Results 1 to 20 of 20
Thread: The Boston Cosmos
    Sep 2006
    North East UK
    The Boston Cosmos
    To be fair this isn’t a full blown mod due to unforeseen time restraints as from what I can gather it will be going straight out onto a road show as soon as its complete so I best get my skates on to get it complete in time to make its debut though I have been advised a more full blown mod could be in the pipeline.
    Its sponsored by Boston who are primarily a UK server based company, guilty of producing this water-cooled blade which caught my eye at CeBIT 08, hence the monster hardware supplied to deck this one out….so lets take a closer look at what we got to work with.
    System Spec:
    Coolermaster Cosmos S
    Supermicro X8DAI Motherboard
    2x Intel EXXXX CPU’s
    Coolermaster Real Power M1000 Modular
    6x Hynix 2GB 2Rx8 PC3 – ECC / Reg RAM
    Unknown GFX Cards but possibly nVidia 2xx series, ideally Sli
    Unknown Hardrives
    My brief - to keep things looking as simple and clean as possible so the hardware can easily be recognised and maintained while watercooling CPU’s and GFX cards to keep things cool and quiet so dual loop is a must.
    Watercooling Spec:
    HWLabs 360 X-Flow Radiator
    HWLabs GTX 240 Radiator
    2x EK Supreme LT 1366 CPU Blocks
    2x XSPC Dual Bay-Res / Pump Combo
    Feser Coolant
    ˝” Tygon over ˝” Barbs
    Even though I would have preferred more time to give the Cosmos the full treatment and give it a unique look, I still like the challenge of working with an extended ATX server board and routing hose as simple as possible.
    So lets get this Cosmos S ready to accept both radiators, which unfortunately is basically all the modding the case will be getting but first some obligatory hardware shots….
    Mar 2008
    Lithuania
    Really nice ! Keep going..
    Intel E8400 @ 4GHz Q748A263 PD: 02/25/08.
    Asus Maximus Formula rev. 1.3G. Bios 1004.
    1GBx2 Corsair Dominator DDR1066 + AirFlow.
    Asus 8800GT TOP.
    Zalman CNPS9700 Led.
    Cooler Master CM690.
    15 229 3DMARK06
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    Very interested to see how you'll set everything up in the Cosmos S. Don't ya just hate it when these companies keep sponsoring you and you've got to just build one kick a$$ rig after another
    Engineering The Xtreme
    Feb 2007
    MA, USA
    Quote Originally Posted by shazza View Post
    it must really get annoying after the first $25k worth of free parts....
    Jan 2007
    romania
    hi
    very nice case and mobo,mobo is very good for server,if you want to make a server or workstation,its more eficient.how many radiators wants to put in this case?
    rampage 2 extreme asus
    i920 D0@4.2ghz apogee gtz easy lapped
    zotac gtx 480 on mcw60r
    3x 2048 kingston hyperx t1 2000mhz@1,65v
    samsung 223b sata
    2x wd 1tb 64mb cache sata2
    x-fi fatality champion platinum
    cm silent m pro 850w
    cosmos s cooler master
    dell 2209wa s-ips
    z5500 digital coaxial
    g9x,g15 v2
    Sep 2006
    North East UK
    Cheers for the comments.......
    Just thought i do a bit of test fitting to see what these EK LT blocks look like and maybe get the crunching tonight and its a good job i did because i came across a problem straight off the bat.
    The Board comes with fitted metal back plates which are already threaded but unfortunately threaded with some obscure thread so the standard EK mounting won't fit and as back plated are stuck on with some ridiculously sticky stuff, replacing them isn't going to happen.
    Anyway after looking around i found some threaded brass rod which is a perfect fit so i'm going to have to cut to length and make me some mounting hardware.
    You just can't plan for things like this but what can you do.
    Apr 2008
    I really wanna see what you'll do with this one. BTW how come you haven't posted any worklogs of any CM stacker 830 yet?
    Anw Subbed
    [SIGPIC][/SIGPIC]
    "I fear naught, I hope naught. I am Free"
    Nikos Kazantzakis
    Quote Originally Posted by stangracin2 View Post
    parents only blame stuff on video games because they don't know how to play them
    Banned
    Mar 2007
    In the land of Red....
    Damn I want that board.....
    Sep 2006
    North East UK
    Quote Originally Posted by Baleful View Post
    LOL, i would if i could you know that Bale
    Was doing a bit of research on these CPU's and came across this review which shows even the X5570 literally spanks everything including i7 965 and my Skully QX9775's so looking forward to kicking this one into life
    Intel Xeon X5570 and E5520 Gainestown Processors
    Xtreme Cruncher
    Dec 2008
    Los Angeles/Hong Kong
    The CPUs look like jewelry boxes to be
    Team XS: xs4s.org
    Jun 2007
    sweat;
    wooh i'm seeing another crazy build
    Mar 2008
    looking awesome as always
    [Project] - Black & Green
    The mother of all builds!:p(maybe)
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Quote Originally Posted by coolmiester View Post
    Agreed, I ran into the same issue. I have the SM X8DA3, same as yours only has an added SAS controller.
    The solution is an easy one.
    I got the right screws from Petra's, same thread as the TRUE heatsink screws.
    Best of Luck!
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    (o.O)
    Jun 2008
    Ohio
    that's some absurrrrrrrrrd hardware right there! $3500 for just the mobo & cpus!!
    Intel Core 2 Quad Q9450 Yorkfield @ 3.2GHz | Asus P5Q Deluxe mobo | 2x OCZ Reaper HPC 4GB (2 x 2GB) DDR2 1066 (PC2 8500) | Sapphire 4870x2 | Western Digital VelociRaptor 300GB 10k RPM | Intel 120GB SSD | Western Digital Caviar SE16 640GB 7200 RPM | Hitachi 2TB 7200 RPM | PCP&C 750W Power Supply |Cooler Master HAF932 | Windows 7 64-bit | Dell ULTRASHARP 2408WFP 24-inch Widescreen Flat Panel Monitor
    Join Us in the XS World Community Grid Forum & Help Fight Cancer and Other Diseases
    Jan 2007
    romania
    hi
    its not absurd,if you have money,buy everything..
    cheers coolmiester
    samsung 223b sata
    dell 2209wa s-ips
    g9x,g15 v2
    Banned
    Jun 2006
    in a Red Rage D....
    correction on that... if you have nice big named sponsors, you're good to go...
    CM i see nice build in the making, even though not the full works, but still good...
    Jan 2007
    romania
    hi
    i know that,coolmiester have good sponsor,but not just for fun,coolmiester its a a master of the modding in coolermaster cases
    samsung 223b sata
    dell 2209wa s-ips
    g9x,g15 v2
  18. #18
    Jul 2007
    looking foward to this. any up dates so far?
    My Loop: mcr320/d5 vario/d tek fuzion/3x ultra kaze 2000's
    Case: Modified RocketFish
    Rig: AMD 720BE X3 Biostar TA790GX A3+ Super Talent 2x2GB WD 320AAKS His HD3870x2 Ultra X3 600W
  19. #19
    May 2008
    Perhaps putting nice Thermalright Memory Heatsinks on is an option, they do look :drool:worthy!
  20. #20
    Jun 2008
    Somewhere in EU
    upgrades?
    Corsair Obsidian 650D - EVGA P67 FTW - Samsung F3 1Tb - 8Gb A-Data cheapest crap DDR3 - Intel Core i5 2500K w/ Corsair H50 - EVGA GTX 295 co-op - Corsair AX650
