Results 1 to 12 of 12
Thread: 247 bclk on Bloodrage PCI-E hardmodded
    all outta gum
    Dec 2006
    Poland
    Hi I'd like to share another high bclk with recently discovered Bloodrage mod:
    Foxconn Bloodrage with PCI-E frequency mod
    Xeon W3520 retail batch #3844A704 coldbug at -105°C
    Corsair Dominator GT 1866
    Kingpin's Dragon F1 EE + LN2
    Bios G25
    Vcore = 1.45-1.52 V
    Max bclk = 5070 MHz - best non-Classified W3520 frequency
    Max clock = 247 MHz
    Max SuperPi 16M = 3 : 17 . 687 at 241.4 bclk
    It was 32M stable as well, and we had screenshots to prove it, but they got lost in a hard drive failure
    Thanks to The_Fox for his excellent tips here and here, r1ch and Lord Trident for discovering the mod. Oh Foxconn, why didn't you do it right from the start?
    -Team PCLab.pl
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    why is your qpi link only at 2897? i wonder is that some sort of a bug on the board/cpu-z since it should be wayy over 4000 at those kinds of speeds
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    all outta gum
    Dec 2006
    Poland
    We disabled QPI Fast Mode - it makes QPI multi 12x but hurts 3d performance.
    www.teampclab.pl
    Test bench: empty
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    Quote Originally Posted by xoqolatl View Post
    ohhh i see, thanks for the explanation
    Feb 2009
    Athens - Hellas
    Awesome bclk frequency
    After this mod for high bclk, the mobo is very competitive
    Mar 2005
    Great clocks xoqolatl, glad to see my settings helped you
    BTW, have you tried to fiddle with the settings and see if you can get some higher clock ?
    It is most probably using different bClk as the i7 Doesn't support x12 multy for QPI.
    According to CPU-Z its 2/3 the "Real" bClk but Massman and Saaya allege that its 1/4 of the Real bClk and that CPU-Z is inaccurate, thus the main reason to hurt 3D performance.
    Can you test 3D Performance with QPI Slow mode and see if it really hurts 3D benches and by how much ?
    PC: Intel Core i7 920 D0 | Kingston Hyperx T1 6GB 2000Mhz 8-8-8 RAM | Foxconn Bloodrage GTI | Sapphire 4870X2 | Perc 5/i - WD 640AAKSx4 RAID0 | Asus 2014L1T | Dell 2407WFP | Lian Li G70 Silver Watercooled
    WaterCooling: Q² Project by The-Fox
    CPU Loop: Swiftech Apogee GTZ | Feser X-Changer 480 | Swiftech MCP655 Vario w/ DetroitAC top | EK Multioption RES 250 Rev.2 | Tygon R3603 1/2" | YL D12SL@1350RPM x4
    GPU Loop: EK-FC4870 X2 Nickel | Swiftech MCR320 | Swiftech MCP655 Vario w/DetroitAC top | EK Multioption RES 150 Rev.2 | Tygon R3603 1/2" | YL D12SL@1350RPM x3
    all outta gum
    Dec 2006
    Poland
    I did run 3dm03 on slow QPI once, but it was so slow I didn't even bother to save a screenshot.
    Your settings were very good, but I had to change:
    PCI-E to 114 or 115 MHz
    QPI CPU Latency to 80-90
    Vpll to 1.86 V
    CPU clock amplitude to 0.9 V
    I also fiddled with CPU clock skew but I don't know if that helped.
    www.teampclab.pl
    Test bench: empty
    Aug 2006
    Fox,
    with slow mode, my framerate goes down my about 66% so yes, it's a huge factor in 3D.
    Mar 2005
    Vpll to 1.86 V
    Interesting, I actually find that Clock Skew made things worse for me, I played with it for a while, on H20 and cold, but behavior was the same .
    The PCI-E didn't seem to matter, 110-120 is all the same I think
    Maybe on my next session I would try some of your settings like Vpll, CPU Clock Amplitude and QPI CPU Latency.
    Quote Originally Posted by roller11 View Post
    Fox,
    Is that on the EVGA Classified ?
    I kind of started to think that the BR is doing the QPI SLow mode differently but it is probably all the same I guess.
    Aug 2006
    Fox,
    slow mode tried on both the Classified and the giga x58 UD5, same result.
    xoqolatl,
    q about your max CPU clock...you show your max is 5070 and that's with a 16M superpi. Normally a chip can do a higher Max CPU clock running, say, CPUZ than superpi. This implies that you have some kind of wall at 5070 Mhz, is this the case?
    all outta gum
    Dec 2006
    Poland
    I had a validation at 5103 (243x21) but the file got corrupted.
    www.teampclab.pl
    Test bench: empty
    Aug 2006
    So it appears that there is some kind of wall at 5070 even with the hard mod.
