Results 1 to 19 of 19
Thread: Typhoon III & D5 -or- XSPC dual DDC pump res?
Threaded View
    Jan 2009
    Torrance, CA
    Question Typhoon III & D5 -or- XSPC dual DDC pump res?
    Been following the T3 thread, but was wondering how the T3 and a D5 pump might compare to the XSPC dual DDC pump reservoir? Both of these pump/res units allow for 2 loops, but would the dual DDCs give you higher pressure or more flow in a 2 loop setup?
    I have the option to use either, but let me explain how my 2 loop setup would be. Loop1 would have a 1080 rad that would be used strictly for an OC'd i7 920 D0 CPU. And loop2 with a RX360 rad that would be used for dual GTX295 blocks and NB and VReg blocks.
    Both the T3 and XSPC setups use a single res for the dual loops, but would one give better performance over the other for the above setup?
    This is the XSPC res I'm referring to:
    the Borg Cube:
    Case - Lian Li PC-343B
    Mobo - EVGA X58 Classified (759)
    CPU - i7 920 (D0 stepping), watercooled w/Enzotech Luna Rev.A block
    RAM - Corsair Dominator GT 2000 (8-8-8-24) w/fan
    GPU - EVGA GTX295 quad-SLI, water cooled w/Koolance NX295 blocks
    PSU - Corsair HX1000
    O/S - Windows 7 RC build 7127
