Well, i got a good X2 550 with capacity to run 4 cores ,but Ive tried to unlock the "extra" cores on TA790GX A3+ but it seems impossible
so I asked for a friend of mine a great bios developer to make a magical bios for TA790GX A3+ and......
He did
i will show you exactly how you can do the same.
the first ever step-by-step is how to get the modded bios
grab this file here
http://www.4shared.com/file/11588524.../78DAA616.html
Set your system back to stock prior to flashing and after updating bios to the new one you just need to follow this steps ,under the CPU Tuning option
HT link @ 1.6GHz
ACC @ all cores
Value(all cores) @ -2%
you must set the HT link @ 1.6GHz, if you don't, you'll see unexpected results
And its work of course
you would like to try it at your own risk
Junior
