Results 1 to 8 of 8
Thread: Beware: GTX 285 Waterblock issues
    May 2009
    My registration finally went through...
    Anyways, be very careful with the GTX 285s. There's a very brief thread on here that I, and I'm assuming others will too, overlooked and have ended up being severely setback because of it.
    Apparently manufacturers are overhauling their GTX 285 video cards. They're reworking the GTX 275 PCB and swapping in and out some parts to meet the GTX 285 standards. However, because this is just now beginning to take place, it means that a lot of the GTX 285 waterblocks are no longer compatible with the newer cards. Cards with 118x in the model number are no longer compatible (though I can't confirm this for all 285 GPU waterblocks).
    I recently bought a GTX 285 and a corresponding waterblock (Koolance VID-NX285) and they are not compatible. Specifically, some of the holes on the end farthest from the ports have been relocated, some of the memory chipsets have been shifted over slightly, and there is a large capacitor impeding on part of the block's location (near what I assume to be a small chip/MCU).
    I'll include pictures of what I'm talking about when I get home.
    Since I've opened the video card, I can't return it to Newegg and, though it's not confirmed and only reported from the customer service rep, since I've cut up the thermal pads to install the gpu block, I can't return that either. Therefore, I'm also open to suggestions as to any different block that may fit or mods to make these compatible.
    CT
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    Get in touch with [Koolance] Dean, he should be able to take care of you.
    http://www.xtremesystems.org/forums/member.php?u=101185
    Circles SucQ!
    Feb 2009
    Cambridge, UK
    [Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build. Written as a tutorial for any newcomers
    Hardware
    Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
    2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
    Watercooling Gear (Dual Loop)
    Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
    6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
    Aug 2007
    Haverford, PA
    [QUOTE=ctsoccer13;3812556]Since I've opened the video card, I can't return it to Newegg
    This is why I avoid all but EVGA like the plague
    20 or so bucks down for an EVGA EAR, and I'll have a new card @ my house ASAP, and also fabulous with returns like this. They let you take the stock cooling assembly off while retaining warranty.
    ~FoxDie~
    CM HAF 932
    MSI Z68A-GD65
    2600k Watercooled @ 4.6 GHz
    Powercolor HD6950
    4x4GB G.skill Ripjaws X 2133
    2x Crucial M4 128GB R0
    WD 1TB Black
    May 2009
    Wish I'd seen that sooner...
    Any blocks to recommend that we know fit? I feel like a list would be beneficial...
    CT
    I am Xtreme
    Jun 2007
    Quote Originally Posted by paul_ View Post
    True, but this problem will still need to be addressed by the block makers because I doubt EVGA is gonna change the design back just for a handful of nuts that LC their cards.
    Circles SucQ!
    May 2009
    Quote Originally Posted by Waterlogged View Post
    Right. From what I've read, it's all about cutting costs and ease of manufacturing for them. It's a lot easier to buy/make a lot of one type of PCB than two. Eventually I'm sure all 285 manufacturers will follow suit, if they haven't already.
    Apr 2005
    USA
    I already commented on this in the other thread, but purchasing a -128X part number does not guarantee you will receive an older revision pcb:
    http://www.evga.com/forums/tm.asp?m=100651290
    ASUS P6X58D Premium BIOS 0703
    Core i7 920 D0 3849A916 cooled by TRUE120 push/pull
    21x200 4.2GHz 1.272v 1.2625 QPI
    Corsair Dominator 1600C7 6GB @ 6-7-6-18-60 1T 1.50v
    MSI Radeon HD 5970 950/1150 1.225v Cat 10.3
    Intel 160GB G2 / WD 640GB Black
    Silverstone DA1000 Modular PSU
    Lian-Li PC-A70B w/ Scythe S-FlexF Fans
    Pioneer DVR 2910 DVD-RW
    HP LP2465 24" S-PVA LCD
    Windows 7 Ultimate 64
