08-14-2009, 09:08 AM
#1
Intel Cpu Test !!!! I9 AND X58 EXTREME
08-14-2009, 09:20 AM
#2
Xtreme MAD
If you can't give more information, please stop posting.
08-14-2009, 11:26 AM
#3
Banned
Hey, I love it! Please post more teasers.
08-14-2009, 10:01 PM
#4
08-14-2009, 10:14 PM
#5
Temperature stats would be nice.
__________________
Rampage 2 Extreme · GTX295 SLI 1792MB FTW · Core i7 920 4.2GHz · Corsair HX 850W · SupremeFX X-Fi
6GB GSKill Trident PC3-16000 · Intel SSD 80GB RAID0 & Samsung F3 1TB RAID0 · Silverstone TJ07 · Samsung 24"
08-15-2009, 12:15 AM
#6
+1
Thats a nice voltage already, 1.4v for 4.35GHz and its from 2.40GHz.  Yeah, I know its an ES.
Some info on the cooling? Water, right?
__________________
flickr®
[My Files.rig:] M:/asusr2g.mob V:/nvgtx275.vid P:/inteli7920.cpu C:/cmhaf932.cas R:/gskill6gbnq.ram C:/corsairh50.wck P:/corsairhx850.psu
08-15-2009, 02:49 AM
#7
WATER 3.3XXG 26度...
08-15-2009, 03:46 AM
#8
first stepping of a gulftown will be crap as bloomfields right? how about a realtemp screen
08-15-2009, 03:51 AM
#9
The i9 is what I am waiting for
Just wish people would "get over Windows XP already", why test such powerful CPU's on such an old OS!
08-15-2009, 03:56 AM
#10
He´s using Win7.. at least in vantage
__________________
System #1:
i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6T 0603, 3x2048 Corsair Dominator 2000CL7, Sapphire 4870X2 @ 825/1000 (Asus TOP Bios), Corsair HX1000, 1x150GB Velociraptor, 1x1TB WD Green, 1x500GB WD Caviar
Cooled by:
Loop 1: D-Tek Fuzion rev1, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Scythe Ultra Kate 2kRmp Pull
Loop 2: XSPC 4870X2 Acetal, Laing DDC-1T /w XSPC Res Top, Thermochill PA120.2 /w Medium Yates Push/Pull
4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
http://img402.imageshack.us/img402/1251/83962063.jpg
AMD @ testing
X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
08-15-2009, 04:03 AM
#11
True, but the first shot does look suspiciously like Windows XP?
08-15-2009, 04:26 AM
#12
This westmere/gulftown will run on x58 motherboard ? and can you run some Superpi 1M and 32M test please. Thanks
__________________
Intel Core I7 Extreme 975 3,33Ghz@5116Mhz and still testing on air Cpu-z Valid url http://valid.canardpc.com/show_oc.php?id=913577
Geforce 260 GTX
Asus Rampage II Extreme bios 1504 Rev 1.3 on board
Cooling : Noctua NH-U12P SE1366 CPU Fan
Memory 2GB kit Kingston HyperX 1600mhz CL 8-8-8-24@vmem 1.55v
Now ya see here son, this is what we call a dead thread, it died as no one was interested or no one had info for it, or the authore found the info and decided to let the thread die.
So we burried it, gave it a funeral and let it lie in piece.
Now what ya have don here is Necrothreaded it back into the living realm disturbing its grave and its peace! Why boy
why? The poor thread has suffered enough! Let it rest!!
08-15-2009, 04:28 AM
#13
Come'on lets see a real-temp shot on Prime-load with 1.3v.
So many people are asking, and it is the most existing part of gulftown to see how the 32nm-shrink will affect the temp.
__________________
* Gigabyte GA-X58A-UD7 (BIOS F4 02/06)
* Xeon W3520 (#3848A352) @4.51GHZ(215x21) 1.34v 10 Run LinX ...
* Noctua NHD14, NF-P12/NF-P14 push/pull/push
* 3x2GB Corsair XMS3 1600MHZ CL7 (ver. 2.2) @1768MHZ 8-9-8-20 1.61v
* XFX GTX 295 @650/1200/1402
* OCZ Vertex v1.5 30GB + F1 750GB + 512MB RAMDisk
* Corsair HX1000W
* CoolerMaster Cosmos 1000, 5x120
* Samsung 24" 2493HM , Logitech G35 Headset
* W7 RC1, 64bit
* 3DMarks P26259 (PhysX:enable)
08-15-2009, 04:32 AM
#14
如果不是在X58的主機板上 又怎樣可以OVERCLOCKING
REAL TEMP 的溫度跟EVEREST差不多..
08-15-2009, 05:03 AM
#15
請問full load時核心溫度大約多少度﹖
08-15-2009, 05:37 AM
#16
Yea, its X58 mobo, other wise can't overclock.
Real Temp and Everest temp are not too far off each other.
What is temp at full load?
08-15-2009, 08:18 AM
#17
Nda Haha...............各位請原諒我 有太多的測試我不能PO 只能說這是顆好U
08-15-2009, 08:25 AM
#18
RealTemp does not yet correctly support the i9. No one has sent one my way for testing.
Core Temp was just updated. Maybe it can read all 6 cores.
http://www.alcpu.com/CoreTemp/
08-15-2009, 08:31 AM
#19
intel.proart, why do you even bother if you are under NDA? What is your point?
08-15-2009, 08:35 AM
#20
Core Temp 可以正常執行 但是溫度確不準確..........
08-15-2009, 09:19 AM
#21
Will this be running on ASUS Rampage II Extreme ? I wonder if i need new mobo for it..............
__________________
Intel I7 920 4.2GHz 1.3875V (LLC/on ) 24/7 with ScythE Mugen 2
G.Skill F3-16000CL9T-6GB TD @ 1600MHz 6-7-6-18
EVGA GTX295 CO-OP Edition + Galaxy 8800GTS O.C.(PhysX)
2780GB Storage with 32MB Buffer
Creative SupremeFX X-Fi
CoolerMaster Real Power Pro 1000W
Silverstone TJ09s
HP Pavilion w2448hc + BenQ FP93G X
http://valid.canardpc.com/show_oc.php?id=858516 24/7
08-15-2009, 10:33 AM
#22
It is XP. On other screens he just have pictures opened in paint brush (as his default picture viewer i guess  )
[edit]
oh, i see 3rd picture is from win7... dunno, confused.
__________________
i7 920 D0 #3911A318 @ 4GHz| Noctua NH-U12P | Gigabyte EX58-UD5
OCZ 6GB Tripple Channel 1600MHz | eVGA GTX275 FTW | ATCS 840
Seagate Barracuda 1TB RAID0 | Enermax Infiniti 720W
08-16-2009, 03:37 AM
#23
這個問題你應該去問華碩才對.......
08-16-2009, 05:02 AM
#24
Please answer in english we dont understand chinese or what language you speak
__________________
Geforce 260 GTX
08-16-2009, 05:05 AM
#25
I believe Intel Pro art was requesting that you ask ASUS this question. (as in ask ASUS if the Corei9 works on the ASUS Rampage II Extreme)
John
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
