Simon says Simon needs help.
1. Rig photo with monitor in shot at point indicated below (H20)
2. Screenshot: Prime95 Blend 30mins; @ 30Mins; with bench running, take a screenshot: CPUz memory & CPU; AMD Overdrive Photo with current CPU Status Open; Radiator Fan Speed Indicator
3. Screenshot: End bench. Wait. Same @ idle
4. Notes on H20 solution and any metered temps
OR
1. Rig photo with monitor in shot at point indicated below (Cold Air)
2. Screenshot: Prime95 Blend 30mins; @ 30Mins; with bench running, take a screenshot: CPUz memory & CPU; AMD Overdrive Photo with current CPU Status Open; CPU Fan Speed Indicator
4. Notes on air solution and any metered temps
Would like to see solutions with high RPM radiator fan speeds.
Random Piece of AMD kit will be sent to 3 of the most helpful posts.
