Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: Asus Mars Quad SLI overheating might be solved
    Jul 2009
    Asus Mars Quad SLI overheating solved
    Whats going on guys
    Got 2x Asus Mars yesterday.
    The performance is the best I have ever seen. Crysis Warhead 64 2560*
    1600 Enthusiast 16Q AA Ice Level running ok, with 4 AA 8Q pretty perfect.
    Best setting with stock clocks is 2 AA. My Mars Quad SLI idle at 50-60c but also reach 100c and they shut down.
    The cooler is a joke ,why didnt Asus use liquid cooling. It would have been the ultimate thing. So I need someone to build blocks!!
    Im now checking for RMA or return if the the overheating cannot be solved.
    When the Mars are not fully used temps are ok. Passes also Vantage.
    Are my Mars bad like OBRs is. Has anyone tested his Mars?
    Update: I optimized the extreme ventilator air flow and the Mars can hold 93c now
    Nov 2005
    Didnt you get the momo. these mars bars melt, its no secret..
    Intel I7 3.5ghz 4770k @4.5Ghz 1.285v HT-Enabled | Gigabyte OC z87 DDR3 | 2x8 Avx 2133 C9 @2400 C10 1.64v | PC-Power & Cooling 950w MKII Single Rail Monster | Creative ZXR Sound Card | 24" NeC MultiSync 24WMGX3 1920x1200 60hz | Sennhizer HD650 Headset | Various HDDs 5+ Terabyte | Noctua D14 Heatsink Push/Pull Config | 2x His 7950`s X-Fire @1120/1450 *Stock Cooling* | LG Bluray Drive/Writer |
    Nov 2007
    San Diego, CA
    I don't think besides you and ORB we have other having this card. It might be off topic but can you take a screenshot of your Crysis benchmark @2560x1600?
    CPU: Core i7-2600K@4.8Ghz Mobo: Asus Sabertooth P67 Case: Corsair 700D w/ 800D window
    CPU Cooler:
    Corsair H70 w/ 2 GTs AP-15 GPU: 2xGigabyte GTX 670 WindForce OC SLI
    RAM: 2x8GB G.Skill Ripjaws PSU: Corsair AX850W Sound card: Asus Xonar DX + Fiio E9
    HDD:
    Crucial M4 128GB + 4TB HDD Display: 3x30" Dell UltraSharp 3007WFP-HC
    Speakers: Logitech Z-5500 Headphone: Sennheiser HD650
    Jul 2009
    Here is a first run with Asus Mars Quad SLI
    Crysis Warhead 64 2560*1600 Enthusiast Frost Level
    Fps are actually hitting 90 but the tool doesnt show it
    Nov 2007
    San Diego, CA
    That's impressive man, Crysis 60fps @2560x1600 is finally reality. I'm wondering what if you crank up to 4xAA or even 8xAA, does the 4GB memory help?
    CPU Cooler:
    HDD:
    Jul 2008
    I have seen approx 30% increase from I7 platform from QX9650. I think it's the triple channel RAM and the CHip help a lot, not to mention 2x Mars is the top benchmarker. With that many horses in your Stall, I would be kinda dissapointed with 60 fps. Evidently, the main problem with running these cards is that they turn your case into a Hibatchi Grill. lol
    Asus Rampage Extreme x58, T.R.U.E. Copper
    I7920 SLBEJ 21 x 210, 6GB DDR3 Mushkin 1683
    Win7x64, 4870X2 Quad-fire + 240GT PhysX
    3dMark06 - 30,048 3dmark Vantage - 32,414
    [SIGPIC][/SIGPIC]
    PI in the face
    Nov 2008
    whats your room temp OP
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
    -_-
    Sep 2006
    ATLanta, Ga.
    Do you have these cards sitting in an enclosed case or are they in a caseless setup?
    Quote Originally Posted by Gautam View Post
    I'll add my name to this elpida graveyard as soon I even think about running 32M. (yes, the thought is enough)
    Jul 2009
    Quote Originally Posted by iTravis View Post
    Thx. The ram makes the difference so performance is not breaking in so much.
    Ram was the last bottleneck in my Systems.I tried to kill the Mars and put 16Q from no AA in game and the ram just ate it. With liquid or extreme cooling 16Q should work. The benchmark tool is not showing the real performance I think coz the difference between recorded fps and fps counter is really big. Like with 8Q Ice Level timedemo recording 35 but counter showing 110. In game its ok.
    Jul 2009
    Quote Originally Posted by Bobbylite View Post
    Case temp is 22c
    Jul 2009
    Quote Originally Posted by Brian y. View Post
    They are in my Cosmos S with the side open and 2x 22cm fans working from the side. I was checking temps also with a laser.
