Results 1 to 16 of 16
Thread: 3.4ghz HT link on Crosshair III (thats 6.8ghz effective)
    Aug 2006
    more pics coming up still benching right now
    3.5ghz
    3.45ghz (6.9ghz effective) stable
    Aug 2004
    Germany
    Congratulations. Great HT-Link.
    What voltage-setting do you use for 3+ ghz?
    Hopefully I can get my Crosshair III back to life and have some fun with it.
    Aug 2006
    1.45v HT and 1.65v cpu
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Use 3D03 to gauge performance increases with HTLink, 3D01 blows on AMD. Impressive HTLink speeds
    Aug 2004
    Germany
    Quote Originally Posted by cdawall View Post
    Thanks for information.
    My board is back in life, seems that a flaky bios-chip caused my issue.
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by [XC] gomeler View Post
    I doubt there are any speed improvements, unless he were running dual or triple graphics cards are really high frequencies.
    Formerly XIP, now just P.
    Aug 2006
    Quote Originally Posted by EnJoY View Post
    dual 48X0X2's shortly my 4870X2 is at rma land
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    wow 350Bus for AMD is high!!!
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    May 2005
    Boulder, Colorado
    Well yeah, why else would you want high HTT clocks
    Feb 2008
    Italy
    what's HT link? [I'm nooob with amd ] Is same rated fsb for intel?
    E8500@4.4GHz (du 500x8 1.20v)|Noctua NH-U12F|2GB Tg Xtreem PC9600@720MHz 5-5-5-15-606MHz 4-4-4-12-475MHz 3-3-3-9|Gigabyte Ga-Ep45-Ud3r 1.1|Radeon HD4870 512MB@250/450MHz 1.083v|WD6401AALS@Ich10r|Corsair HX750W|Win Vista x64 SP2+Win 2K3 x32|Asus VH226H|HAF932|E4400@3.98Ghz oc ~99%|Ciao Max 24/07/2008
    Jun 2008
    Awesome work
    I did 355FSB on a 939 mobo, is that good?
    Aug 2006
    Quote Originally Posted by fatguy1992 View Post
    Awesome work
    yep it is i have gone higher but not with this board BIOS issues....
    NV780A got higher up
    Mar 2008
    I can bench stable with HT 3250MHz on X4 955, not too far, next time I will bench with HT higher that
    Y!M: Leonarderman
    Clan: Duck Team VN
    I am ATI Fanboy - Not AMD
    Location Location Location...................
    Thần tượng: KingTea Super Bựa
    May 2009
    Scotland
    God damn!!!
    That is insane overclocking!!
    I wish that I had built a PII rig instead of my Core i7... I used to only ever build systems with AMD chips, and I never had any trouble with them, but this time I decided to move over to Intel because of all the stuff I had read about them, so I went ahead and built a rig using the Gigabyte EX58 UD5, and a D0 Stepping Core i7 920, and I have had nothing but problems with it from day 1...
    I can't even get the system stable @ stock frequency, and I have tried absolutely every possible hardware config with all the gear I have lying around the house, and each setup give me the exact same results...
    I bought another set of RAM and new PSU for testing, I have tried 3 GFX cards, 3 SATAII HDD's, built the system outside the case with bare minimum connected, and again I get the exact same problems...
    I RMA'd the processor, and the motherboard, and they have both been tested and have been found not faulty!!!
    And the other hardware has been tested on another system and they are all working perfectly... I personally thought it was the mobo that was giving me my problems, but the guys I bought it from say that it is fine... so I really don't know what else to do...
    I should have just stuck with AMD instead of switching over to Intel.....
    What are you using to cool your CP?U??
    Aug 2006
    Quote Originally Posted by BLunTSmoKeR View Post
    God damn!!!
    my OP was done on DICE the cpu can clock alot higher than that but it was done to push the HT link speed.
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    whau, nice cdawall, brutal HT clock . How is diferent HT 2000 and HT 3000MHz in benchmarks?
    ROG Power PCs - Intel and AMD
