Results 1 to 22 of 22
Thread: How are my results with X25-M RAID0?
    Nov 2007
    Toronto, Canada
    I am under the impression that my write times should be higher? Or is this what I am going to get now that my drives are about 80% full.
    I'm running Windows 7 RC1 (Build 7100) x64
    Write back caching is enabled.
    System specs in sig.
    RIG 1 (in progress):
    Core i7 920 @ 3GHz 1.17v (WIP) / EVGA X58 Classified 3X SLI / Crucial D9JNL 3x2GB @ 1430 7-7-7-20 1T 1.65v
    Corsair HX1000 / EVGA GTX 295 SLI / X-FI Titanium FATAL1TY Pro / Samsung SyncMaster 245b 24" / MM H2GO
    2x X25-M 80GB (RAID0) + Caviar 500 GB / Windows 7 Ultimate x64 RC1 Build 7100
    RIG 2:
    E4500 @ 3.0 / Asus P5Q / 4x1 GB DDR2-667
    CoolerMaster Extreme Power / BFG 9800 GT OC / LG 22"
    Antec Ninehundred / Onboard Sound / TRUE / Vista 32
    SLC
    Oct 2004
    Ottawa, Canada
    It is quite a lot slower than it should be. I don't know why. Stripe size?
    Nov 2007
    Toronto, Canada
    Stripe size is 128
    Writeback cacheing is on.
    I'm not running anything during the test and I've got about 32GB of free space on the RAID array.
    I haven't really done much tweaking. I suppose I should? I read something about realigning? Should I look into it further?
    RIG 2:
    Savuti
    Guest
    For x25 m raid0, the writes portion seems low. It might have to do with the remaining space, the degree of use the drives have undergone. As a reference perhaps you should consider doing a secure erase to return the drives to fresh state and do an image of fresh OS install then bench from there.
    Nov 2006
    CA and FL
    You may just need the latest firmware
    Think mine are a little low too, 128k stripe, about 90gb left. Using Windows 7 RC build.
    PC1:
    core I7 920 [3841A627] @4.3 Ghz, EVGA Classified, Corsair Dominator GT 2000,
    ATi 5970, 2xIntel X25M, SB X-Fi Titanium, Corsair HX1000
    PC2:
    P4C 2.4@3.8Ghz - 1.6 vcore, IC7-G Max3, OCZ 4000 Gold
    ATI Aiw 9800 Pro, 2xRaptor I, SB Audigy 2 Plat Pro
    Coolermaster 210a w/ Enermax 600W, h2o cooling
    Mar 2005
    It's due to not having optimized drivers for Windows 7...I have X-25M drives and experienced similar problems...I just put my drives onto an Areca 1230ML controller and my scores shot up significantly in Win7 using Vista64 drivers...change your stripe size to 64 and try again in Vista64 to see how well they perform.
    Ultra Aluminus/Silverstone SUGO 05/Thermaltake SPEDO
    Asus P6TD Deluxe/Zotac Mini-ITX GeForce 9300
    Core I3 3ghz/Core i7 920 D0
    TRUE Black/CM Hyper 212 Plus
    G.Skill 4GB PC8500/3GB Corsair DDR3-1866/6GB G.Skill DDR3-2000
    ATI HD4850 1GB/ATI HD4890 1GB/ATI HD5850
    Samsung 305T Plus
    Asus Xonar HDAV 1.3/Creative X-Fi PCI-E
    4 Intel X-25M 80GB SSD RAID-0/Areca 1231ML
    LG 8X Blu-Ray Burner/LG 10X Blu-Ray Burner/Sony Slimline Blu-Ray Optical
    Ultra X3 1600W/Ultra X3 1000W
    Nov 2007
    Toronto, Canada
    Thanks for the tips, guys. I'm not sure I want to return to using Vista. I've been using Win 7 for a while now and I really like it and I'm used to it. Perhaps I just need to be patient and wait for updates?
    RIG 2:
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Quote Originally Posted by ACE76 View Post
    Never had that problem. My X25-M performed better on Win7 than it did on Vista.
    Nov 2007
    Toronto, Canada
    I guess I'll have to pull them and install them in the backup rig and run the benchmarks there.
