Hi guyshere are some results with RE X48 and 2x2GB OCZ3B2000LV2G
open setup:
Rampage Extreme + 0403 BIOS
2x2GB OCZ3B2000LV2G 7-8-7-20 (3x2GB kit)
E8600 / NH-U12P
RE stock air cooling + fans
BIOS 0403 common settings for all runs:
NB GTL Auto
CPU, NB, DRAM skews Auto
NBDDR/A+B DDR vREF Auto
except > 510fsb / 1:2 : NB skew del 300 (CPU skew del 200) for POST @ 510fsb or higher.
Vista 64
test basic board stability + vNB
450x9 / 1:2 / 400 strap / CL7 / Clocktwister auto / tRD6 / vNB 1.40 set / vDIMM 1.51 set
475x9 / 1:2 / 400 strap / CL7 / Clocktwister auto / tRD6 / vNB 1.51 set / vDIMM 1.617 set
also same as 333 strap / Clocktwister strong / tRD6
XP32 SP2
Everest / 500fsb / 1:2
all 500fsb result from boot @ 500fsb = lower Read versus boot < 500fsb.
7-7-6-20 / tRFC 60 / 333 strap / clocktwister moderate / tRD 7
7-7-6-20 / tRFC 60 / 333 strap / clocktwister moderate / tRD 7 + CHA pull-in 1+2
(HyperPi 32M vNB = 1.51V set or less)
7-7-6-20 / tRFC 60 / 333 strap / clocktwister strong / tRD 7
7-7-6-20 / tRFC 60 / 333 strap / clocktwister strong / tRD 7 + CHA pull-in 1+2
(HyperPi 32M min vNB = 1.59V set)
7-7-6-20 / tRFC 60 / 266 strap / clocktwister strong / tRD 6
(SuperPi 32M min vNB = 1.69V set)
with CL8
8-7-6-21 / tRFC 60 / 200 strap / clocktwister strong / tRD 6
CL7 booting < 500fsb
so far, 490fsb is ~ maximum for 32M with 2x2 + 'full' bandwidth.
490x9 / 7-7-6-20 / tRFC 60 / 266 strap / clocktwister strong / tRD 6
495x9 / 7-7-6-20 / tRFC 60 / 266 strap / clocktwister strong / tRD 6
(Everest min vNB = 1.72V set)
495x9 / 7-7-5-20 / tRFC 55 / 266 strap / clocktwister strong / tRD 6
CL7 + CL8 HyperPi / 1:2 CL8 SuperPi 'max' clock / 1:2 CL8 validation
CL7
500x9 / 1:2 / 333 strap / CT strong / tRD 7 + CHA pull-in 1+2 / boot 500fsb
5:8 shows lower limit for tRD 8 with 2x2GB than 2x1GB, 575-580fsb/5:8 is the max so far with 2x2.
600x7.5 / 5:8 / 333 strap / CT moderate / tRD 9
CL8 - booting > 500fsb for stability (+ low bandwidth)
(NB skew from auto to 300 for POST @ 510fsb/CL8)
515x7.5 / 1:2 / 333 strap / CT moderate / tRD 7 / boot 510fsb
520x7.5 / 1:2 / 333 strap / CT moderate / tRD 7 / boot 510fsb
525x7.5 / 1:2 / 333 strap / CT moderate / tRD 7 / boot 510fsb
533x7.5 / 1:2 / 333 strap / CT Lighter / tRD 8 / boot 525fsb
2x2 Elpida : SPi 32M efficiency
450x10 / 1:2 / 400 strap / CT Auto / tRD 6 / maxmem 680 + copy waza
500x8 / 1:2 / 266 strap / CT strong / tRD 6 / boot 500fsb / maxmem 680 + copy waza
500x9 / 1:2 / 266 strap / CT strong / tRD 6 / maxmem 680 + copy waza
600x7.5 / 5:8 / 333 strap / CT moderate / tRD 9 no pull-in / maxmem 680 + copy waza
with tRD 8
571x7 / 5:8 / 333 strap / CT moderate / tRD 8 / maxmem 680 + copy waza
564x7 / 5:8 / 333 strap / CT moderate / tRD 8 / maxmem 680 + copy waza
Loop 25 finished..
