Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 115
Thread: Worst Xeon W3520 ever...
    2.4C killer
    May 2003
    San Diego, CA
    So I bought a Xeon off Ebay was supposed to be a batch 3848A something but instead its a 3844A704.
    The board I got is good, seems to do 225 BCLK without even trying but I can't even get it to run 4ghz HT stable. 1.25v is not enough and it errors, 1.3v it gets up to 95c...so I lose again. I have a sunbeam tech core contact freezer was supposed to be a really good heatsink! I even rotated the heatsink and it still gets hot, and the base is lapped and touching the IHS good. Is there something I'm missing here? This is the first i7 I have had, or did I get a screwed CPU...?
    Nov 2004
    Europe/Austria
    What are your temps with 1,25v ? And you meen Vcore right? I know most W3520īs need less, but i need about 1,38 to get 4,2 stable with HT (on my 920er). Maybe you should think about your cooling
    System #1:
    i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6X58 Premium, 3x2048 Corsair Dominator 2000CL7, Sapphire 5970 @ stock, Corsair HX1000, 1xOCZ Vertex2 120GB, 3x1TB WD Green
    Cooled by:
    Loop 1: Watercool HK rev 3.0, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
    Loop 2: EK 5970 Nickle, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
    Loop 3: EK Asus NB/SB, Mips Asus Mosfet 1 + 2, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.2 /w Phobya Fans @ 5V Pull
    4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
    http://img402.imageshack.us/img402/1251/83962063.jpg
    AMD @ testing
    X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
    Jun 2008
    From what I am seeing that hs is alright, do you have the fan on high speed? I noticed while reading a review that it has low/high speeds.
    Quote Originally Posted by Movieman View Post
    I don't care, I'm running out of popcorn waiting for the results..
    2.4C killer
    May 2003
    San Diego, CA
    Quote Originally Posted by Paxi View Post
    With HT on and 4ghz 1.25 it will crash on prime withing 20 seconds, but it gets up to like 85c. Kinda bummed sold my Core 2 quad for this was expecting atleast 4.2ghz stable with HT but cant even get 4 =(
    Doesn't seem like my temps should be nearly this high either, some sites said this cooler was even better then the TRUE
    Aug 2008
    Hong Kong
    I'll say TEST THE CPU USING TURBO MODE 191 BCLK AND USE PRIME 95 SMALL FFTS (NOT LARGE NOR BLEND)
    Intel XEON X5650 B1 Retail x2 3012A692
    EVGA Classified SR-2 BIOS A50
    Crucial Ballistix PC3-1333 CL6 D9GTR 2G Kit (Active)
    Crucial Ballistix PC3-2000 CL9 D9GTS 2G Kit (Active)
    Thermaltake V1R (in use, without heatpipe)
    Cooler Master Silent Pro M 1000W PSU
    Galaxy GTX 275 (Digital PWM)
    WD 10EALX
    Overclock:
    Currently running @ Default.
    Intel i7-2600K (L041C107, L048B284, L050A853)
    Asus P8P67 Pro BIOS 1305
    WC setup EK Supreme HF GOLD Edition powered by BlackICE GTX 480
    G.Skill 12800CL7D-4GBECO x2 packs
    WD 10EALX
    Intel X25-M 120GB
    MSI NGTX560Ti Twin Frozer SLI
    Overclock:
    40x100 4Ghz 1.15v [Currently testing L048B284]
    Dec 2007
    San Francisco
    That sound much too hot to me
    e8600: 6261 mhz (LN2)
    e8500: 5830 mhz (dice)
    Quote Originally Posted by xaxis View Post
    It's really unfeasible, unpractical, and for all intensive purposes... SHOULD NONE THE LESS BE ATTEMPTED!
    2.4C killer
    May 2003
    San Diego, CA
    Quote Originally Posted by ci2kla View Post
    Turbo mode on this board and Xeon does everything the complete opposite, it slows it down...
    Jun 2008
    Have you checked to make sure the fan is running at max speed? Did you try a re-mount of the hs yet?
    Aug 2008
    Hong Kong
    Quote Originally Posted by Peen View Post
    I think you should test with a low ram multi, low uncore first...
    200*20 should be okay but you have to make sure that bclk isn't holding you back
    WD 10EALX
    Overclock:
    WD 10EALX
    Intel X25-M 120GB
    Overclock:
    2.4C killer
    May 2003
    San Diego, CA
    Quote Originally Posted by hellcamino View Post
    Yep, and yep.
    And the thing idles at 35-38c but jumps up the 85c in 2 seconds. I think it's got a bad sensor, wouldn't be the first chip thats done this to me. I had a E8400 that went to 95c under same cooler, but my Q9550 at same speed never went about 65c.
