So I am attempting to power some 120mm PWM fans that work really well in daisy chains from my graphics card (xfx 4890 xxx edition):
http://www.sidewindercomputers.com/arcoafpwm12c.html
http://www.arctic-cooling.com/catalo..._48_68&mID=144
I found on another forum some part numbers needed to put together most of the adapter, but am not quite there.
So far, I have found the housing and female contacts that connect to the graphics card PWM fan header:
what im looking for are the male pin contacts (most likely crimp style contacts) and a shrouded male PWM in-line housing connector, as shown in the photo below (circled in red):
If anyone has any input/help I would really appreciate it.
part numbers found so far on www.digikey.com are:
female GPU PWM housing P/N: 455-1164-ND
female contact connectors P/N: 455-1127-1-ND
