Results 1 to 4 of 4
Thread: Athlon X2 7750 BE Unlocked to Quad-Core
    Aug 2007
    Romania
    Quote Originally Posted by techPowerUp;
    Earlier this year, a Korean source had pointed out an easy method to enable a fourth core on the Phenom II X3. This was made possible by the way AMD has been designing its triple-core and dual-core processors based on the K10 "Stars" architecture: by disabling one or two cores on the quad-core die. "Sloppy" BIOS coding lead to the Phenom II X3 anomaly. It looks like a somewhat similar mod enables not one, but two cores on the sub-$100 Athlon X2 7750 Black Edition. A Korean technology website GiggleHD.com has reported a successful unlock of two cores.
    The method is similar to that of the Phenom II X3 unlock: using flaws in BIOS code to enable cores, by enabling the "Advanced Clock Calibration" feature in the BIOS setup. The OS, Windows XP SP3, was able to see the processor as a "AMD Phenom(tm) FX-7750", while CPU-Z reads the name string correctly and lists the core count as 4. We are trying to gather more information about this, especially about the name string, and will keep you updated. Details on the rest of the system (the motherboard) is not provided, though you can conclude it is based on an AMD chipset with SB750 southbridge, since that's the only qualified platform with ACC support.
    source
    [SIGPIC][/SIGPIC]
    Xtreme Mentor
    Feb 2007
    Oxford, England
    "Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
    //James
    Aug 2007
    Romania
    i did a search before for keywords "7750 quad" and that thread didn't came up
    feel free to delete this thread
    thanx
    [SIGPIC][/SIGPIC]
    Dec 2008
    powerful cheap htpc solution
    /win
