Looking nice, but I have a question :
I bought the PC-A70B and the matching T03B top panel (for tripple fan/rad combo).
I received my tripple Feser last week and I noticed that it won't fit the top.
By this I mean that the fan spacing isn't correct.
The T03B has 12mm fan spacing, while the feser rad has 15mm, which means only the middle fan will fit the top.
I noticed that you have the same rad I have, the case looks more or less smilar to mine (dimensions should be the same), but the Feser rad seems to fit without any problems.
Can you do me a favor and measure the distance between the mounting screws for the fans (measuring from the inner edge of each hole, if you know what I mean), this on both the top panel and the Feser rad.
My drawing skills are ribbish, but this should give you an idea of what I mean (2 white lines between the bottom fan holes).
