Results 1 to 4 of 4
Thread: E8400 to 4.6GHz - EP45-UD3P
    Jul 2006
    Nova Scotia Canada
    I have 9 X 500MHz stable, but am having trouble moving to 9 X 512MHz (4.6GHz). With settings below I have run 10 loops of Intel Burn Test set on Maximum at 512MHz for FSB, with CPU at 8 X 512 for 4.096GHz. If I rasie my CPU multi to 9 for 4.6GHz, adn raise my CPU Voltage to 4.225 in Bios, 3.9V in Windows, it crashes in IBT. Shuts down completely and reboots with the Error message telling me that Windows has recovered from a fatal error. Looking for opinions as to wheter it is my CPU failing, in which case I will add some voltage to it, or could it be the memory or MCH failing with the added strain of the CPU flying at 4.6GHz?
    MB Intelligent Tweaker(M.I.T.)
    Robust Graphics Booster ..............: [A]
    CPU Clock Ratio ......................: [8X]
    x Fine CPU Clock Ratio................: +0.0
    CPU Frequency ........................: 4.096GHz( 512X8)
    ********** Clock Chip Control ********
    >>>>> Standard Clock Control
    CPU Host Clock Control................: [Enabled]
    x CPU Host Frequency(Mhz).............: [512]
    PCI Express Frequency(Mhz)............: [100]
    C.I.A.2...............................: [Disabled]
    >>>>> Advanced Clock Control..........: [Press Enter]
    CPU Clock Drive.......................: [800mV]
    PCI Express Clock Drive...............: [900mV]
    CPU Clock Skew........................: [ 0ps]
    MCH Clock Skew........................: [ 0ps]
    ******** DRAM Performance Control ********
    Performance Enhance...................: [Standard]
    Extreme Memory Profile(X.M.P.)........: [Disabled]
    (G)MCH Frequency Latch................: [Auto]
    System Memory Multiplier (SPD)........: [2.00D]
    Memory Frequency(Mhz).....800.........: 1024
    DRAM Timing Selectable (SPD)..........: [Manual]
    >>>>> Standard Timing Control
    x CAS Latency Time................5...: [ 5]
    x tRCD ...........................5...: [ 5]
    x tRP.............................5...: [ 5]
    x tRAS...........................18...: [15]
    >>>>> Advanced Timing Control.........: [Press Enter]
    x tRRD............................3...: [ 3]
    x tWTR............................3...: [ 3 (11 in Windows)]
    x tWR.............................6...: [ 5 (14 in Windows)]
    x tRFC...........................52...: [54]
    x tRTP............................3...: [ 1 (4 in Windows)]
    x Command Rate (CMD) .............0...: [ 2]
    >>>>> Channel A Timing Settings.......: [Press Enter]
    x Static tRead Value.............10...: [11]
    x tRD Phase0 Adjustment...........0...: Auto
    x tRD Phase1 Adjustment...........0...: Auto
    x tRD Phase2 Adjustment ..........0...: Auto
    x tRD Phase3 Adjustment...........0...: Auto
    x Trd2rd(Different Rank)..........6...: Auto
    x Twr2wr(Different Rank)..........6...: Auto
    x Twr2rd(Different Rank)..........5...: Auto
    x Trd2wr(Same/Diff Rank)..........8...: Auto
    x DIMM1 Clock Skew Control (ps).......: Auto
    x DIMM2 Clock Skew Control (ps).......: Auto
    x DDR Write Training..................: Auto
    >>>>> Channel A Driving Settings......: [Press Enter]
    x Driving Strength Profile............: [1066MHz]
    x Data Driving Pull-Up Level..........: Auto
    x Cmd Driving Pull-Up level...........: Auto
    x Ctrl Driving Pull-Up Level..........: Auto
    x Clk Driving Pull-Up Level...........: Auto
    x Data Driving Pull-Down Level........: Auto
    x Cmd Driving Pull-Down level.........: Auto
