Page 1 of 6 1234 ... LastLast
Results 1 to 25 of 148
Thread: DavyJones Eat your Heart out..Calypso is a BEast
    Jul 2007
    Cool DavyJones Eat your Heart out..Calypso is a BEast
    Its been along time coming.
    X2's with a whole new meaning.
    I havnt had the urge to play with a X2 in almost two years. I almost passed this one up for a 955.(Either was free for me)im not greedy
    This has to be AMD's ultimate Bonus package.
    These BE's are like CrackerJacks...Suprize in every Box
    @$109 + shiping + tax = $120 = Half the cost of 955. Then coupled with a new budget AM3/AM2+ Mobo it delivers. Im running a UD4P Bios F5a.. Not the Best Bios but it works %100% to unlock the newest Beast yet,,
    Callisto.....AKA my Calypso is amzing for the price...i imagined a lot less bang actually
    1st Boot up to 3800mhz + @ STOCK VOLTS
    3900mhz+ required a smal bump to 1.44volts Stock NBvid
    4000mhz @1.48volts NBvid= 1.2volts
    4128mhz @1.52volts NBvid= 1.3volts
    Im not saying every chip will unlock and clock,,
    So what even then you still can Expect 4ghz with decent cooling on 2cores.
    This CPU is my B-day present... i couldnt ask 4xanything more.
    I am still testing the CPU/Nb and max Ram Freqency.
    I think im close to max and i could settle for 4gig 24.7 . High freqency and low volts there is still a lot of heat in the kitchen. Even though the load temp is mid 40's to High 40's. It still put a lot of stress on things.
    Just now starting to up the Nb and ram. Im no where near done. A little faster NB and better timing will be nice. I think NB is where these X2's may be weak once turned into a X4. I havnt even raised up the HTT yet
    Im happy with my X550x4core BEeeeast......
    "AMD...Like the perfect Storm,...Everything needs to be just right"
    X555x4SuperCore@4450mhz@1.64v..........
    RYZEN 7 1800x/ ASUS ROG STRIX VEGA64/ =EK NICKEL WB, Feser THC 2x360 1x480
    X470 Gigabyte Aorus7, Patriot 3400mhz 16gb dual2x8
    SSD Samsung 970pro,,860EVO
    Jan 2004
    Sweden
    Thats totally sick! My 940 BE cant even do 3.9ghz with watercooling
    What cooling are you using?
    Banned
    Apr 2008
    Brisbane, Australia
    Holy cow!
    Xtreme Mentor
    Feb 2007
    Oxford, England
    nice
    what cooling
    and what mobo?
    "Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
    //James
    Apr 2008
    NW Italy/NE USA
    PhenomX4 9850@3.4Ghz / Asus M3N-HT DLX/HDMI / Gainward GTX 285 / 2x2GB G.Skill DDR2-800 CAS4 / Win7 x64 RC / Water Cooling
    I am Xtreme
    Feb 2003
    Netherlands
    That's just awesome! True bang for buck.
    Now tighten up those timings and show 3GHz NB please!
    Happy birthday man, enjoy your nice present!
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Jul 2007
    GigaByte MA790X UD4P AM3/AM2+ DDR2 mobo F5A Bios.
    Cooling is in SiG+ two Tripples.
    I may need a Better Bios for Decent Ram NB tweaking. This dosnt have the easy Ram feature that the UD5 has.
    As for Ram im running patriot Viper 1200's. there 2.3 volts .. so down the road ill invest in some LV Blades
    The CPU seems to max around 4150/4175mhz but this may be to my Bios . I havn't really played with the NB/HT Multis to Tweak HTT yet.
    Trying to let Chip settle in while bringing the Volts up a tad. Seems to be working so far. Even with Good water set up these still put out some heat. , Higher freqency with less volts still creates WATTS TDP either way you slice it.
    Hmm BRB check the NB muli for a bug in BIOS..i dint check to see if it went above 12x stable with Bios.here we go..
