Results 1 to 25 of 134
Thread: Foxconn BloodRage Shared BIOS Settings
Threaded View
    Apr 2004
    Greets folks here's your place for bios settings using BloodRage pls share your bios setting using this format this will be helpfull for all of us thx for taking time to share
    CPU & Batch (XXX)
    RAM Model (XXX)
    Bios Ver: Quantum BIOS (XXX)
    CPU Features
    PPM :
    EIST :
    CxE :
    Execute Disable Bit :
    Virtualization :
    Hyper Threading :
    Active Processor Cores :
    Memory Settings
    Memory Controller Settings
    IMC Configuration :
    Channel Congifuration :
    Channel Interleaving :
    Rank Interleaving :
    Memory Timings
    Extreme Memory Profile XMP :
    Memory Profile Select :
    DRAM Timing Control :
    tCL (CAS Latency) :
    tRCG (RAS to CAS Delay) :
    tRP (RAS Precharge) :
    tRAS (Precharge Delay) :
    CR (Command Rate) :
    tRFC (Refresh Cycle Time) :
    tWR (Write Recovery Time) :
    tWTR (Write to Read Delay) :
    tRRD (RAS to RAS Delay) :
    tRTP (Read to Precharge) :
    All Voltage Settings
    CPU Voltages
    CPU Core Voltage :
    CPU Target Core Voltage :
    CPU Vdroop Compensation :
    CPU VTT (UnCore) Voltage :
    1.8 PPL Voltage Setting :
    CPU Clock Amplitude Ctrl :
    Memory Voltages
    DRAM Voltage :
    DIMM1 Vref CA (Addresses) :
    DIMM1 Vref DQ (Data) :
    DIMM2 Vref CA (Addresses) :
    DIMM2 Vref DQ (Data) :
    DIMM3 Vref CA (Addresses) :
    DIMM3 Vref DQ (Data) :
    Chipset Voltages
    X58 IOH Core Voltage :
    X58 IOH VCCA 1.1V :
    X58 IOH VCCA 1.5V :
    ICH10 SB Voltage :
    OC Gear : Skipping this part
    CPU Turbo :
    System Turbo :
    Clock Speed Control Center
    CPU Bclock (FSB) :
    QPI Link Fast Mode :
    QPI Multiplier :
    QPI Target Speed :
    CPU Core Multiplier :
    CPU Core Target Speed :
    CPU Uncore Multiplier :
    CPU Uncore Target Speed :
    Memory Bus Multiplier :
    Memory Bus Target Speed :
    CPU Clock Skew :
    IOH Clock Skew :
