Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: 4890 Voltage Increase Methods
    Jun 2008
    Ok guys, I bit the bullet and ordered a bunch of equipment yesterday to upgrade my current 4870/512MB Crossfire setup to 4890/1GB Crossfire and also ordered a whole new watercooling loop just for the vid cards as my current loop will not be able to sustain 2 4890s with tweaked voltage...which leads me to the topic of the thread...
    Since I will be running 2x4890's in Crossfire -- (one is MSI brand, and one is HIS brand if it matters, both appear to be reference design) both will have full coverage waterblocks -- what application(s) is/are out there that will allow me to increase voltage to both cards permanently? (like a BIOS update or something in Rivatuner, etc.?)
    Thanks very much -- this is the last piece to my puzzle.
    ASRock 990FX Extreme4
    AMD FX 8350
    Kingston 16GB (4GBx4) DDR3 1333
    Gigabyte NVidia GTX 680 2GB
    Silverstone 1000W PSU
    Oct 2006
    supposedly you can use Rivatuner, with a config file tweak to work for the 4890, to increase voltage and then a scheduler in Riva to apply the higher voltage at each bootup. While I got the voltage increase to work, I could not figure out the scheduler to apply voltage at bootup :/
    Rig 1:
    ASUS P8Z77-V
    Intel i5 3570K @ 4.75GHz
    16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
    Nvidia GTX 670 4GB SLI
    Rig 2:
    Asus Sabertooth 990FX
    AMD FX-8350 @ 5.6GHz
    16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
    AMD 6950 with 6970 bios flash
    Yamakasi Catleap 2B overclocked to 120Hz refresh rate
    Audio-GD FUN DAC unit w/ AD797BRZ opamps
    Sennheiser PC350 headset w/ hero mod
    Engineering The Xtreme
    Feb 2007
    MA, USA
    Rivatuner works wonderfully per this guide: http://www.xtremesystems.org/forums/...ghlight=vt1165
    you just need an extra config file to make riva recognize the 4890 - the zip is attached
    http://rapidshare.com/files/24077692...Tuner.zip.html
    Jun 2008
    Thanks very much for the help fellas!
    AMD FX 8350
    Banned
    Oct 2006
    new bios will be available soon so we can all just flash higher clocks with a bumped voltage... we will all sit at 1ghz.....
    Xtreme Mentor
    Dec 2007
    Looking forward to trying that bios.
    Jun 2008
    Quote Originally Posted by SNiiPE_DoGG View Post
    Sniipe I went to download this today now that I've got my 4890's installed but I get an error --
    Error
    This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times.
    This limit is reached.
    To download this file, the uploader either needs to transfer this file into his/her Collector's Account, or upload the file again. The file can later be moved to a Collector's Account. The uploader just needs to click the delete link of the file to get further information.
    Help. I really want that plugin to make Riva recognize my 4890s.
    AMD FX 8350
    Feb 2007
    MA, USA
    Quote Originally Posted by Razrback16 View Post
    Error
    http://rapidshare.com/files/24314875...Tuner.zip.html
    Oct 2007
    this thread is being bookmarked!
    Jun 2008
    You sir, are the man. Thanks!
    AMD FX 8350
    Jun 2008
    Alright tweaking is under way via AwardFabrik's Voltage Factory. Stock volts allow me to go to 925MHz/1080MHz on both cards stable in Crysis for 1+ hours of gaming. Above this (tested up to 975MHz at stock volts) doesn't cause crashes, but it does cause artifacting. Load voltage on both cards @ stock is 1.31 volts. I'm now bumping to 1.35 volts to see what we can get....
    ** What is the max safe recommended gpu core voltage on a 4890 that's on straight water?
    AMD FX 8350
    Oct 2007
    I asked a similar question and didnt get an answer but I have seen people recommending 1.4 volts as being safe on water
    Corsair 700D
    Intel i7 920 @ 4.20|Asus P6T6 Revolution|G.Skill 6gb DDR3 1600|Zotac GTX480|Intel x-25-M 80GB x 2 / Raid0
    H2O
    |Perfecting the Obsidian series case. Build log to follow soon...|
    Jun 2008
    Thanks for the reply DP.
