Hi guys!!
This is my first "review" post at Xtremesystems, so be patient
I have just received 2 kits of brand new Trident DDR2 modules. These are the 8500's ones, so I hope to get 1200mhz out of them...
I got them, because I received a refund for my previous D9 sticks. Two of them dead, and they sent me a refund to buy another ones. I was between the PC8800PIs and these brand new trident.
There is a mistake on the HS. You can read "DDR3 Trident", but these are DDR2 sticks... First, I thought... "they sent me another kits... WTF", but when I took the box, I saw the P/N... and it was correct...
Another pics of the sticks:
It seems very difficult to take off the heatspreader, so I will find out what ICs do they have only by testing them.
Specifications from GSkill site:
CAS_Latency: 5-5-5-15
Capacity: 4GB (2GB x 2)
Speed: DDR2-1066 (PC2-8500)
Test_Voltage: 1.8 Volts
Registered/Unbuffered: Unbuffered
Error_Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Test setup:
ASUS Rampage Formula x48
Q6600 G0
4 x 2Gb GSkill PC8500 Trident LV
2 x ATI Radeon 4870 512Mb CF
2 x 500 Gb RAID 0 WD
Windows Vista x64 SP1
I have only one kit installed at this moment, and I will start with testing right now.
After installing them, I just booted and configured default timmings, speed & voltage. Also, I pulled down the CPU to start with testing.
SPD information:
Wait until I finish the tests.
(EDITING POST... WAIT FOR A WHILE)
RGDS!