    Jun 2008
    Yep, and yep.
    That doesn't sound promising...Have you forced the cpu to throttle yet? If you peg it at 100c it should throttle down to cool, it would certainly tell you if the sensors are accurate or not.
    2.4C killer
    May 2003
    San Diego, CA
    Well it would crash a few degree before getting to throttle temp.
    So I just tried 20x200 w/ HT Uncore 2400 something, RAM was 1260, Vcore 1.23v, QPI 1.35v, PLL 1.85. Prime95 small FFT crashed within 30 seconds.
    Xtreme Mentor
    Feb 2007
    Oxford, England
    bad chip... thats all :/
    "Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
    //James
    Jun 2008
    Small fft crashing that quicks sounds like not enough vcore, uncore is too low also raise it to at minimum double your ram speed.
    Aug 2008
    Hong Kong
    Test it using 15 multi and see if you will crash. IF yes then your bclk isn't stable at all
    WD 10EALX
    Overclock:
    WD 10EALX
    Intel X25-M 120GB
    Overclock:
    2.4C killer
    May 2003
    San Diego, CA
    My uncore is twice my RAM speed
    and I have tried 15 multi thats how i concluded it was stable up to like 230bclk.
    Back from the Dead
    Oct 2007
    Stuttgart, Germany
    Usually smallFFT NEVER crashes on i7, it's not even remotely stressful on that arch, so it must be really really unstable.
    I have an ultra low vid w3520 that does LinX at 4Ghz with 1,17V but also goes over 90C using a Scythe Zipang... those things need water really.
    World Community Grid - come join a great team and help us fight for a better tomorrow![size=1]
  18. #18
    2.4C killer
    May 2003
    San Diego, CA
    Man, priming smallFFT 1.288vcore 4ghz HT and running 94c....
    This chip is a POS, shoulda just kept my Core 2 Quad
  19. #19
    Jun 2008
    Those are some ugly temps there!
  20. #20
    Xtreme Cruncher Russ_64's Avatar
    Aug 2005
    London, UK
    Bad luck mate, hope you didn't pay top $$ for that chip. FleaBay is not the place I would buy my goodies ......... sucks
    Asus Maximus VIII Ranger Z170 : Core i5-6600K : EVGA RTX2080 XC : 16Gb Corsair Vengeance DDR4-3200 : 256Gb Crucial MX500 : Corsair H100i : PCP&C 750w 60A : CM Cosmos S : Windows 10 x64
    Asus Z8NA-D6 : Dual Xeon E5645 : 24Gb DDR3-1333 ECC : MSI GTX470 : 120Gb Samsung EVO 840 : 1TB HDD : PCP&C 750w 60A : CM Stacker : DD MC-TDX, EK-FC470, RX240+RX120, D5 X-Top, BayRes : VMware ESXi 6.7.0 - VM's - WCG crunchers x 5 (Ubuntu 18.04 LTS), Mint 19, Windows 10 Insider Preview
    Sophos XG 17.5.3 running on GA-Z97-Wifi : Core i3 : 8Gb DDR3-1600 : 120Gb SSD : Corsair H80
    BenQ GW2765, Aten 4-port KVM, Asustor AS5002 4Tb NAS, Belkin 1500va UPS, Sky Fibre Max 80/20Mbps
  21. #21
    Aug 2008
    Hong Kong
    Maybe... and get a new one?
    WD 10EALX
    Overclock:
    WD 10EALX
    Intel X25-M 120GB
    Overclock:
  22. #22
    PI in the face
    Nov 2008
    needs better cooling is all
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
  23. #23
    Nov 2007
    Toronto, Canada
    Quote Originally Posted by Bobbylite View Post
    QFT.
    The Sunbeam wasn't even engineered to cope with i7's so replacing that with something a bit more up-to-the-task will make a huge difference.
    Water is the new air with these bad boys.
    GB 790XTA UD4
    GSkill Pi Black 2000 Cas9
    ASUS 4870
    Enermax Revolution 1050+
    http://www.heatware.com/eval.php?id=67661
  24. #24
    2.4C killer
    May 2003
    San Diego, CA
    Yeah I wish I had my old chiller. I changed the ram speed which auto changed the uncore to 2400 or so. It seemed to drop the temps 5-10c and actually passed OCCT auto 1hr. Still needs alot of volts and runs hot.
    I will buy water again someday!
  25. #25
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    It sounds to me like your cooling is an issue and also it may be the chip.
    check for flatness on the IHS and also on the cooler base.
    Try another HS like a TRUE if you can get one from a buddy to borrow.
    Your really running hot and in the 80's to me is unacceptable.
    Good Luck!
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
