XtremeSystems Forums
Reply
Old 06-08-2009, 04:35 PM   #1
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
TFC MONSTA testing complete
After about a month's worth of tinkering and testing, I think I'm finally done..
Here is the information I've gathered on my new toy, the TFC Monsta. It is an expensive, but very nice and top performing radiator. I haven't tested a bunch of triples, but I have tested a few. It's become pretty clear to me that test results can really only accurately be compared when they are on the same test bench.
I've also in the process of testing learned a few things about testing and ended up changing my test method as a results. In particular, I think it's much more accurate and appropriate to calculate C/W values on radiators that are specific to "Water Average" as opposed to "Water Out". The reason being that "Water Out" depends on flow rate and it also depends on heat dissipated. "Water Average between inlet and outlet" on the other hand is not, it eliminates the delta between inlet and outlet since it's an average of the two.
Anyhow, long story short. This round uses a "Water Average" method which is different from my old testing. I did however recalculate the heat dissipated for a couple of triple radiators I previously tested.
OK, so enough of that, let's get on with it. Being a camera nut as well, I may as well give you some eye candy. After all, aesthetics and visual is a big part of water cooling anymore, to some more than others.
Here is the Monsta Packaging, it's it very nice and gives a nice first impression:
But more important to me is the "Protection" effort. Each end of the radiator is completely encompassed by a custom foam end piece. Take note that even the barbs, plugs, screws, and fluid each have their own compartment. This attention to detail in packaging should ensure the radiator is protected, not only from outside damage but also from loose barbs. That' not something I've experienced before, but I have read a few threads where someone had damage done to a radiator from loose barbs in the package. That can't happen with this sort of protection.
And this is the accessory package. Of particular note the very nicely made custom rubber gaskets that work as a shroud and noise/vibration isolation. Unlike cheap foam gaskets, these can easily be removed and reused without sticking to or requiring cleanup. The rubber gaskets even have steps to perfectly match the radiator ends where the sides step down to the top/bottom.
And the package comes with some 3/8" x 1/2" compression fittings and G1/4" plugs for the secondary ports. Finally it comes with two sets of screws for fans, short ones for fans that are open ended and longer ones for 25mm thickness fans.
Speaking of barbs, if you want 1/2" x 3/4" compressions, you either need these or some extensions to make standard ones to fit.
These TFC fitting are pretty nice and oversized though, the inlet side has a nice taper bore to better match the tubing ID for reduced restriction.
And here are some general pictures for scale:
Yeah it's BIG!..almost makes my 480's look a bit smallish..
Standing it up next to my TFC480 for relative comparison:
OK, so how does this thing flow. It has 4 rows worth of tubes 14 across for a total of 56 TUBES!
For reference most slim thickness radiators have 10 or 12 depending on width, and most double thickness types have 24 tubes. The Monsta has twice that many....
This team of 56 tubes is also why this radiator is soo free flowing as I found during my pressure drop testing:
Pressure drop results:
And a quick comparison to some others I've tested:
It doesn't get better than that. While radiators in general are very free flowing, this is exceptionally free flowing.
For scale, the TFC Monsta at 2GPM has a pressure drop of .3PSI
A swiftech GTZ for comparison at 2GPM has a pressure drop of about 5.0PSI
So you could run about 15 of these radiators together in series before it would add up to the restriction of just one GTZ block!
It is that low...
And here are some of the new Triebwerk fans, they are extremely nice.
Really nice casting quality:
A continuation of the MONSTA theme..
The fans are unique from other fans in several areas. In particular, they have a built in shroud, a cone shaped and smaller hub, and generally much less dead spot than your typical fan. Here is an active area comparison I sketched up:
Here are some videos to listen to the fans:
TK-121
http://www.youtube.com/watch?v=Mq-65qnTwAk
TK-122
http://www.youtube.com/watch?v=Fp_DWfCH0UU
OK enough of that, how about thermals you might ask?
On with the bench testing:
I used my old radiator testing bench with the crystalfontz, 8 air in sensors, 4 air out sensors, one water in, and one water out. For pumping I used a DDC 3.2 with SWC top, and controlled flow rate to 1.5GPM as I've done before. I did try to do one preliminary test to see what sort of flow rate effects I could measure, but it was pretty much flat from .5GPM to 3.5GPM. So unlike water blocks, radiators are not very sensetive to flow rate even big quad thickness types like this.
