
1M=16.469s při 4162 MHz
Finally i started demanding SuperPi 32M (DDR2 There are a lot of convoys with disabilities compared to DDR3
PS: thanks for all experienced users as *Chew, MSIMAX, Daveburt, Zeus, Slappa, Titan, charged3800z24 etc...We love Phenoms
