So I've had the res installed for about 1.5 weeks now. It offered an improvement over my previous single loop setup. But after 3 days of 24/7 folding, I come home last night to find red coolant at the bottom of my case.
So I shut everything down, and determine that the leak is coming from the res itself. Pumps were mounted correctly, and there was no leakage coming from the fittings.
So I washed out the res and after doing so, I still saw red coolant where the walls are attached, and also behind the front plate:
Is it possible that pump vibration could have caused this? After sending XSPC an email they responded back requesting pictures, and I'm still waiting to hear back from P-PCs where I bought it.
I hope the new one doesn't have the same issue...
If you really wanted to feel safe, you could always cover the top of the fan controller in some manner.