    Latest findings are 1.38 volts allows 975MHz core clock stable on both cards in Crossfire. No artifacts. Before I push to 1GHz, I am curious if RBE is flashing the 4890 successfully currently? I will likely need to flash both cards to open up higher clock availability in CCC.
    AMD FX 8350
    Feb 2007
    MA, USA
    as long as you temps comply <1.5vGPU on water
    Oct 2007
    Good to know. I cant wait to get my card in. Stink that ups takes 5+ days to go cross country
    Corsair 700D
    H2O
    Jun 2008
    1.40 volts allows 1GHz core clocks on both cards, stable. VRM temps are getting outta control though ~100*C even with the full cover WBs. I may just hold there. Mem is stable @ 1080MHz.
    AMD FX 8350
    Feb 2007
    MA, USA
    Volterra PWM's are specified for 125C operation
  18. #18
    Xtreme Mentor
    Dec 2007
    Was able to get 1000mhz core to pass furmark 400 seconds. Upped the voltage to 1.35. The numbers look low to me, before I was getting better fps. Do I need to take the second card out and retest? I disabled cf in CCC.
    Attached Images Attached Images
  19. #19
    Xtreme Mentor
    Dec 2007
    Ok, took the card out of the bottom slot and reran fur. FPS look better, think it was running at 8x.
  20. #20
    Jul 2008
    US
    My VRMS touch 80C max with EK 4890 LT blocks at 1000/1000 with 1.42v. Is your block mounted securely?
    --Matt
    My Rig :
    Core i5 4570S - ASUS Z87I-DELUXE - 16GB Mushkin Blackline DDR3-2400 - 256GB Plextor M5 Pro Xtreme
  21. #21
    Jun 2008
    Quote Originally Posted by mattkosem View Post
    --Matt
    Too many tubes to get down in there and really look (running two loops, not very organized ), but during inspection of the blocks after installation, everything LOOKED good. Maybe your loop is just more efficient, or better contact for your VRMs? Going by what Sniipe said, if 125*C is operating temp, I'm still under that so I'm ok with that for now. This is as hot as my house gets during the summer as well (~75*F) so hopefully I can survive the summer and enjoy the ~63*F once it starts cooling down.
    Can anybody chime in with their experiences pushing the core with up to 1.5 volts on water? What did your temps look like for the v-regs?
    AMD FX 8350
  22. #22
    May 2005
    Dubai,UAE
    i got Asus EAH4890 VT , using RT v2.24, i set the Vcore to 1.5 and ran furmark, and i got temps of 43~45c TOPS,
    room temp = 26c
    Defaults clocks with wc
    1.5v and 1010MHz on core
  23. #23
    Aug 2008
    Nebraska
    Tried this link and it's dead. Is there another?
    Mobo - Asus RE II Gene
    CPU - Core i7 920 D0 - Memory - G Skill DDR3 1600 3x2GB 8-8-8-21 1.6V
    CPU HSF - Prolimatech Mega Shadow - Deluxe Edition
    GPU - MSI GTX 770 [COLOR="Red"]
    Monitor - Planar 27"
    OS - Windows 7 Professional
    Heatware
  24. #24
    Aug 2006
    The Netherlands, Friesland
    >i5-3570K
    >Asrock Z77E-ITX Wifi
    >Asus GTX 670 Mini
    >Cooltek Coolcube Black
    >CM Silent Pro M700
    >Crucial M4 128Gb Msata
    >Cooler Master Seidon 120M
    Hell yes its a mini-ITX gaming rig!
  25. #25
    May 2005
    Dubai,UAE
    Quote Originally Posted by LiveLongerDays View Post
    http://downloads.guru3d.com/RivaTune...nload-163.html
