Results 1 to 16 of 16
Thread: DFI X48 LT T2R - 8GB of ram?
    May 2008
    I want to upgrade to 8gb (4 x 2GB) of ram. I can't add in anymore OCZ Flex ram as the heatsinks are too big. I am currently water cooling my CPU and NB.
    What is realistically the fastest 4 x 2GB of ram the X48 NB can handle? I was hoping to reach 1185mhz, but I don't know if it's possible.
    There's no point spending the extra money on a high speed kit, if Im limited my the NB. For video editing, I would prefer more ram over faster ram if it comes down to that.
    Mobo: DFI LP X48 LT T2R | Bios 12/24 | XSPC Delta Chipset
    CPU: Intel Q9550 E0 @ 3.6ghz (424 x 8.5) | Swiftech GTZ
    Ram: OCZ PC2-9200 4GB (2 x 2GB) Flex II @ 1121mhz 5-5-5-15 2T
    GC: HIS 5870 @ 900/1300 - Eyefinity
    SC: Auzentech Forte 7.1
    Monitors 3 x DGM 24" L2442W-VA LCD
    HD's: 3 x WD 150GB Raptor (Raid 0) & 2 x Samsung F3 1TB (Raid 1)
    Optical Drives: 2 x NEC DVD Writers
    PSU: Enermax Modu82+ 625W
    Case: NZXT Tempest
    Cooling: Custom Water Cooling
    OS: Windows 7 Home Premium 64 Bit
    Apr 2008
    http://www.newegg.com/Product/Produc...82E16820227454
    OCZ Blade low-voltage. Not a bad price for a kit of this caliber.
    • i7 920 D0 // eVGA X58 SLI // 12GB G.Skill Ripjaws // HD6950 (6970 BIOS)
    • Apogee XT // MCP655 // Thermochill PA120.3 // CM HAF 932
    • OCZ Vertex 3 MI edition // ASUS Xonar DX // Corsair TX850
    • HTC Incredible - Uber Kingdom Revolution ROM
    May 2008
    I was looking at the blade series as I like OCZ ram. The 1.8v appeals to me, but I am not sure if 8gb's of the stuff would be stable in my mobo.
    Case: NZXT Tempest
    Apr 2008
    Why wouldn't it be? There's more than a few reports of 8GB running at DDR2-1200 on P45. On your X48 you should be able to get 1150 out of it without much tweaking, though you may have to increase your northbridge voltage a little - but that's true for running 8GB in general.
    Engineering The Xtreme
    Feb 2007
    MA, USA
    the x48 lt is also a very strong ram clocking board, it has sufficient ram power phases to properly run 8gb and I am sure you will be able to clock the sticks very well.
    Mar 2005
    Why cant you run 8gb of flex in your current board?? I've got 8gb n my DKX48+ with no issues, and have also used the same ram in a MFII, Rampage Formula, and a P5E.....
    X299X Aorus Master
    I9 10920x
    32gb Crucial Ballistix DDR4-4000
    EVGA 2070 Super x2
    Samsung 960 EVO 500GB
    4 512gb Silicon Power NVME
    4 480 Adata SSD
    2 1tb HGST 7200rpm 2.5 drives
    X-Fi Titanium
    1200 watt Lepa
    Custom water-cooled View 51TG
    Feb 2007
    MA, USA
    he said he cant because it wont fit in the board.
    May 2008
    Yep, the heatsinks on these bad boys are massive, otherwise I would just get another set. I have been looking into getting 8gb of the blade series, but over here in the UK only the 9200 is available at a decent price. I might wait for Newegg to get the 9600 back in stock and get my friend to order it for me. the £'s getting stronger they say.
    Case: NZXT Tempest
    Mar 2005
    Sorry, I should of stated that I have 8GB of OCZ FLEX 9600 in the above mentioned boards, maybe the "older" style flex heatsinks are bigger??
    X299X Aorus Master
    I9 10920x
    EVGA 2070 Super x2
    4 480 Adata SSD
    X-Fi Titanium
    1200 watt Lepa
    Dave's Mentor!
    May 2007
    montreal
    4 sticks is nothing for the x48 lol i was doin 500fsb+ with 4 sticks
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
    Love will tear us apart
    Mar 2006
    wrigleyville.chi.il.us
    Quote Originally Posted by SNiiPE_DoGG View Post
    Quote Originally Posted by zsamz_ View Post
    True stories.
    Dark Star IV
    i5 3570K | Asrock Z77 Extreme4 | 8GB Samsung 30nm | GTX 670 FTW 4GB + XSPC Razer 680 | 128GB Samsung 830
    Apogee HD White | 140MM UT60/120MM UT45/120MM ST30 | XSPC D5 V2
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    same here, i was up to 1250mhz cas5 with 4x1GB of gmh the dfi lt handled it like nothing.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    May 2008
    sweet, ill go for the 9600 blades then and get a Q9650 at some point.
    Case: NZXT Tempest
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by zanzabar View Post
    i did 1274mhx 4 stix
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    Jul 2007
    SF bay area, CA
    dont make me buy working sticks and a 45nm. or compare my blackops thats able to do 1350 cas5 (but i dont have 4 sticks of gts), i think that i could do better but i like 1600+ with the 2:1 multi
    Dave's Mentor!
    May 2007
    montreal
    do it do it!!!!!
    if i had a blackops i'd do it lol
    btw heres everest i know it suks but 4 stix take a big hit and i had to set memory to nominal setting
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
