4890 @ 900/1000, Cat 9.8 , GPU 10.750
4890 @ 900/1000, Cat 9.9 , GPU 11.043
RE 5, CAT 9.8 + 4890 @ def, AVG = 98.6 FPS
RE 5, CAT 9.9 + 4890 @ def, AVG = 107.6 FPS
COS :
- inc gpu score in vantage +/- 300 pts
- INC / FIXED FPS on area 3,4 at RE 5
COS :
with AA, in cat 9.8 had drop FPS in area 3 and 4, i'll found this Pic on forum
NOW with cat 9.9, 8xAA + 4890 @ def.....hmm preety COOL
CAT 9.9, 8xAA + 4890 @ 925/1100
CAT 9.9, 8xAA + 4890 @ 1000/1150
wow, looks like a nice performance boost. i'm wondering why ati doesn't promote the 9.9 as such? there's no hint at better performance in the changelog.
what's your OS? vista or 7?
1. Asus P5Q-E / Intel Core 2 Quad Q9550 @~3612 MHz (8,5x425) / 2x2GB OCZ Platinum XTC (PC2-8000U, CL5) / EVGA GeForce GTX 570 / Crucial M4 128GB, WD Caviar Blue 640GB, WD Caviar SE16 320GB, WD Caviar SE 160GB / be quiet! Dark Power Pro P7 550W / Thermaltake Tsunami VA3000BWA / LG L227WT / Teufel Concept E Magnum 5.1 // SysProfile
2. Asus A8N-SLI / AMD Athlon 64 4000+ @~2640 MHz (12x220) / 1024 MB Corsair CMX TwinX 3200C2, 2.5-3-3-6 1T / Club3D GeForce 7800GT @463/1120 MHz / Crucial M4 64GB, Hitachi Deskstar 40GB / be quiet! Blackline P5 470W
good !
ROG Power PCs - Intel and AMD
ok so how successful is a "simple uninstall old, install new" lately, if even that (do you just install on top)?
do i need to go get driver cleaner and worry?
i7 2700k 4.60ghz -- Z68XP-UD4 F6F -- Ripjaws 2x4gb 1600mhz -- 560 Ti 448 stock!? -- Liquid Cooling Apogee XT -- Claro+ ATH-M50s -- U2711 2560x1440
Majestouch 87 Blue -- Choc Mini Brown -- Poker Red -- MX11900 -- G9
9.9 on 09/09/09
i mean the publish date is on their site
Core i7-4930K LGA 2011 Six-Core - Cooler Master Seidon 120XL ? Push-Pull Liquid Water
ASUS Rampage IV Black Edition LGA2011 - G.SKILL Trident X Series 32GB (4 x 8GB) DDR3 1866
Sapphire R9 290X 4GB TRI-X OC in CrossFire - ATI TV Wonder 650 PCIe
Intel X25-M 160GB G2 SSD - WD Black 2TB 7200 RPM 64MB Cache SATA 6
Corsair HX1000W PSU - Pioner Blu-ray Burner 6X BD-R
Westinghouse LVM-37w3, 37inch 1080p - Windows 7 64-bit Pro
Sennheiser RS 180 - Cooler Master Cosmos S Case
I'm running Cat 9.9 right now as well. I don't have any pre-9.9 benchmarks to compare to but it seems like it fixed the BSOD I was getting in L4D which is good.
"Everything is amazing and nobody is happy".
- Louis CK
I can't wait to get a 5870 and use these drivers. Hopefully I can then max out ArmA2. AMD is executing well these days.
exactly what i was thinking... arma2 everything on maximum...cant wait...
Arma 2 just plays so bad, so clunky, makes the game not enjoyable, ive tried it even with gtx 295 quad sli, doesnt scale well at all.
I have vista and always get the reboot now notice.
http://support.amd.com/us/kbarticles...eDriverWV.aspx
Plays fine!
CoJ:BiB -> CF supported![]()
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55''Samsung LED 3D TV
Odd.....Have Vista and haven't had to reboot after installing new Catalyst drivers in a loooong time....honestly, cannnot remember the last time installing new Cat. drivers required a reboot. And always have installed the new ones without uninstalling the old. Do the same on my XP machine, same outcome....no reboot required, not uninstall/reinstall crap.
Catalyst drivers just uninstall themselves and then install the new ones...no drama, no rebooting, nothing. They just work and have been for a long time now.
