Praetor
» Intel i7 2600K 3103B306 » Asus Maximus IV Extreme-Z » Asus GTX 470's TRi-SLI » Corsair Dominator GT CMT4GX3M2A2000C8 » Corsair Force F180 SSD » Corsair AX1200 PSU » Corsair 800D
» Cooling : Swiftec Apogee XT » Swiftec MCP350-DDC1 w/XSPC Dual DDC Bay Reservoir » Swiftech MCR320-QP w/Scythe SlipStreams 110CFM
The Yamato
» Intel i7 920 3849B028 or i7 980X » Asus Rampage III Extreme Black Edition » Asus HD6970's QuadFireX or Asus GTX 570's 4way SLI » 6GB Corsair Dominator GT TR3X6G1866C7GTF » Corsair Force F180 SSD » Corsair AX1200 PSU » Microcool Banchetto 101
» Cooling : Dragon F1 Extreme Edition(LN2) » Custom SS by RunMc »
Nice! Ill be getting this case for my next build.
Is that swiftech kit?
I've bought the same case two weeks ago now I need to build a system.
Nice pics.
Refits
Praetor
The Yamato
Wow, great work. Do you have a shot of the front? I'm curious to see how that optical drive works in with the case.
| Cooler Master 690 II Advanced | Corsair 620HX | Core i5-2500K @ 5.0GHz | Gigabyte Z68XP-UD4 | 2x4096MB G.Skill Sniper DDR3-2133 @ 2134MHz 10-11-10-30 @ 1.55V | 160GB Intel X-25 G2 | 2x 2TB Samsung EcoGreen F4 in RAID 1 | Gigabyte HD 7970 @ 1340MHz/1775MHz | Dell 30" 3007WFP-HC | H2O - XSPC RayStorm and Swiftech MCW82 on an MCP350 + XSPC Acrylic Top, XSPC RX240 and Swiftech MCR220 radiators.
Praetor
The Yamato
who knew antec could make a tiny case that is better suited for watercooling than their full tower sized cases![]()
White tubing is realy nice! I'm thinking about using it in my case too.
Looks kinda cute how all the cool hardware fits in such a small case![]()
Wow that looks great Nemesis, just such overall excellence. It seems like the case was made for builds using i7 micro-ATX boards.
Nemesis, do you think u could mount another 220 rad up top if u only ran one set of fans on each rads? im sure i could get 2 pumps just wondering about the rad space on top.
I love seeing this smaller builds. Im sick of these massive MM builds (even though a lot of them are incredible!)
I guess I just prefer a clean, simple, and compact build over a massive, bulky, and "lightshow" build lol.
Anyways, nice work.
Looks very clean Nemesis![]()
Gamingrig:
Antec P180 Mini :|: Corsair HX620 :|: Asus Rampage II Gene :|: Intel Core i7-920 :|: Club3D HD4870x2
CPU & GPU watercooled
Back-up:
Antec P182 :|: OCZ GameXStream 600watt :|: Asus P5K-e :|: Intel C2D-E6700 :|: XFX 8800GTX
Desktop:
CoolerMaster Centurion 5 :|: Enermax Infinity 720 :|: MSI P43 Neo :|: Intel C2D-E8400 :|: Asus HD3650 TOP
Praetor
The Yamato
very nice. Why did you sacrifice 2 fans when you rebuilt it with the GTZ and MCP355? Are temps better vs the apogee + pump combo drive.
i7 920 | Asus Rampage II gene | 6GB ocz Blade | 4870x2
bump?
Yes another rad will easily fit up top but only one 120mm would truly be pulling air from outside.
Now I'm using an Apogee GT with i7 mount, MCP350, and same reservoir. The temps are about the same +/- 3'c using two less fans. Have the fans in the front of the rad pushing air really creates alot of noise so I removed them. Noise to temp ratio decision.
Praetor
The Yamato
beautiful.
this was when i was still rolling the ol' P5E-VM HDMI - i'll be moving the RIIG in here shortly, then i'll post more.
http://i28.photobucket.com/albums/c2...362/rig3-2.jpg
PC-A04 | Z68MA-ED55 | 2500k | 2200+ XPG | 7970 | 180g 520 | 2x1t Black | X3 1000w
hey The Nemesis, where are you hiding your Hard drive? seeing as how you took out the drive cages? was it easy to fit the 2x120 in there?
Project: HeadShot
Intel i7 3770k | Corsair H100
EVGA GTX-590 Classified | XSPC GTX 590 Waterblock
Gigabyte G1.Sniper 2 MotherBoard | Swiftech MCR-320 Res/Rad/Pump
16GB Corsair Vengeance Low Profile Ram
Crucial M4 128GB / Intel X25-M 160GB / WD 1TB Black
Corsair AX850W PSU
27" Apple Cinema Display (2560x1440)
Corsair 600t White
You best be Crunching and Folding/GPUgrid'ing!
This new look was very nice!
SORRY FOR MY BAD ENGLISH!
I used a 3.5 to 5.25 hard drive adaptor and placed it on bottom under cd-rom. Yes it was easy to fit the 2 X 120 radiator, this one is taller due to built in reservoir but a Thermochill PA120.2 fits too. I'm gonna change it again to the MCR220-QP & MCRes-Micro. I have two HD4850's in there now so it will fit.
Thank You
I post a pic up of how it looks now and again after yet another refit![]()
Praetor
The Yamato
with a mcr 220, can you put the top 5.25" back in? i was interested in getting this case, and possibly water cooling it like how you have, but i have 1 hard drive, 1 cd/dvd read/write, 1 blu-ray, and a 5.25" fan controller... so you can see that i would be running out of room... would you be able to fit that top one back in with an mcr 220? whats the clearange from the psu plate to the bottom of the 5.25" cage?
thanks!
Project: HeadShot
Corsair AX850W PSU
Corsair 600t White
Hey Nemesis I really like how your Antec Mini p180 turned out. Wondering if one can add a triple radiator to the top area, I understand I would have to cut it and add a rad grill. Maybe a XSPC 240 rad standing up right like yours along with a XSPX 360 rad for the top section? Would it fit? Also are those regular 120x25mm fans or 38mm you have on yours?
CPU: Intel Core i7-4770K 4.8GHz
MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31 1T
GPU: 2 x eVGA GTX 780 SC
SOUND KRK Rokit 5 Limited Edition White Studio Monitors
SSD: 4 x Samsung 128GB Pro's Raid 0
PSU: SeaSonic Platinum 1000W
COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm 6 x Swiftech Helix 140mm Fans
CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
MONITOR: ASUS VG278HE Black 27" 149Hz
O.S: Windows 7 Pro x64
