Hi ~
AMD Phenom II X2 550 BE easy test
http://www.playwares.com/xe/?document_srl=4519253
Hi ~
CPU : AMD Phenom II X2 550 BE
Mainboard : FOXCONN A7DA-S 3.0
RAM : Patriot Viper DDR3 PC3-16000 2X2G
VGA : GeForce 7300GS
Power : Ultra X3 1000W
Cooler : APACHI PROLIMA MEGAHALEMS
Phenom II X2 550 BE 3.1G @3.6G
Phenom II X2 550 BE 3.1G @3.8G
Phenom II X2 550 BE 3.1G @4G
http://valid.canardpc.com/show_oc.php?id=575189
Can you try some RAM clocking on there too?
SweClockers.com
CPU: Phenom II X4 955BE
Clock: 4200MHz 1.4375v
Memory: Dominator GT 2x2GB 1600MHz 6-6-6-20 1.65v
Motherboard: ASUS Crosshair IV Formula
GPU: HD 5770
wooooo that looks very nice thank you for test^^
1. ASUS Sabertooth 990fx | FX 8320 || 2. DFI DK 790FXB-M3H5 | X4 810
8GB Samsung 30nm DDR3-2000 9-10-10-28 || 4GB PSC DDR3-1333 6-7-6-21
Corsair TX750W | Sapphire 6970 2GB || BeQuiet PurePower 450w | HD 4850
EK Supreme | AC aquagratix | Laing Pro | MoRa 2 || Aircooled
DFI LP DK 790FXB-M3H5 other Test ...
ACC active, 4 cores ...?
Hot hot hot! The new CPU AMD can be unlocked to 4 core!
http://www.xtremesystems.org/forums/...d.php?t=225698
May have to buy one when available could be fun ocing theses!
Imo this new CPU isn't that exciting... I want to see what Regor can do, thats something new.
Not meaning to start a fight - but Callisto is just another Deneb![]()
SweClockers.com
GPU: HD 5770
namegt:4 GHZ with only 1.35V? How much than with 1.55V? Or CPU-Z show it not correct? Thx. Nice chip. King of dualcores AMD![]()
ROG Power PCs - Intel and AMD
Is the stock volts really 1.280V?
AMD Threadripper 12 core 1920x CPU OC at 4Ghz | ASUS ROG Zenith Extreme X399 motherboard | 32GB G.Skill Trident RGB 3200Mhz DDR4 RAM | Gigabyte 11GB GTX 1080 Ti Aorus Xtreme GPU | SilverStone Strider Platinum 1000W Power Supply | Crucial 1050GB MX300 SSD | 4TB Western Digital HDD | 60" Samsung JU7000 4K UHD TV at 3840x2160
Man i cant wait for one of these! Thanks for sharing!
ASROCK 970 Extreme 3 // FX-6200 @ 4.65 (245x? 64bit os) 1.45v,2200 nb/HT //8GB Mushkin DDR3 @833 8-8-8-24 cmd1 1.55v // HD7850// Silverstone 650w // ~32inch portal // WDgreen and blue // Kingston v300 120GB SSD // watercooled with Swiftech storm rev2, Fez 240 , 655 pump not packed into a Corsair Obsidian 650D///
AMD Phenom II X4 B50 ??
Test the main board is DFI 790FXB-M3H5
BIOS: 0402
http://valid.canardpc.com/show_oc.php?id=575783
But ....
4 cores is not active ...![]()
Is ACC in Auto mode?.. maybe try up + ACC.
How many cores does it show in Bios tha you can Dis/eneable only one ?
4Ghz 24/7, what are the temps at load?
Perkam
That was a real kick-ass Dual core CPU for now.![]()
Sorry For My Bad English
Those temps can't be accurate. 25c load at 3.6 GHz? that means...it's like no heat output at all.
Is AMD Overdrive accurate with the temperature readings?
Computer:
Case: Corsair 750D Airflow Edition
Mobo: Gigabyte Aorus X570 Ultra
RAM: Team TForce Xtreem ARGB 3600C14 2x16gb XMP
CPU: AMD Ryzen 5900x
Graphics: EVGA (rip) RTX 3080 FTW3
PSU: Seasonic Focus GX 850w
Cooling: Arctic Liquid Freezer II 360mm
NVMe: SKHynix P41 Platinum, Samsung 980 Pro 2tb
SSD: Micron 1100 2TB, Samsung 860 Evo 1tb
HDD: WD SE 2TB, WD Black 1tb 3 platter with over 10 years of power-on time
Y!M: Leonarderman
Clan: Duck Team VN
I am ATI Fanboy - Not AMD
Location Location Location...................
Thần tượng: KingTea Super Bựa
Your the Bomb dude
Thats insane Dualcore Action.
Haha I just Grabbed a Revised UD4P for My 720. Hopefull i can truely see what it has in Hybrid Mode
So in a few hours or So ill be hitting up that GIGA thread with some Results .
" NameGT",,
is it working in Auto ? For 4cores now " Also can you disable temp monitoring then check temp in windows.
If its like the 720's it may not reg temps once unlocked and could be messing with Bios
I like DFi too but theres never No DFi's stocked in my neck of the woods. So i grabbed the next best thing that is capable to unlock on stock Bios for Cheap .
A very good friend gave me 50% off UD4P, early Bday present![]()
I check in later need to finish installing The Mobo.
