wow, it seems anything is fair game when it comes to unlocking with AMD.
__________________
Particle's First Rule of Online Technical Discussion:
As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
Rule 1A:
Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
Rule 2:
When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
Rule 2A:
When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
is this only for an ES processors? coz there are many X2 240 out there, yet no one report it being unlocked to opteron (or Black Edition CPU fo that matters)
I understand why cores or cache can be unlocked, but multipliers?
Opterons aren't unlocked to begin with. .
This could mean that it either is because of that specific board, which I highly doubt, or otherwise it should work on EVERY A2!
Together with a cheap 785G it would be a great combo!
Well, I may have to buy a 240 just to try this, because it seems like a no go on my 245. Not sure if I'm limited by the 770/710 NB/SB chipsets, or the processor, but the proc. seems like a better idea than a new board.
Tried ACC on both settings, hybrid and normal, on auto and with various different combos of manual settings, both per core and for all cores. I'll be happy to test any settings that may work.
Running the F2c BIOS for my GA-MA770T-UD3P right now, BTW. Flashed to F2 to give them a try as well.
This doesn't sound like a yield-issue so it should work for every single Athlon II x2 240 (245/250???). If it does work I am getting one this instant ^^
__________________ Nvidia GT300 yields are under 2% CPU: Phenom II X2 550BE @ X4 B50 Clock: 3600MHz 1.4v 24/7 crunching stable Memory: 2x2GB 1333MHz 6-6-6-18-24-1T Motherboard: MSI 790FX-GD70 GPU: ASUS HD5850 1GB AMD Forum
