Results 1 to 22 of 22
Thread: naked w3520
Threaded View
    Feb 2008
    Canaduh
    naked w3520
    almost there at last!
    my high-tech holding tool
    nearly done, still need to get rid of a thin copper layer and the solder
    at first i didn't want to remove the copper surrounding but i removed it after all
    done!, will it boot?
    of course it still works, i can't believe you doubted
    the IHS have been sanded down totally using power tools, the only problem is the heat generated by the sanding action.
    I've tried everything i had under the hand:
    Belt sander > generated lots of heat, probably the worst of them all, but the sandpaper was done and didn't bother changing it to see if it helped.
    Grinder/flapdisc > did 80% of the job with this, generates LOTS of heat. 20sec sanding/2minutes off
    8" disc sander > with 60 grit that thing works really good, no to be used toward the end tho, or with very little pressure
    orbital sander > than thing amazed me, even with gritty sandpaper it doesn't leave a mark and doesn't generates heats like the other tools. you can literally sand without stopping. But it's slow compared to the hardcore sanders
    Next time i lap a CPU i'll use this to get the top off and finish by hand
    hand> works good as usual but not fast enough for me
    why i did this?
    just for the hell of it
    cpu is damaged, but still works see sig for what it can do, but can't stay on without a bsod for a more than a few hours in a row. He deserved some punishments after so many hassle
    don't try this at home, dangerous procedure!
    Intel i7 980x / 3001B331
    HK3.0+LaingDDCPRO+XSPCRX360+1xMCR220
    EVGA Classified X58+EK FB
    6GB Corsair Dominator GT 1866 7-8-7-20(TR3X6G1866C7GT)
    ASUS GTX580
    Enermax Revolution+85 950w
    Corsair Obsidian
