Results 1 to 25 of 45
Thread: Stuck at 3.7Ghz and NOT liking it one bit
Threaded View
    Mar 2008
    Pennsylvania
    First...
    Win XP SP2 32 bit
    AMI 0802 BIOS (latest)
    ok here is two settings in my BIOS that have me confused:
    FSB Frequency.......... stock = 200......range = 200-600
    description: Displays the frequency sent by the clock generator to the system bus and PCI Bus.
    CPU/NB frequency.......Stock=auto.....range = 800, 1000, 1200, 1400, 1600, 1800....4000
    description: this item appears when you set the AI overclocking item to manual and allows selection of the CPU frequency.
    CAN ANYONE WITH AN nVIDIA CHIPSET EXPLAIN THESE SETTINGS?? The descriptions are what I don't understand. The "settings" seem to be backwards to me as per the descriptions.
    I'm assuming the FSB Frequency is the CPU frequency...but that doesn't explain the description for the CPU/NB frequency.
    PROBLEM: When ever I try to go over 3.7Ghz is get BSOD 0x000000A stop error at the Winows XP progress bar loading screen.
    Here is link to my best, stable, 3.7Ghz OC: http://www.overclock.net/amd-cpus/49...hread-193.html...(VERY BOTTOM POST ON THIS PAGE)
    Coolermaster ATCS 840 case, ASUS M4N82 Deluxe nVidia 980a chipset, AMD 955 B.E., Prime95 Stable @ 3.7ghz, Corsair CM2X2048-8500C5D, EVGA GTX 580, WD VR 300Gb, WD Black 1TB, LG CD/DVD Burner, PC P&C 750W, Zalman CNPS 10X Extreme CPU Cooler.