    Jun 2005
    Melbourne, Australia
    Fully sikm8 results Lucky you got a nice chip first pop. I'm 5 down & counting... Time to contact my supplier for same stepping as yours
    C-BuZz
    Jul 2007
    Quote Originally Posted by C-BuZz View Post
    C-BuZz
    Dang ,, bloody happens somtimes,, to the best of us. I have 9600BE that dosnt even run @stock it only runs at 2100mhz...I sent it out, but AMD said nothing was wrong with it in 64bit..Stupid B2's
    Wow i wonder what made this one a X2 if they start as a X4...I dont see nuttin wrong with the Nb clocks either. My 720 could barely do 2400nb@ 3700mhz ,, with this same Bios @ 1.3vid
    I just need to see what other ram i have around ,, this patriot isnt the best for this set up . Any Lower volt sticks would be better than 2.3v
    Mar 2008
    Nice chip, glad to see the UD4P doing its thing,
    Ill almost definately be getting one of them!
    Dec 2007
    Hungary (EU)
    Batch please!
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Impressive clocks for a "budget" chip. I wonder if your chip wasn't broken but made into an X2 to satisfy the launch quantity?
    Dec 2003
    UK
    Wow this is the first time I've been hyped up about an AMD CPU since the mobile Athlon days!
    With that in mind I just put an order in:
    It will be arriving tomorrow
    This is like the CPU lottery, I'm just hoping I've got a winning ticket which has x4's all over it!
    Jul 2008
    Ontario
    Nice clocks there Man
    Looks like I'll be trying the same thing here, Since we both have the same batch number. Damm thunder storm last night had to shut it down early, Back at it today tho
    Time to see what this chip can do also, fingers are crossed also, hope'n bios holds up
    i7 860 Batch # L933B378
    ASUS Maximus III Formula
    Koolance CPU-360
    G.Skill 1600 7-7-7-24
    Sapphire 5770
    i7 860 @ 4.213 http://valid.canardpc.com/show_oc.php?id=986383
    Phenom II 550 X4 @4.160(MA790X-UD4P) http://valid.canardpc.com/show_oc.php?id=652117
    Phenom II 550 X2 @ 4.1(MA790X-UD4P) http://valid.canardpc.com/show_oc.php?id=638438
    Kuma 7750 @ 3.5....http://valid.canardpc.com/show_oc.php?id=560031
    Phenom II 940 @4.1<------ http://valid.canardpc.com/show_oc.php?id=501007
    9850BE@3.6------- http://valid.x86-secret.com/show_oc.php?id=447465
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    Heh, you've got a nice chip there. My 955 isn't even stable at 4.4GHz on dry ice. Core 4 flips out > 4GHz no matter how cold or how much voltage is applied.
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
    Oct 2007
    Chesterfield UK
    Nice, whats your cpu code? mine here in the uk is 0919EPMW and i have an unstable core
    a few threads about the 550 BE on here
    Gigabyte GA-P67A-UD4-B3 - F7a Bios
    Intel CPU Core i5 2500K Sandy Bridge @ 4.6Ghz
    Gigabyte GeForce GTX 460 OC 1024MB **SLI**
    16 GB (4X4)Corsair DDR3 Vengeance Arctic White,1600mhz,CAS 9-9-9-24, 1.35V
    Asus Xonar DG - Thermalright Silver Arrow
    Creative Fatal1ty HS-800 Gaming Headset
    LiteOn 20X SATA DVD±RW/RAM
    Dell 24 INCH U2410 IPS Panel
    Crucial RealSSD M4 128GB 500MB/S
    1 x Samsung F3 1TB -- 2 x Samsung F4 2TB
    Fractal Design R3 - Corsair 850W Modular PSU
    Windows 7 64 Bit
    Dec 2008
    Isn't it Callisto, not Calypso?
    Please feel free to send any unused Athlon 250's this way to upgrade my aging X2 4000+ @ 2.4
  18. #18
    Jun 2008
    Northern Ohio
    Wow that's a heck of a chip. I also noticed something a bit weird for my perspective. To get up to 4Ghz+ you were raising the NBvid? Even though your NB speeds were not going up? So NBvid was helping hit a higher CPU clock? I have been keeping my NB volts LOWER, hoping to keep the total heat lower. I have been stuck at 3.9Ghz on my 955, perhaps I should give my NB more volts and see if I can hit the magic 4Ghz for 24/7.