    x Ctrl Driving Pull-Down Level........: Auto
    x Clk Driving Pull-Down Level.........: Auto
    >>>>> Channel B Timing Settings.......: [Press Enter]
    >>>>> Channel B Driving Settings......: [Press Enter]
    ****** Motherboard Voltage Control ******
    Voltage Types..........Normal...........Current
    >>> CPU
    Load-Line Calibration.................: [Enabled]
    CPU Vcore..............1.27500V.......: [1.4V (1.38V in Windows)]
    CPU Termination........1.200V.........: [1.300V]
    CPU PLL................1.500V.........: [1.65V]
    CPU Reference..........0.760V.........: [.76 (.7 when VTT is 1.2)]
    >>> MCH/ICH
    MCH Core...............1.100V.........: [1.380V]
    MCH Reference..........0.760V.........: [.72]
    MCH/DRAM Reference.....0.900V.........: [1.05]
    ICH I/O................1.500V.........: [1.5V]
    ICH Core...............1.100V.........: [1.1V]
    >>> DRAM
    DRAM Voltage...........1.800V.........: [2.12V (2.11 in Windows)]
    DRAM Termination.......0.900V.........: [1.05]
    Channel A Reference....0.900V.........: [1.05]
    Channel B Reference....0.900V.........: [1.05]
    ******** Advanced BIOS Features ********
    No-Execute Memory Protect.............: [Enabled]
    CPU Enhanced Halt (C1E)...............: [Disabled]
    C2/C2E State Support..................: [Disabled]
    x C4/C4E State Support................: Disabled
    CPU Thermal Monitor 2(TM2) ...........: [Enabled]
    CPU EIST Function.....................: [Disabled]
    Virtualization Technology.............: [Disabled]
    Delay For HDD (Secs)..................: [ 0]
    Full Screen LOGO Show.................: [Disabled]
    Init Display First....................: [PEG]
    ******** Integrated Peripherals ********
    USB Keyboard Function.................: [Disabled]
    USB Mouse Function....................: [Disabled]
    USB Storage Function..................: [Disabled]
    i7 860, 20 X 200 = 4.0GHz at 1.35V, MSI P55-GD85, 2 X 4GB KHX1600C9D3K2/8GX, GTX 590, 2 X Corsair Force 3 120GB SSDs in RAID 0, 4 X Barracuda SATA 7200.10 250GB RAID 0, 2 X Barracuda SATA 7200.11 500 GB RAID 0 for Back Ups, OCZ ZX 1250W, Z-5500s, LG Blu Ray Player/DVD Burner, Koolance CTR-CD12 Fan/Pump Controller, Windows 7 X64 Home Premium, HAF X. Vision Quest 24" WS LCD, Optoma H66 Projector
    Cooling: Thermochill PA120.2 GT AP15 in push, DC3.25/XSPC Res top, Apogee Xt Extreme, XSPC Razor, Coolgate CG-240 GT AP15 in push/pull, MCP35X.
    Jun 2008
    Lower that PLL, 1.57V PLL should be plenty. As to your problem, have to tried more vcore, dram voltage? Also a 50ps clock skew on the NB can sometimes help.
    Dec 2008
    Melbourne, Australia
    Ye mine were as follows:
    CPU Clock Skew........................: [ 50ps]
    MCH Clock Skew........................: [ 150ps]
    This was for 4.3ghz with my E8400
    Also, why is the MCH ref lower than standard, it should be at least standard from what ive seen (and how i have mine, albeit its a DS4P board, but near enough)
    CPU: E8400 E0 (Cooled By OCZ Vendetta 2) @ 4.3ghz/1.296vcore
    Motherboard: GB EP45-DS4P BIOS F8
    Memory: OCZ DDR2 PC2-8500 (1066mhz) 2x2gig - & Corsair Dominator RAM cooler
    Graphic: PowerColor PCS+ HD4890
    HDD: 2x WD 640GB, 1x Maxtor 180GB
    I am Xtreme
    Sep 2006
    My P45 UD3P and P45T UD3P MCH Ref setting are both lower than stock MCH setting. Round .74, otherwise I don't get into windows.
    But each Board/CPU/RAM combo is different. Eg some need 1.3MCH voltage for eg 550 FSB, others need +1.4 for that...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