And after 20+ 2-3 hour runs, this is what I found:
UPDATED 6-21-09 (Added some 140mm fan runs)
First the raw averaged data collected. These are all the average of the logged run data after reaching stabilization:
And the 10C heat dissipated chart (Water Average being used here)
Here is the estimator chart for figuring out what delta you can expect for particular heat loads and corresponding fan lines:
First the 120mm fans:
Second the 140mm fans:
And the C/W charts. I don't really like these as much as the heat dissipated, it tends to give you the impression that they are the same at higher RPMs...
And finally a comparison with some triple radiators I've previously tested and recalculated per the "Water Average" method.
The blue bubbles are comparing apples to apples with the same exact 120mm fans at exactly the same RPM
The red bubbles are showing how some Koolance 140mm fans compare. This is no longer an apples to apples fan power comparison, but it does give you a good indication how some 140mm fans compare. As you might expect, there is a noteworthy gain by using 140mm fans per RPM.
Bottom line, it's very strong in performance and particularly strong with higher strength fans where the extra thickness and surface area gives the largest gains. In addition, it appears 140mm fans give about another 10+% gain over using 25mm fans when comparing RPM. I suspect running 140mm fans in push/pull on the radiator would gain a fair amount more as well.
Now I just need to work on building some brackets for my Torture rack. The two 480's now have some "MONSTA" company...
Cheers!
Martin
Martinm210 is offline   Reply With Quote
Old 06-08-2009, 04:40 PM   #2
LOUISSSSS
Banned
thanks M!
LOUISSSSS is offline   Reply With Quote
Old 06-08-2009, 04:55 PM   #3
jollyjoker
Very nice. Thanks
__________________
I7 920 @ 3.6 W/ Enzotech Sapphire
Asus P6T
4870x2 W/ XSPC Fullcover
6gb Gskill 1600
jollyjoker is offline   Reply With Quote
Old 06-08-2009, 05:02 PM   #4
leo_bsb
leo_bsb's Avatar
Send a message via MSN to leo_bsb Send a message via Skype™ to leo_bsb
thanks martin!
great job as always.
__________________
My Lian Li PC-G70W
Q6600 @ 3.6GHz @ 1.43V - Sapphire 5870 1GB 900Mhz/1300Mhz - 4GB Gskill 1066 - Corsair P128 SSD - Asus Maximus Formula - Lian Li G70W Powdercoated
Watercooled by single loop PA120.3 + Swiftech MCR220 with San Aces H1011 - D Tek Fuzion V1 - EK NB-Max - Koolance Vid-AR587 - Swiftech 355 with XSPC Top/Res
leo_bsb is offline   Reply With Quote
Old 06-08-2009, 05:08 PM   #5
Lu(ky
I am Xtreme
Lu(ky's Avatar
Great Job Martin...
__________________
CPU: Intel i7-920 4.2GHz 1.2V 3849A832
MOBO: Asus Rampage Gene II Micro x58
MEMORY: Mushkin Redline 1600MHz 6-7-6-18-40 1T
GPU: 2 x XFX 4890 Black Edition eK Full Block "Nickel"
SOUND Auzentech X-Fi Prelude & M-AUDIO Studiophile AV 40
SSD:Intel 80GB SSD G2
PSU: Corsair HX1000W PSU
COOLING: 2 x XSPC 240 radiators & 4 x Scythe "ULTRA KAZE" 120 x 38mm
CASE: Torture Rack DD
MONITOR: LG W3000H-Bn 30" 5ms Widescreen LCD
O.S: Windows 7 Ultimate x64
Lu(ky is offline   Reply With Quote
Old 06-08-2009, 05:10 PM   #6
quattro_
I am Xtreme
quattro_'s Avatar
thank you martin, really appreciate the time and effort you put in all your tests.
__________________
rig1
q9650@4.3 ~ EK Supreme
Asus RE ~ BP chipset block
4GB OCZ PC3-14400 Reaper@1600Mhz
HD 4870x2 ~ DD waterblock
DELL 3007HC
rig2:
i7 920@4 ~ HK3 CU
EVGA Classified 760 ~ EK chipset block
6GB Dominator GT@1866MHz, 7-8-7-20
HD 5870 ~ EK waterblock
quattro_ is offline   Reply With Quote
Old 06-08-2009, 05:14 PM   #7
masska
I am Xtreme
masska's Avatar
Great work as always Martin. Thank you for your time and sharing your results
masska is offline   Reply With Quote
Old 06-08-2009, 05:22 PM   #8
alacheesu
Thanks, Martin! I'm always looking forward to your test results!
