Been playing with DFI's latest 4/28 pre-public beta bios and it seems to have improved memory clocking stability for Elpida IC modules as well as improved my max H20 cooled bclk validation from 233 on 3/28 pre-public beta bios to 235bclk on 4/28 bios. 4/28 is pre-public beta so flash at your own risk from here.
4/28 bios seems to be more tolerant of very tight subtimings .. so close to sub 9min 32M pi at <3900Mhz!
sub 4000Mhz 32M
Max BCLK
Super Pi 1M to 32M
System:
- i7 920 3836A756
- EK Supreme LT 1366 / FESER 480 / MCP655
- DFI UT X58-T3EH8 04/28 beta
- 512MB Inno3D 8800GT OC Edition
- 6GB Corsair Dominator GT DDR3-2000Mhz 7-8-7-20
- 750GB Samsung SATAII
- Silverstone OP1200 PSU
- Dual boot - WinXP Pro SP3 / Vista Ultimate 64Bit SP2
Bios settings used.
Code:
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Channel Interleave Setting: AUTO
Rank Interleave Setting: AUTO
Memory LowGap: 1792M
DRAM Command Rate: AUTO
CAS Latency Time (tCL): 6
RAS# to CAS# Delay (tRCD): 7
RAS# Precharge (tRP): 6
Precharge Delay (tRAS): 20
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): 31
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): 31
Ch1 Round trip latency: AUTO (-15 to +16)
Ch2 Round trip latency: AUTO (-15 to +16)
Ch3 Round trip latency: AUTO (-15 to +16)
tREFI: AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: 1.4500v
CPU VID Special Add Limit: Disabled
CPU VID Special Add: 103.30%
Vcore Droop Control: Disabled
DRAM Bus Voltage: 1.71v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: 0.0875v
CPU VTT Voltage: 1.53v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.29v
IOH Analog Voltage: 1.20v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 22x
2 core Max Turbo Ratio: 21x
3 core Max Turbo Ratio: 21x
4 core Max Turbo Ratio: 21x
CPU Non-Turbo Clock Ratio: 19x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO
CPU Base Clock (BCLK): 230 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 110 Mhz
DRAM Frequency: 8xx Memory multipliers
UnCore Frequency: 16x Uncore multipliers
CPU Spread Spectrum: Disabled
