Going into tease mode, Wallace Santos, the CEO of custom PC builder Maingear, has blogged about a 'special' AMD CPU called the Phenom II TWKR Black Edition. Seen below, the quad-core part is supposed to be able to overclock higher than the Phenom II X4 955 BE
I wonder what the stock speed is, and is this meant to perform close to Core i7 or what?
__________________
PC 1: Intel Core i7 950 | 12GB DDR3 G.Skill Ripjaws | Gigabyte 1536 GTX 480 | AeroCool V12-1000 80+ ATX Power Supply | 20 LG SATA DVD+/- RW | LG BluRay/HD DVD Combo Drive| 5.1 speakers | 32" LG HDTV at 1920x1080 1080p | Gigabyte GA-X58A-UD7 | 1x 500 SATA II Western Digital Hard Drive | 1x 1TB Western Digital Hard Drive | Windows 7 x64 Ultimate RTM
PC 2: AMD Phenom II X6 1090T | Gigabyte GA-890FXA-UD7 | 4GB G.Skill DDR3 1600Mhz | Gigabyte NVIDIA GeForce 896MB 275 GTX | 22" Acer LCD | 700 watt power supply | LG BluRay/HD DVD Combo Drive | 500GB Western Digital hard drive | Windows 7 x64 Ultimate
a desktop product is unlikely sever cpu price is a lot higher. more profit there for AMD.
it would be very low clock 6 core BE wattage of 140 watts.
this says it can past 7ghz.
Well, our Phenom II's are nothing but the exact same chips as the server ones - except ours only has 1 HyperTransportBus enabled. Istanbul migrating could very well be a reality.
Istanbul currently doesn't support DDR3 -Officially- as it's not a priority for AMD and its customers atm, which would make a Dekstop Istanbul going in the wrong direction to become a AM2+ CPU hmm.
But I think the same as you, that it's cherrypicked Deneb.
__________________ Nvidia GT300 yields are under 2% CPU: Phenom II X2 550BE @ X4 B50 Clock: 3600MHz 1.4v 24/7 crunching stable Memory: 2x2GB 1333MHz 6-6-6-18-24-1T Motherboard: MSI 790FX-GD70 GPU: ASUS HD5850 1GB AMD Forum
__________________ PC1 AMD Phenom II x6 1090T BE @4300 MHz 2800 MHz NB 1.479V 24/7, ASUS Crosshair IV Formula, 2x2GB A-DAta 2000x 1600MHz+ cl7, Xigmatek 1283DK+ultra Kaze, ASUS HD5770 1GB DDR5, Seasonic 650W, CM HAF PC2: AMD Phenom II x4 965 BE C3 3.4GHz@3950MHz with 1.44V or at 4032MHZ+2828 MHz NB with 1.52-1.533V stable, CPU3: AMD Phenom II X4 955 BE 3.2@3.895GHz+2665 MHz NB 1.485V with new BIOS, or 3.915GHz 2678MHz NB 1.5V = 24/7 and lower voltage (max 4264Hz with 1.485V and 4386 MHz 1.55V) CM Hyper 212, Gigabyte MA790X-UD4 F3 bios, 2x2GB Kingston Hyper X 1066MHz cl 5, 2x320GB HDD,ASUS HD5770 1024MB, saphire HD3870 512MB (1950pro 256Mb 610/1480MHz),Seasonic 500W Aspire X Cruiser, A4tech keyboard+mouse Razer deathadder ~ 4386MHz AIR x4 955
4570 MHz AIR x4 965
AMD X6 1090T BE on the way...next chip x4 960T Zosma
i think, this is not six core, six core coming at 1Q 2010 and not top clocks! Because TDP...This is some diferent. Maybe in new revision C3.
4570 MHz AIR x4 965
Do you need to turn the lights on and off thirteen times before you enter a room?
I agree though, Why put shiny new tech in a old board that will hold it back? I have never upgraded just a cpu.
True, I would love it if AMD got some decent ROG boards from Asus.
Although my next build will deffnently be a mATX or iATX if AMD ever get some decent boards that can take a good graphics card.
On a note about the lights on and off. Thank goodness not! Although I measure ( With an actual scale ) the amout of meat and carbs I get in :O I also need something green on my plate at all times. All times!
