Results 1 to 9 of 9
Thread: Help me Diagnose SSD Raid_0 Array Problem
    Xtreme Addict Jor3lBR's Avatar
    Jul 2007
    Arizona - USA
    Question Help me Diagnose SSD Raid_0 Array Problem
    Hey Guys,
    System: Gigabyte EP45-Extreme / Q9650 / DDR2
    Drives: 3 x Super Talent Ultradrive ME 32GB MLC 1711 Firmware
    Controller: OnBoard Intel ICH10
    OS: Win7 standard RC1 Install -no tweaks-
    Can't seam to find the culprit for this abnormal ssd_Raid_0 problem I'm having, on all the benchmarks my ssd's graphs show inconstant reads/writes (drops suddenly) and the scale lines are all over the place, see pic:
    I've browsed thru many similar benchmark on same type of drives (Vertex and Ultradrive) and they all show a constant line almost unchangeable throughout the entire bench.
    All I can think of:
    - Saturated ICH10? I'm using all 6 ports 3x ssd's 90Gb's in Raid_0 + 2x F1's Raid_0 3TB's + 1x DVDrom/rw
    - I made a small partition on the SSd's for Pagefile (9Gb's)
    //RETIRED-o00o--°(_)°--o00o-OVERCLOCKER//
    Jun 2008
    The Netherlands
    Where the drives unused before you installed W7?
    Also the Pagefile partition is not needed, your better of without it.
    If the drives where already used before i advise you to use hdderase 3.3 to completely wipe the SSD's.
    If you have any questions "how to" please ask.
    » Xeon X3360 @ 3.7 ~ 1.304 VCore
    » TRUE Black ~ Dual GT AP-14
    » Rampage Formula (Bios 902)
    » Corsair Dominator 8500C5D 2x2GB
    » X-Fi Xtreme Gamer Fatality Pro
    » Asus HD5850
    » 80GB X25-M G2 ~ 40GB X25-V ~ 2x WD10EADS (RAID 1)
    » Seasonic X-750
    » Lian Li PC-A05N
    Feb 2009
    Fragmentation looks to be your issue. It's just going to keep getting worse until you update fw or HDD erase.
    Apparently OCZ and Indilinx have collaborated to make a custom Vertex fw that pretty much will keep the drives in as new state.
    Indilinx may post a fw update for the other manufactures but I doubt it will have GC like OCZ's. It may work differently or you may
    have to wait for trim to be enabled both on the drives fw and on your ICH10R.
    Are you Intel's Btch?
    Jul 2007
    Arizona - USA
    Quote Originally Posted by Earzz View Post
    Yes Earzzz they where used elsewhere.
    I'll try that
    Jul 2007
    Arizona - USA
    Quote Originally Posted by Rhys View Post
    I didn't know that fresh Win7 install would be fragmented. I guess because of previous use the Quick Format isn't enough then.
    Yes so I heard about the new firmware, but I'm already using that update (1711), problem is in Raid_0 the tool is not working just yet (Trim).
    I'll try the erase and then install OS.
    Feb 2009
    Quote Originally Posted by Jor3lBR View Post
    Apparently the 1711 Fw other manufactures have is missing the OCZ implemented GC code.
    The more times you install/format the array the more the drives will slow down. Quick format or full format make zero difference, you need to secure erase.
    One option is for you to use ccleaner to delete empty space, this may bring back some performance, but the only way currently for you to get fresh drives is to HDDerase.
    Jul 2007
    Arizona - USA
    Is the secure-erase supposed to be lightning fast?
    I'm getting this message on drive number #2:
    "Factory default maximum address does NOT equal the maximum LBA addres currently set!!!
    Special diagnostic areas, HPA and/or DCO exist on the drive.
    Total sie of these area is: 1213 SECTORS
    DO YOU WANT HDDERASE.EXE TO ERASE THESE SECTORS? (Y/N):
    - what should I do?
    Jul 2007
    Arizona - USA
    After_HDDErase
    I went ahead and pulled the trigger erasing that info on the #2 drive (the newer ver. of them, I don't know if it will have any issues in the future), but the numbers after the HDDErase 3.3 got much better and linear:
    Normal Windows 7 RTM install on single partition Super Talent Ultradrive ME 32GB x 3.
    Do you guys think I should ALIGN the drives after the HDDErase to gain some more speed or there is no need to do that anymore?
    Jun 2008
    The Netherlands
    Aligment is fine with W7/Vista install, and the speed is almost as high as the ICH10 can give so trying to finetune it is not really needed.
    Extra info: HD Tune Pro 3.50 will give you better readings then the version your using now.
    » Asus HD5850
    » Seasonic X-750
    » Lian Li PC-A05N