    Quote Originally Posted by gOtVoltage View Post
    My idle temps are just a bit under 40c I don't know why my chip is so warm, I use water cooling and it's lapped and still that warm. Load is mid 50's with my NB volts being lowered, so I am sure if I do raise it, then my temps will skyrocket into unstable territory.
    Well again nice chip congrats
  19. #19
    Jan 2005
    What an awesome chip...it kills my 720 easily. Amazing value you got there. If I knew I was going to get that I would buy one lol...who wouldn't?
    *CPU: Xeon X5650 @ 4.3 Ghz | Cooler: Thermaltake Water 2.0 Extreme
    *Asus Rampage III Formula | RAM: 36GB DDR3 (Tracer LED + Hyper X Savage)
    *Video Cards: Gigabyte Aorus 1080ti
    Sound Card: Sound Blaster Z | PSU: Corsair HX1000W | Display: BenQ PD3200u | JVC RS520 projector
    *Case: CoolerMaster HAF X (932 side panel) | Others: Roccat Kone AIMO | Roccat Alumic | Logitech G15 |Cameras: Sony A7R3 | RX100 V
  20. #20
    Feb 2008
    Northeast Ohio, Where the weather changes every 30 min...
    Man I barely get 4.1 stable on phase with 1.6v.
    Not much to say right now.
  21. #21
    Aug 2007
    made in indonesia
    awsome.......i wonder if that using LN2...hmmmmm......can get more.......
  22. #22
    Jan 2008
    milwaukee
    $120 for 4ghz quad core now that is a good deal!
    LEO!!!!
    amd phenom II x6 1100T | gigabyte 990fxa-ud3 . .
    2x2gb g.skill 2133c8 | 128gb g.skill falcon ssd
    sapphire ati 5850 | x-fi xtrememusic. . .
    samsung f4 2tb | samsung dvdrw . .
    corsair tx850w | windows 7 64-bit.
    ddc3.25 xspc restop | ek ltx | mc-tdx | BIP . .
    lycosa-g9-z2300 | 26" 1920x1200 lcd .
  23. #23
    Xtreme Cruncher
    Jun 2006
    Haha what an uber X2,err X4 .May it serve you well and long gOtVoltage !
  24. #24
    Xtreme Mentor
    Nov 2005
    Devon
    Do I need to wish you Happy Birthday??
    You're really lucky guy!
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
  25. #25
    Jul 2007
    Quote Originally Posted by [XC] gomeler View Post
    I dont know but looks good to me
    Quote Originally Posted by Balb0wa View Post
    0921 APAW
    Quote Originally Posted by salad View Post
    If i put Callisto,, you be like oh.. Since i put a Nice theme to my Watercooled chip called (Calypso)(Godess of the Sea) it seems to be working.
    Quote Originally Posted by Tom128 View Post
    My NBvid is 1.1 vid (STOCK) .. Its set to +.250-300,, after 4ghz or when running HIGH NB..So this is where i drew the Line for Now..the Max limit i CHOSE to set for the NBvid( 1.4vid ) the Mobo goes alot Higher
    Im still in shock , Volts are nice , My 720 is hiding the Beer ,thinks i may do something wild.
    Quote Originally Posted by angelicavoc View Post
    Just two tripple rads and some good old distilled water. My Abiants for Room right around 22c. When the Summer Heat kicks in i usually lower the Oc anyway,, but so far i left the ACC off and tested with 26c ambiant.
    4ghz is a nice X4 for 24/7. I can always Keep NB stock for less heat.
    4000@1.53 looks to be a sweetspot up to 2600/2800 Nb. The NB is good up to 2800+ @ 4100mhz so will be a decent all around clock.
    Quote Originally Posted by crazydiamond View Post
    Whole new meaning to 100% overclock..Or Buy 1 get one free thing
    Quote Originally Posted by informal View Post
    This one is my Main Rig for playing around .. If i didnt get the 550 it was gonna be a new 955.
    Im glad i decided to try this new X2 line. Reminds of when 6400+BE hit and everyone got all uberNutty n Stuff.
    Hahaha all nice little X2_550BE ,, see how it eats its kin ....
    Quote Originally Posted by Lightman View Post
    I think Luck and good Karma....i hope what ive been giving out is coming back to me lol Treat your Nieghbor how you would Treat yourself kinda thing.
