Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Thread: *** Corsair DOMINATOR 2000C7GT .:. DDR3-2533 CL7 3ch 6GB .:. Details inside & more***
    Xtreme X.I.P.
    Dec 2003
    Cool *** Corsair DOMINATOR 2000C7GT .:. DDR3-2533 CL7 3ch 6GB .:. Details inside & more***
    Greetings!
    After introducing you guys to our new Corsair Dominator 2000C7GT last December, and then bringing entire line of Dominator GT DDR3 memory in February, Corsair Lab finally had some time to try to really push some boundaries, where no other RAM has gone before
    Today I'd like to show you the results I'm really proud of - Corsair Dominator 2000GT, unmatched, shattering DDR3-2500 CL7 barrier in triple-channel configuration!!!
    Corsair Dominator GT, TR3X6G2000C7GTF
    eVGA X58 SLI Classified
    Intel Core i7 975, 3.33GHz, D0 stepping
    Corsair P256 SSD
    Corsair HX1000
    Please note that in those experiments I will be exceeding 1.65V VDIMM voltage level. Be aware that hardware may be damaged or it's life dramatically shortened should you try anything similar you see me do here at home Results seen here are not common, and obviously cannot be approached let alone matched by any other RAM, but Corsair Dominator GT
    Let's begin the screenshot galore!
    MAX CPU-Z validation .:. DDR3-2533 CL7 triple-channel, 3x2GB
    MAX CPU-Z validation | Desktop .:. DDR3-2533 CL7 triple-channel, 3x2GB
    HyperPi 32M | SMT On .:. DDR3-2333 7-8-7-20
    HyperPi 32M | SMT Off .:. DDR3-2333 7-8-7-20
    Memtest 2.11 | Quick test .:. DDR3-2333 7-8-7-20
    I need to admit that 8 x HPi32M at this DDR3 frequency is a royal PITA!!! It's was very close few times, but I could comfortably achieve QUAD HPi32M instead...
    Quad HyperPi 32M | SMT On .:. DDR3-2333 7-8-7-20
    Quad HyperPi 32M | SMT Off .:. DDR3-2333 7-8-7-20
    HyperPi 32M | SMT On .:. DDR3-2376 7-8-7-20
    Everest Ultimate + WinRAR | SMT On .:. DDR3-2376 7-8-7-20
    HyperPi 32M | SMT Off .:. DDR3-2376 7-8-7-20
    Xtreme X.I.P.
    Dec 2003
    Got enough of CL7 craziness ?
    How about some CL6 action then, for dessert? Breathtaking, isn't it?
    MAX CPU-Z validation .:. DDR3-2305 CL6 triple-channel, 3x2GB
    MAX CPU-Z validation | Desktop .:. DDR3-2305 CL6 triple-channel, 3x2GB
    HyperPi 32M | SMT On .:. DDR3-2133 6-7-6-18
    HyperPi 32M | SMT On .:. DDR3-2250 6-7-6-18
    Everest Ultimate + WinRAR | SMT On.:. DDR3-2250 6-7-6-18
    Let me know what you think - give a shout to Corsair Dominator GT
    Apr 2006
    Italy
    impressive ram
    Can you post any bios setting?
    Dec 2007
    Dallas, Tx
    I love those sticks. I've been trying to push the limit of the regular Dominators without going over 1.65v. Been doing ok.
    BTW, what dimm voltage did you use to achieve 2533 mhz?
    Current Rig: Broke i7
    Lian Li 1200 -- Foxconn Bloodrage -- Intel i7 920 @ 3.2Ghz -- Corsair Dominator GT 6GB @ 1925Mhz -- 9800GX2 -- Corsair HX1000 PSU -- Patriot Inferno 100GB SSD -- EK350 block Swiftech 220 S-Flex's all around
    Mar 2008
    Was any kind of cooling used for the RAM(other than the fans that come with it of course)
    i7 Rigs
    Mobo:EVGA Classified/Foxconn BR
    CPU:W3540/i7 920(D0)
    RAM: Dominator GT 2000 cl7/Patriot DDR3-2000 cl8
    GPU:Sapphire 4870x2/XFX 4890/ GTX 260 tri-sli
    Lappy:
    Late 2008 "Unibody" MBP 2.4 GHZ(with OCZ Vertex 250GB)
    Xtreme Legend
    Mar 2005
    Australia
    crazy CL6
    Team.AU
    Got tube?
    GIGABYTE Australia
    Mar 2008
    Quote Originally Posted by dinos22 View Post
    crazy CL6
    Well, if anything shows how important the IMC is for memory/uncore clocking. I think it's almost impossible to hit even 2K CL6 with a 920 D0 or even with my W3540. I will have to find out myself this weekend when I put my W3540 on the classifed with the 2k CL7 doms.
    EDIT: These results just shows how good the 975 is gonna be and pair it with a higher binned elpidas like the 2K dom GTs and sky is your limit, when you go sub-zero cooling.
    i7 Rigs
    Lappy:
    Mar 2008
    川崎市
    I don't care how much cherry picked the ram and the cpu are, that is just extreme
    Corsair
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by tekjunkie View Post
    i'm sure that a good memory controller has to do a lot with it as well
    i wouldnt say that 920 wont be able to do this though
    if you got a CL7 kit gathering dust send it here i'll show ya
    Team.AU
    Got tube?