Anyway:
The more numbers we get on the monsta/treibwerk, the less impressive they look, imo. Sure the monsta beats the PA, but a 420 vs 360 rad isn't exactly a fair fight. Even with the built in shroud the $35 (?) triebwerk fans could only perform about as well $5 YL. I really like the idea of 140.x rads, but I think the monsta handles this poorly as far as price/performance/size goes. I also like the idea of fans optimized for radiators, but the numbers speak for themselves as far as triebwerk goes.
alacheesu is offline   Reply With Quote
Old 06-08-2009, 05:24 PM   #9
soulesschild
great work
__________________
Cooler Master ATCS 840 Silver Water Cooled || Vista x64 || Corsair HX1000
Swiftech MCR320 || MCP355 /w XSPC ResTop || Swiftech GTZ || 1/2" ID x 3/4" OD Duralene Tubing
Q9550@3.7Ghz, E0, 1.215 VID || Asus Rampage, 1.25 vCore, 1.29 NB, 1.32 VTT ||XFX 4870x2
Dell 3007WFP-HC || 2x Dell 2007WFP || 4GB(2x2GB) Mushkin DDR2 6400 800MHZ ram at 4-4-4-12-2T
ATH-A900/Z-2300s || FiiO E5 Amp || G15 Rev 1 || G7 || Logitech 9000 Quickcam || Salar M8 Microphone
6401AALS WD Caviar Black || 400GB Seagate || 500GB Seagate || 250 Seagate
White MSI Wind U100 2GB Ram || Windows 7
soulesschild is offline   Reply With Quote
Old 06-08-2009, 05:28 PM   #10
Fragger
Fragger's Avatar
Good to see the PA120.3 beating the RS360 by 21% at 1000rpm, the PA still has some fight left!
__________________
Asus Maximus II Formula, E8500@4GHz, 4Gb Crucial Ballistix Tracers, Enermax Infiniti 720 Watt, 8800 GTS, Creative Audigy, 1Tb HDD, 500Gb External HDD, Asus DVD Burner, HP w1907 Monitor, Custom Acrylic Case.
Water cooled by Swiftech Apogee GT, EK Full Cover, Thermochill PA120.3 & PA160, D5@3, Custom Bronze Res, 7/16 Tubing.
Fragger is offline   Reply With Quote
Old 06-08-2009, 05:33 PM   #11
Martinm210
Xtreme X.I.P.
Martinm210's Avatar
Thanks!
I ordered some 140mm Koolance fans this weekend, but they are in the mail. I'll try to get a few more runs with the 140's when I get them. I'm sure 140mm runs would be a fair amount stronger, but I was trying make a comparison using exactly the same fan, number of fans, and corresponding fan power and noise.
I can add the 140 runs later...should be better per RPM, but it's no longer apples to apples on the fan power side of things since you get more CFM per RPM on the 140s.
Old 06-08-2009, 05:40 PM   #12
Sly Fox
Sly Fox's Avatar
Send a message via AIM to Sly Fox
Martin, you never cease to impress.
Thanks for the testing!
__________________
Q6600 g0 (lapped up to 1200 grit) @ 3.6 ghz (will be higher once a game comes out that needs the juice)
DFI LP LT X48
EVGA GTX 260 (216) FTW (what a name...)
4 gigs DDR2-800 Ballistix 4-4-4-12
Creative X-Fi XtremeGamer
500 gb Seagate + 150 gb Raptor X
Silverstone 850 watt (modular)
Vista Business 64 bit
EK Res 150 -> DDC3.2 + XSPC Rev. 3 top -> MCR320 rad (S-Flex F fans) -> Apogee GT (bowed) -> MCW30 -> MCR120 rad (Zalman F3 fan) -> MCW60 -> EK Res 150
Sly Fox is offline   Reply With Quote
Old 06-08-2009, 05:45 PM   #13
SAE
XS-Fanb0i N-side
SAE's Avatar
Send a message via ICQ to SAE Send a message via Skype™ to SAE
Great testing and results. Thx, Martin.
__________________
Xtremesystems.org
i7-950 * Duniek + DT rty singlestage comin' (long wait since september ) * EVGA X58 Classified * 6Gig Corsair DomGT 2000C7 * XFX GTX 285 XXX * Intel 80Gig G2 + OCZ Vertex 30GB * Corsair HX1000 * Dimastech Easy V2.5 * Swiftech MCW60, MCP355 Dual Setup@Watercool Top, PA120.3 w/Triebwerk, EK Res250, DD 16/10 w/Feser fittings...
