As the title states.
Chip 1 default vcore.
Chip 2 default vcore, stronger core's it seems weaker NB.
Chip 3 default vcore, has the strongest NB ( needs least amount of NB_vid )
heatware chew*
I've got no strings to hold me down.
To make me fret, or make me frown.
I had strings but now I'm free.
There are no strings on me
This is a preety beat install of XP Sp1 but its the most reliable, seeing as all my other OS's are corrupt atm, scores won't be the greatest.
Playing around with max benchable core frequencies atm.
Chip 3 ( I think this might me my ln2 chiploves volts )
Not bad for the heatwave i'm dealing with atm.
Chip 2 Looks to me you air guys are gonna want the default 1.4v chips.
Seemed to need quite a bump here......
Seems to be a pattern forming all 4 gig + in cine, FYI if cine passes this at this speed 4.1 3d is a cinch
Chip 1 with 1.425 default is almost identical to its brother chip 3 for max.
I think I will go play the lottery now.
heatware chew*
Reserved 2
heatware chew*
Reserved 3
heatware chew*
You can send the worst one my way when you are done.![]()
heatware chew*
Damn I need to get ione of these.......4.1ghz default core...hell yea!
AMD 1090T@4.0ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus Crosshair IV Formula
ht 2400mhz / nb 2400mhz
12gb Gskill 1300mhz
HIS HD5970
Enermax Evo Galaxy 1250
case: XCLIO A380PLUS-BK
4.61ghz water
4.5ghz superpi 1M 15.585
http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
Phenom 2 125w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=117414
Phenom 2 140w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=109214
Phenom 2 AM2+ 940 cold air results
http://futuremark.yougamers.com/foru...ad.php?t=97430
If I dont get every single drop out of my cpu I feel like someone is stealing from me
Nice stack
Is it doable for most of them to go over 4Ghz or just those cherry picked?
heatware chew*
and where is third chip?I see 3 x4 965, right?
ROG Power PCs - Intel and AMD
btw, send me one, change with my x4 955
Chip 1 has a default Vcore of 1.424V?
Looks good mate, wondering how these cherry picked retails will do.(sorry, couldn't resist.)
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
Yes russ it varies from chip to chip thus amd's loose rating of 140W TDP.
Here's something my review samps can't do......
2 things are needed to scale these chips, voltage and temps.......
I could not boot at 1.55v on my review samps on phase........
Don't try this at home kids....cpu death is imminent especially on air like this.
heatware chew*
Sorry, didn't see the boxed part of the title
p.s. hangover sucks![]()
That's crazy. Looking forward to great things to come with these chips you got there.
Il try for compúarsion the same with my x4 955and the same vcore, but think, end behind 3900-4000 MHz
lol, u mean really, 1.728V with AIR? OMG...I have fear with 1.55V
. Il look forward next benches chip2 and chip1 (to time u post chip3 at air)
here my chip x4 955 with 1.4V 4000MHz/2800MHz (higher i dont tried)
( http://img341.imageshack.us/img341/2541/easyw.jpg higher image)
I runing my 940BE @ 1.585v 24/7 and 1.625v when i bench..some chips seems to like more vcore than another, i dont wory about to high vcore. They always have reboted for me if i push the vcore to much
, then i lower it abit. my first 940BE hade problems over 1.55v but this chip works fine to about 1.625v with air.
whau, interest...think, my like 1.45,1.475 and 1.485V mostly..
whats your temps at 1.585 (1.625V)?
Flanker flop that NB up to 2900-3000 at least for all cores bud at 4 gig and 1.4v
High NB changes alot![]()
heatware chew*