    GIGABYTE Australia
    Apr 2006
    Barack Hussein Obama-Biden's Nation
    Quote Originally Posted by naokaji View Post
    Corsair
    "Extremely" cherry-picked, so I'm not that impressed for that sake..
    What are the odds of cherry-picking such hardware? 10%? 1%?
    --two awesome rigs, wildly customized with
    5.1 Sony speakers, Stereo 3D, UV Tourmaline Confexia, Flame Bl00dr4g3 Fatal1ty
    --SONY GDM-FW900 24" widescreen CRT, overclocked to:
    2560x1600 resolution at 68Hz!(from 2304x1440@80Hz)
    Updated List of Video Card GPU Voodoopower Ratings!!!!!
    Aug 2007
    Greece
    Corsair
    I'm actually with you on that one, that was just breathtaking, seriously ...
    Michal great work man, these rams are plain sick !
    I've seen 12GB of the 2000 CL8 ones hitting 1000MHz 7-8-7-20 (not fully stable) with a regular 965, no golden cpu or sth I've seen 6GB of the previous ones hitting 1080MHz+ CL7 fairly easy. Both CL7 and CL8 kits of Dominator GTs are excellent products It's just that ... well, 2000 CL7 are better
    Nov 2008
    Russia
    I think voltages are crazy on this....
    CPU: i7 930 3002A648 (Venomous X+Ultra Kaze 2000rpm)
    MB: Asus P6X58D Premium Bios 1501
    Video: Saphire HD 5970
    Memory: Corsair Dominator TR3X6G1600C8D @ 1600MHz
    X-Fi Extreme Gamer Fatality Pro
    HDD: Vertex 2 100GB+WD Caviar Black 1Tb
    Case: TT Kandalf LCS Silver
    Power: CM Real Power Pro 1000W
    Display: Samsung 275T
    Input: Logitech G25/G15/G500/Z-2300
    Oct 2008
    Land of Intel CPU's
    this must be gold coated cherries~
    cudos on the great job....
    i would call it an engineering marvel
    Memory Addict
    Aug 2002
    Brisbane, Australia
    bloody awesome indeed!
    and the question everyone would want to know, the voltages used i.e. cpu vtt and vdimm ioh/ich etc
    ODOC
    Aug 2006
    Copenhagen - Denmark
    crazy man , thats absolute astonishing , someone played with tec module huh ?
    keep pushing it
    Xtreme Cruncher
    Jul 2007
    @ the computer
    yup, already saw some of the benchmarks because some of these results were posted in the news section as WR ddr3.
    i'm assuming that these are only cherry picked from the top of the top? not even half the retail kits can get near this, or is it a new GT model/binning?
    [SIGPIC][/SIGPIC]
    Mar 2005
    Corsair will never accept the warranty on this with the voltage those chips were suffering, benchus you are in trouble
    I bet we are talking 2.0v+ here, and they probably needed to peel of the sticks from the motherboard at the end of this session.
    Amazing SSSSSSSCP (right dinos ?) sticks you managed to assemble there
    PC: Intel Core i7 920 D0 | Kingston Hyperx T1 6GB 2000Mhz 8-8-8 RAM | Foxconn Bloodrage GTI | Sapphire 4870X2 | Perc 5/i - WD 640AAKSx4 RAID0 | Asus 2014L1T | Dell 2407WFP | Lian Li G70 Silver Watercooled
    WaterCooling: Q² Project by The-Fox
    CPU Loop: Swiftech Apogee GTZ | Feser X-Changer 480 | Swiftech MCP655 Vario w/ DetroitAC top | EK Multioption RES 250 Rev.2 | Tygon R3603 1/2" | YL D12SL@1350RPM x4
    GPU Loop: EK-FC4870 X2 Nickel | Swiftech MCR320 | Swiftech MCP655 Vario w/DetroitAC top | EK Multioption RES 150 Rev.2 | Tygon R3603 1/2" | YL D12SL@1350RPM x3
  18. #18
    Sep 2008
    Croatia
    this is f u cking crazy
    great job by the way
  19. #19
    Apr 2008
    DDR3-2250 6-7-6-18
  20. #20
    Aug 2006
    adelaide.sa.au
    Wink
    wonder what batch number was on the cpu
    |W3570|ClassifiedE760|12gbGT2000c7|2x[XFXgtx295]|X-fiForte|2xF120raid0|2x300gbVraptor|HX1000|LianPC-71|Dell3007wfp-HC|
    SuperPi is like caviar. It's an acquired taste.
  21. #21
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by eva2000 View Post
    wild guess here
    1.7vtt
    2.0vdimm
    Team.AU
    Got tube?
    GIGABYTE Australia
  22. #22
    Oct 2006
    L2
    impressive frequency...amazing..
    impressive memory controller and memory...
  23. #23
    xtreme energy
    Oct 2004
    Europe, Latvia
    It does indeed, new 975 with the best mem controllers
  24. #24
    May 2005
    Italy
    Oh.....very impressive...but...it would be beautiful to see a settimg bios
    Thx
  25. #25
    Dec 2006
    Can I ask you for such a cherry-picked kit on your online store?
