Hey
I bought a Lian Li V2110B last fall in my hunt for silence and lost of harddrivespace. I build a HTPC server this spring and therefore I moved all my harddrives except for my systemdrive.
The Lian Li V2110 is not a highflow case it has very bad flow with default settings, so I considered sellling it, but the resellprice is very far from the new price. So I decided to mod my current case instead of selling it and buying a highflow case.
And because I wont be using the harddrive area, I will this summer install watercooling with either a quad or triple rad in the bottem compartment.
But for now I just wanted to add exstra aircooling.
This is my first experience with a Dremel!
I am very satisfied with my result, but I dont understand why I had drill the fan holes in the fan grill abit bigger before it was possible to screw the screws through, but other than that it went pretty well. I would like to color the antivibration rubber bands I have put on the fans (The white stuff you can see) but I am not sure the paint would stick to the rubber
And this should add a lot of airflow in the case.