    I think either my Mars are bad or the ram has unlocked the full boost so when performance explodes heat explodes too using the tdp of 700 watts. Running Crysis 64 could be now like running furmark
    Dec 2006
    Kuwait
    my cards also reach 95C , but i set the fan rpm to 85 (with evga precious) and the temp. 60~70C
    Gaming rig;
    ASUS RAMPAGE IV BLACK EDITION
    I7-4390K
    G.SKILL Trident X 16GB 2400
    Intel 530 240GB
    2x Asus GTX780
    Corsair AX1200
    HP ZR30w 30
    Win 8.1 pro
    Sound rig;
    Auzen X-Fi H.T. HD --> Yulong D100 MKII --> D-7100
    Jul 2009
    Quote Originally Posted by koc View Post
    Thanks. I set both fans to 100% with precision and they reach 100c in Crysis 64. Other games run cooler. I was playing Wolfenstein 2 and temps were 70c with fans on auto. So I think the Mars are just like that. Some games are now like furmark. If someone is building blocks let me know
    Anyway, I have other liquid setups. Its just too bad that Asus build a cooler that cannot hold stock clocks
    Jul 2009
    Today I was using high flow ventilators, so creating extreme airflow around the Mars. In
    Crysis Warhead 64 2560 1600 Enthusiast 2 AA ice level they could hold 95c now. I was also experimenting with the volterras.
    I will now build an old mod that will create extreme airflow inside the Mars. My goal is 80c with fully loaded oc
    Jan 2009
    Italia
    try with cpu at 4ghz.... quad sli run more great
    nb: try to set at 0 pre render frame in the nvidia control panel
    Jul 2009
    Quote Originally Posted by Andrea deluxe View Post
    This is basic stuff
    My 975 was at 4. Tool not showing the right speed.
    Also tested with 4.6 but it is NOT needed in Crysis.
    Im working on temps right now, not drivers.
    Jan 2009
    Italia
    Quote Originally Posted by EtheEnthusiast View Post
    This is basic stuff
    i have used nibitor to change the fan regulation on my ex gtx 295 quad sli.....
    i remenber i have set to run 100% fan at 82°.....
    but i dont know if this trick work whit mars....
    Go here: http://www.mvktech.net/
  18. #18
    Jul 2009
    Good suggestion but the auto or manual fan settings are
    not the problem. The coolers cannot hold the Mars without
    support due to the TDP of 700 watts. I can use precision to set
    auto fans or use the Asus Smart Doctor to program fan behavior.
    Even if I set fans to 100% the Mars were reaching 100c in Crysis. With
    extreme ventilation I could get them to hold 95c. As I said before I will build
    an old mod that might solve the problem.
  19. #19
    Jan 2009
    Italia
    RMA....
  20. #20
    Xtreme Legend
    Mar 2005
    Australia
    another Mars overheating
    damn
    Team.AU
    Got tube?
    GIGABYTE Australia
  21. #21
    L-l-look at you, hacker.
    Jun 2007
    Perth, Western Australia
    Just a thought, but could you flip the PCBs and mod in MCW-60s? Haven't seen any PCB shots with dimensions listed, so not sure if they'd fit on, but it'd certainly solve your heat issues.
    Rig specs
    CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
    Foundational Falsehoods of Creationism
  22. #22
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    MCW60 with G200-compliant x-plate will fit without modding.
    You were not supposed to see this.
  23. #23
    Jun 2007
    The MCW-60 may fit the socket (great if it does), but from looking at the pics you're still going to have to flip the PCBs to get two on there.
    Rig specs
  24. #24
    I am Xtreme
    Dec 2008
    France
    Can it be bad TIM?
    Donate to XS forums
  25. #25
    Jul 2009
    Good point guys
    I was thinking the same, just colling gpus and cooling the rest like with pots or evaps. Flipping the second pcb will be a problem due to the ribbon cable. Asus said its longer but I dont think its enough. The reason I use the WS Pro for the Mars is that there is a lot more space between the cards than on the R2E but I dont know if it is enough.
    Still Im not sure if the Mars are bad. Both of them behave the same way. I dont want to lose the rma chance right now. I contacted customer support but they have not answered (of course) . When its clear that they are not bad I have to mod them. I hope that one company or builder will build blocks, otherwise I have to take them apart and find another way. Best would be to see what temps other Mars users have on full load.
    Edit: I dont think its bad tim but if others dont have problems on full load it could be possible