Athlon XP in summer 2004@12.5x261-265MHz 11-2-2-2-2.0 w/DFI Lanparty B No.1 AXP 3.25-3.3GHz+ phase cooled, 3.2GHz folding stable
No.1 HexusPifast Athlon XP: 43.92sec @12.5x263MHz 11-2-2-2-2.0 w/DFI Lanparty B
No.1 Superpi 1M Athlon XP: 30s @12.5x265MHz 11-2-2-2-2.0 w/DFI Lanparty B
SAE is offline   Reply With Quote
Old 06-08-2009, 05:58 PM   #14
Sadasius
Tygon Warrior
Sadasius's Avatar
Thank you for this Martin! I am wondering why there are differences between the slow and medium Triebwerk fans for the same rpm's. Are they a different pitch or is there a sensor problem?
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is online now   Reply With Quote
Old 06-08-2009, 06:07 PM   #15
NaeKuh
Broken Gainestown
NaeKuh's Avatar
WOW the tribewerk blows @ that price.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is online now   Reply With Quote
Old 06-08-2009, 06:24 PM   #16
MpG
MpG's Avatar
Excellent. Not sure how impressed I am with the stars of this test to be honest, seeing as the rad is packing a hell of a lot more surface area, and the fans have more thickness. Still, it's seeing the data laid out like this that gives us the luxury of making those kind of judgments in the first place, for which I'm highly grateful!!
Extra note: Second last graph, you've got two lines labelled TK-122. I assume one of them should be TK-121?
__________________
i7 920 | Foxconn Bloodrage | GTX280 | Corsair DDR3-1600 2x3GB
MpG is offline   Reply With Quote
Old 06-08-2009, 06:28 PM   #17
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
We all knew the triebwerk would suck
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 06-08-2009, 06:30 PM   #18
NaeKuh
Broken Gainestown
NaeKuh's Avatar
Martin why did the 122 score worse then the 121 @ higher RPMs?
__________________
Old 06-08-2009, 06:34 PM   #19
eligray
eligray's Avatar
Send a message via AIM to eligray Send a message via MSN to eligray
Thanks for the data Martin, this is truly amazing work
__________________
Originally Posted by xaxis View Post
It's really unfeasible, unpractical, and for all intensive purposes... SHOULD NONE THE LESS BE ATTEMPTED!
eligray is offline   Reply With Quote
Old 06-08-2009, 06:58 PM   #20
Serpentarius
Serpentarius's Avatar
cant believe a 25mm Scythe pawns the rest .. would rpm being such a huge factor?
i was thinking either 38mm or that thumb thick fan would prevail
i still cant get it ... why would a smaller surface area still wins the larger surface area?
Serpentarius is offline   Reply With Quote
Old 06-08-2009, 07:03 PM   #21
DarthBeavis
Infected with the Ewe Flu
DarthBeavis's Avatar
awesome possum . . . now get ur rear to PDXLAN . . .
__________________
Please stop by my blog: www.outoftheboxmods.com
DarthBeavis is offline   Reply With Quote
Old 06-08-2009, 07:05 PM   #22
DarthBeavis
ALl fans suck and blow?
__________________
Old 06-08-2009, 07:05 PM   #23
Sadasius
Tygon Warrior
Sadasius's Avatar
EXACTLY! Not only does it have more surface area for cooling but it does worse then the el cheapo fan. The Triebwerk fan really does blow!
__________________
Old 06-08-2009, 07:10 PM   #24
eligray
eligray's Avatar
All the pump, radiator, waterblock, and now fan choices are best left to martin :thumbup:
Guys, I'd imagine that the larger surface area does help, but that the difference isn't enough to offset the inefficiency of the fan blades
__________________
Old 06-08-2009, 07:20 PM   #25
santiagodraco
I am Xtreme
Awesome work as always Martin!
__________________
i7 920@3.9 Ghz | Gigabyte X58-UD5 | 6GB Corsair Dominator 15000
ATI Radeon 4870x2 | X-Fi Elite Pro | Samsung LT4665N 46" 1080p + Samsung LN32A550 32" 1080p LCD TVs
Koolance CPU-350/Vid-487x2 on Koolance ERM-2K3U
Zalman HD160XT HTPC | 4TB+ (2x VelociRaptors, ~4 Cudas, 4x Free Agent Pro 750gb) | Thermaltake Toughpower 1200w PSU
santiagodraco is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
