Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: My first sub zero W3540 tests
    no sleep, always tired TheGoat Eater's Avatar
    Oct 2006
    Iowa, USA
    It feels good to be benching again...
    Thanks to TiTON for helping with the pot and Charles for help and stuff
    Also thanks to MSI for some great products that I have had the pleasure to use and they are growing on me a lot
    Hours on hours of DICE benching and learning my board... my uncore seems to top out at 4900... I got like 50lbs of Dry Ice for $10 USD and spent 6 hours then slept and did 4.5 hours so great use of $10 eh? I mainly learned the board by trial and error - the chip is good for 4.6-4.7 on decent water...
    First - Big thing - I had to use 1.51 CPU-Z instead of 1.52 as the newer version drops multis as I increase bclk - anything over 5 bclk... so to show actual speed I needed either cpu-tweaker or 1.51 CPU-Z
    Setup -
    W3540 3851A257
    MSI X58 Platinum SLI
    MSI N260GTX-OCv3
    7900GS SLI (OEM)
    Silverstone Zeus 1200W PSU
    WD 80GB IDE HDDs
    XP PRO SP2
    K|ngp|n F1EE
    Muskin Elpida Hyper ... $70 pair - stripped to OEM style
    Lots of Scythe High CFM Fans
    First the pics of the setup -
    Results - have a lot of tweaking to learn and study LOL
    the AM3 is with a bone stock card as the OCv3 has no software voltage adjusting, need some mods asap
    I know not overly impressive but its a start
    Feb 2009
    Athens - Hellas
    Nice start
    3D results?
    Xtreme X.I.P.
    Oct 2006
    Error in computation in Pifast But apart from that, good stuff!
    --->TeamPURE<---
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    Nice resutls Ryan! Did you run 7900 GS SLI too?
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    take me to the manbar
    Apr 2008
    South Africa :)
    gogo ryan, great stuff, im sure in the future you will get 5.2 out of that chip ! there is so much to i7's.
    how did you like the board? any issues?
    Moderator
    Jun 2002
    gooo goatie... gimme that no look pour again
    Banned
    Feb 2008
    Buffalo, NY
    Nice stuff goat, 50lbs for $10 is a great price! Lets see some more 3D!!
    Oct 2006
    Iowa, USA
    thanks a lot everyone!... I have to get more GPUs modded to be competitive and don't save anything that isn't worth points LOL...
    EDIT- testing more now - work... what is that LOL
    ODOC
    Aug 2006
    Copenhagen - Denmark
    hey man, great start and just the batch i needed to see
    keep pushing it
    Mar 2009
    Slovakia
    nice!
    sorry for my bad english
    Team Inkognito is ready for overclocking!
    I am Xtreme
    Aug 2008
    way to go GoatEater
    superpi1m ..pls run with ht off
    awesome tweaking with the msi board...whats your vtt? pcie? using latest bios?
    Team.XS FTW!
    Xtreme X.I.P.
    Nov 2002
    Shipai
    thanks to charles for... stuff? ... 0_o
    nice results, good to see you picking up speed
    Jan 2006
    sweet OC session
    what was your temp range while benching?
    Intel i5 3570K@4.6ghz, Swiftech Apogee GTZ, mcp655, Typhoon III and mcr320
    Gigabyte Z77X-UD3H, 8GB 2000 cl9, M4 128GB SSD, 2TB W-D green USB3.0
    MSI 7870 HAWK 1300gpu /1450mem, ASUS VG23AH 23" IPS 3D 72hz
    PCP&C 750W in CM651 case
    89 Ford Mustang coupe burnt orange on chrome ponies
    Bum & Hater #1
    HEATWARE: d50man
    Jun 2009
    Ukraine, Dnepropetrovsk
    TheGoat Eater nice try, but i consider your cpu dont need high voltage. Try to use under LN2 1.5-1.55V on cpu, maybe your results will be higher and faster.
    Forgive for my English because I only learn it
    Oct 2006
    Iowa, USA
    Quote Originally Posted by MaJ0r View Post
    yeah - I am gettign one reading in bios and another in cpu-z ... need to find readpoints as I need to know what it is, and they vary quite a bit... IDK if it over volts a bit too...
    Quote Originally Posted by d50man View Post
    sweet OC session
    -62C to -50C / using Everclear as a buffer...
    Champion
    Aug 2004
    SoCal
    Great to see the pot is being used well Have fun with it
    - Ton
    Nov 2006
    Vienna
    Nice Results. Go ahead.
  18. #18
    Oct 2006
    Iowa, USA
    Better Runs -
    struggling with bclk and uncore cooperation
    once again cpu-z errors with 1.51
  19. #19
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by TheGoat Eater View Post
    Better Runs -
    lol whats that a W3560 hahaha
    Team.AU
    Got tube?
    GIGABYTE Australia
  20. #20
    Jun 2009
    OMG Nice CPU w3560
    TheGoat EaterSimilar your results improve each time
  21. #21
    Champion
    Dec 2005
    Budapest, Hungary
    hehe i have the same batch, its really similar to mine... sadly it dont goes anything better with cold or higher vcore... can handle -130 easy but 3D cant go over ~5.1G
    max clock only:
    but... i wish you better luck on ln M8 and congrats anyway
  22. #22
    Oct 2006
    Iowa, USA
  23. #23
    Jun 2009
    Achill3uS at me same batch But i try to improve my results, and i dont give up. If i can't run over 5100 MHz, i wiil sell it
  24. #24
    Oct 2006
    Iowa, USA
    Got my MSI N260GTX-OCv3 modded and will test on water for now...
    prep work done - off to buy DICE in anout 7 hours when they open
  25. #25
    Mar 2005
    Mumbai, India
    Good run man!!
