When the task manager has to show two levels of cpu graphs, you know you've got something good under the hood.
So will the Westmeres run at lower clock speeds to accommodate the TDP requirement of 135W? Will 32nm get it all the way there? Or will 2.4ghz just have to be the new 2.66?
With this kind of stock clocks I hope they at least treat it with an extensive turbo mode. Something like 2 bins per core-not-used would be satisfactory.
It is an ES chip, so for all we know retail chips might have higher stock clocks.
__________________
"When in doubt, C-4!" -- Jamie Hyneman
Silverstone TJ-09 Case | Seasonic X-750 PSU | Intel Core i5 750 CPU | ASUS P7P55D PRO Mobo | OCZ 4GB DDR3 RAM | ATI Radeon 5850 GPU | Intel X-25M 80GB SSD | WD 2TB HDD | Windows 7 x64 | NEC EA23WMi 23" Monitor |Auzentech X-Fi Forte Soundcard | Creative T3 2.1 Speakers | AudioTechnica AD900 Headphone |
Exactly, remember how low clocked the first Bloomfield ES were? But even so I think we might see up to 2.93 (launch) or 3.06GHz (slightly later) but beyond that I'd be sceptical or the die shrink has have to do wonders.
Very nice, seems like it might be some tweaks in there other than 2 extra cores, guess it's for making up for the slightly reduced clock speeds in apps that cannot utilize 4+ cores.
Hopefully the supporting boards for these CPUs have better OC options than my Supermicro.
__________________ Particle's First Rule of Online Technical Discussion:
As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
Rule 1A:
Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
Rule 2:
When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
Rule 2A:
When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
Rule 3:
When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
Random Tip o' the Whatever
When you are looking for a quality soldering iron, pay the premium and get something like a Weller WESD51 (or better yet a Hakko 937). It's worth it.