    RIG 2:
    Jan 2005
    did you update the firmware?
    Nov 2007
    Toronto, Canada
    Yes, the firmware is updated.
    RIG 2:
    Jun 2007
    I am running same windows 7 build RC1, no raid just one x25m, it is about 60% full...your write speed is def low. Did you run iometer for long time?
    Nov 2007
    Toronto, Canada
    I haven't run IOmeter yet.
    I'll be home in a short time and I'll try that next and post up the results.
    RIG 2:
    May 2007
    Quote Originally Posted by zlojack View Post
    I don't think he ment for you to test it, only if you have done alot of IOmeter runs, wich usually slow down the drives...
    | Ci7 2600k@4.6ghz | Asus SaberTooth P67 | Sapphire HD7970 | Samsung B555 32" | Samsung 840 PRO 128gb + 2xIntel SSD 520 120GB Raid0 + 2xC300 64GB Raid0 | Corsair Vengeance 16GB DDR3-1600 8-8-8-24 | Vantage GPU=40250 |
    Nov 2007
    Toronto, Canada
    Quote Originally Posted by Ourasi View Post
    Ah ok...
    Well I've done exactly none
    RIG 2:
    Jun 2007
    yeah, sorry, should have been more clear, I accidentally ran a very long iometer run and killed my write performance...but that was about time when RC1 came out, so secure erase and reinstall fixed it. Hopefully trim support will be coming soon, maybe that will fix your write speed, especially if it is from being 80% full/use habits.
    Nov 2007
    Toronto, Canada
    Well, it looks like I've made some progress here.
    I found a setting in Intel Matrix Storage Manager that I had not played with previously, so I ran CrystalDiskMark with four different configs and these were the results:
    Config 1 (This is what I had been running) - Low write performance across the board
    Config 2 with write-cache buffer flushing turned off. Pretty similar results to Config 1
    Config 3 Much better results with Hard Drive Data Cache Enabled in Storage Manager (right click on the Array and Enable it) and write-cache buffer flushing turned off
    And Finally, Config 4 with write-cache buffer flushing turned on and Hard Drive Data Cache Enabled in Storage Manager
    I'm going to do some more tests between Configs 3 and 4 to see where it stands with other benchmarks.
    EDIT:
    More benchies
    Alright! Now I think Config 4 will be the winner here
    Here are a couple more benchmarks
    Config 3
    Config 4
    RIG 2:
  18. #18
    Nov 2007
    Toronto, Canada
    ATTO writes are still very slow, right?
    RIG 2:
  19. #19
    Feb 2009
    No they are fine!
    They are about double the speed of one drive. That slight blip at the end is probably a touch of degradation.
    It should be cured with a new FW update before it becomes a problem.
    x25-m's don't have very fast sequential rights anyway, so perhaps that's why you thought it looked slow, but your mainly going to be taking advantage of the drives read speed when loading apps ect. which the m will generally do slightly faster than the e, but you do suffer a sequential write penalty, which I have only found annoying if I am writing a large file to the drive, but i'm only using a single x25-m, so you will have double the throughput.
  20. #20
    Nov 2007
    Toronto, Canada
    Thanks Rhys. So it looks like I just had to enable that one setting in Intel Matrix in order to get things "up to speed"
    RIG 2:
  21. #21
    Feb 2009
    Yeh, write back cache got me to, when I first put my couple of Vertex's in raid 0.
    Well glad you got it sorted.
    You should stay tuned for when Trim will be released and more importantly (for you) does it support raid 0.
    It should do, and when it does performance degradation should be a thing of the past.
    Note: the x25-m is fairly good anyway at trying to combat degradation.
  22. #22
    Nov 2007
    Toronto, Canada
    Yeah, I am eagerly awaiting the new firmware. I was really hoping to avoid going through the whole OS rigamarole to test these drives, so I'm glad I was able to find the real problem. It's funny, because I enabled write back cache in Device Manager and also in Intel Matrix, but in that one spot on the "Array"
    The two circled in Red were on but the one circled in Black was the one that helped make the difference for writes.
    Interesting.
    RIG 2:
