Results 1 to 25 of 151
Thread: Project "True 4x4"
Threaded View
    Back from the Dead
    Oct 2007
    Stuttgart, Germany
    Project "True 4x4"
    Hey fellas,
    I am sure everybody remembers AMDs "4x4" marketing paper launch back in the day, where they would have two Dual-Core Athlon FX Processors on a DP mainboard, sort of like what Intel did with SKulltrail a few years later.
    They called it "4x4" because it had 4 cores, but it sucked really bad (mediocre performance, insane cost and extremely high power draw) and few people ever bought one. I always thought that crappy thing didn't deserve the name "4x4", because it was 4 cores but only 2 procs, so what's the second "4" stand for?
    Soo.. I present to you: My first dedicated AMD cruncher in ages, and a true 4x4 rig - 4 CPUs x 4 cores each - 16 real Cores on a single system.
    What's in it, you may ask? Here's the specs.
    CPUs: 4x AMD Opteron 8347 HE (High Efficiency, sort of like LV and ULV Intel Xeons), 1,9Ghz 65nm Quadcore, Codenamed "Barcelona". 55W ACP, 68W TDP, 2MB of L3 made for up to 8-way servers based on the ancient socket F (LGA1207)
    Unfortunately they are not all perfectly matched, despite the seller's promise they would be
    Notice the odd-ball?
    Since they are pretty close in manuf. date and have the same stepping (AAAWB) it should work with no problems.
    Motherboard: Supermicro H8QME-2
    Ram: 4x1GB Kingston DDR2-800 Reg ECC (minimum ram config for 4 CPUs )
    PSU: Enermax Pro82+ 385W
    GFX: onboard crap
    HDD: Savvio 15k.1 2,5" 73GB SAS drive (still got one lying around doing nothing)
    Case: uhm yeah.. no normal case can fit this monster, it's 16x13" SOlution: Sawed-off CS601 mobo tray with PSU-bracket mod known already from the Dual Gainsy thread
    Will it work? I don't know yet... CPU coolers are due to arrive tomorrow.
    Stay tuned
    It works!!!
    Moar pics
    Awesome options for a SM Quad Socket if you ask me. A LOT of ram settings, and even Vcore up to 1,45V (can it be true?). Only HTT ref. clock options missing, but that should be doable by software.
    World Community Grid - come join a great team and help us fight for a better tomorrow![size=1]
