Due to large overflowing market with excelent CPUs, i decided to throm myself in action once again and use my termophysics knowlegde to make something that will parry their hunger for lower and more stable temperatures. I named this POT by a magnificent game named Requiem
This POT isn't in heavy weight category, which you can see from its weight of only 1400g without alu part. But, this POT isn't ment to be heavy weighter, and is modified to allow us to reach highest max clock and best SPi scores
As you can see, POT is made two different materials, Cu and Alu. I didnt see much usage of full copper POT becouse ln2 oxidies only 60mm from base. Angle from the base to the first curve of the POT is usually 45 degree. But by my calculations, i made two curves. Angle to first curve is indeed 45 degree for faster temperature flow, but the angle to second curve is 50 degree for better disspation on the walls of the POT. You may see the modification on the photos below.
As i mentioned, the "intestines" of the POT is designed for reaching best max clock and SPi scores. Becouse of the problem we all know named cold bug, this pot has less weight and increased allover size. Details about "carvings", you can see on photos below
Special thanx to animaN for polishing this pot till pefection
And i've got one AMD TWKR in my hands, that cant wait till this weekend to be frosted xD So expect some nice scores
More info and photos on http://www.pcaxe.com/forum
Best regards,
warmaster and PCAxe team![]()
