Q 66 ( 2.4 GH - 3.9 GH )
4870 ( def ) 750/900
Q 66 @ 2.4 GH
Q 66 @ 3.2 GH
Q 66 @ 3.4 GH
Q 66 @ 3.8 GH
Q 66 @ 3.9 GH
Q 66 @ 2.4 GH
Q 66 @ 3.2 GH
Q 66 @ 3.4 GH
Q 66 @ 3.8 GH
Q 66 @ 3.9 GH
Q 66 @ 2.4 GH, AVG = 30 FPS
Q 66 @ 3.2 GH, AVG = 30 FPS
Q 66 @ 3.8 GH, AVG = 30 FPS
WELL, any comment ?
Can you compare FarCry 2 ? Never liked Crysis anyway
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro AsusSaaya yupp, I agree
we can draw two possible conclusions regarding your system:
1. vantage is cpu-limited (higher cpu freq -> higher score)
2. crysis is most likely gpu-limited (higher gpu freq -> higher fps)
if you repeat the tests, but vary your gpu frequency, we can see whether our statements are wholly true, or if we need to alter them.
Well I still see Crysis as among the most GPU performance limited games, there are always people telling you CPU will also matter but perhaps it does but for Crossfire HD 4870x2 or GTX 285/295 SLI and alike setups only in that case. For one GPU, it'll be GPU limited for sure.
Of course that doesn't mean you can use some old single core Pentium 4 CPU, but say E8400 @ stock already is prolly enough to be severely GPU limited with a single HD4890 or GTX 275 already.
Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
If all people would share opinions in an objective manner, the world would be a friendlier place
Try disabling two cores on a QUAD and see Crysis/Far Cry/FSX (yes, FSX)/Whatever perform the same. Not valid for benchmarks obviously. I did that a while back, and guess what, i'm running with two cores since then: Less power draw, less heat and same performance on what i use it for. I'll enable them when i need them in the future, lol.
ASUS Sabertooth P67B3· nVidia GTX580 1536MB PhysX · Intel Core i7 2600K 4.5GHz · Corsair TX850W · Creative X-Fi Titanium Fatal1ty
8GB GSKill Sniper PC3-16000 7-8-7 · OCZ Agility3 SSD 240GB + Intel 320 SSD 160GB + Samsung F3 2TB + WD 640AAKS 640GB · Corsair 650D · DELL U2711 27"
@ all = thanx 4 u'r comment ! that was my old 4870, i've already sold it, i can't test anything now, now i have only 4890.....![]()
in real gameplay in crysis it becomes more cpu dependent when there are many enemies and physics.
What am I missing?
I have a lowly e5200 that gets 21255 (cpu points) @ 3.5GHz and 29703 @ 4.0 on what appears to be the same benchmark (3d Mark Vantage) My fsb is also lower than yours, @ 1333. My gfx card is a 9800GT so that shouldn't be giving me any advantage either, esp in CPU test...
BLACKOPS mobo., 4 GB Corsair xms3 XMP DDR3 RAM @1333 7-7-7-20, seagate 'cuda v11, 1TB, Q9650 @ 3.7, Megahalems cooler, corsair HX620 PSU, Galaxy 9800 GT. Win 7 HP 64. Intel X25-M G1 80 GB ssd
Just to show what Far Cry 2 results are like, I wrote a short article on the scaling of cores in FC2 using my "normal" gaming settings and then very low settings to negate GPU bottleneck.
"Normal" settings.
"Low" settings.
Source: http://www.xcpus.com/reviews/121-Far...ng-Page-1.aspx
i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
Looks like a waste of power for the increase in performance, specially when you play at 1920x1200 like me.
It makes THAT much difference? I can understand my GPU keeping up with, or marginally beating your 4870 in a nVidia biased bench - Haven't been tracking my GPU scores in vantage, but they are around the 9-10k mark from memory. (core clock @ 667, shader @ 1667, mem. 900[ish]) So the GPU (very strongly) influences CPU score in CPU tests in Vantage? They should call CPU test a "combined" test then...
If it is indeed the power of the green card making such a big difference does it also make gaming twice as good in physX games? Is it possible to have a nVidia card AND a Redeon card (and their drivers) in the same PC and switch between the 2 for different applications/games?
Still a n00b, so please forgive me if my questions seem stupid - I won't learn the answers if I don't ask them. Thx for your patience.![]()
Spork I don't think you understand what he's trying to say: with a nvidia card and physx enabled your gpu calculates the cpu test, not the cpu. Try dsabling physx in the nvidia control panel and run the test again, you'll understand then![]()
Yups, it's clear enough that a game like Crysis is mostly a GPU limited game, From the 3 SS we can see the ave FPS, except for Min FPS it really gets a bit higer for a 3,8 Ghz clock. Could it be that CPU only help to keep the game runs smoother than that of a lower clock ...CMIIW .
@GAUL : See u in your next personel test
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
