Results 1 to 3 of 3
Thread: Cooler Master N520 review
Threaded View
    Apr 2008
    France
    http://www.guru3d.com/article/cooler...r-n520-review/
    yeah, the mounting is a bit sick:
    To install the cooler, you will need to remove the mainboard 100% from your system. The Hyper N520 has the mounting screws faced down and the heatsink has to be tightened down from the backside of the motherboard with nuts. Having a third hand would be a requirement.
    So you put the cooler upside down, then position the motherboard over the 4 screws and washers, and then at the backside you secure them screws with four washers and nuts. For LGA 775 processor you can use a back plate here, but using that I felt we'd have even less clearance in-between the motherboard tray and motherboard.
    We'd very much like to to see Cooler Master move away from this mounting system, there are so much more better solutions out there.
    [SIGPIC][/SIGPIC]
