Results 1 to 13 of 13
Thread: Cosmos S Closed loop worklog
Threaded View
    May 2005
    Sugar Land, TX
    Pictures coming this weekend Never could find an XSPC RX360 in stock so went with swiftech. For the volts I use this setup is still overkill i7 4Ghz takes 1.2-1.225v. Most likely 24/7 will be 4.2Ghz 1.3 - 1.35v.
    Parts Log Water
    - EK Supreme LT using hold down plate from Coolermaster V8
    - x2 EK High Flow G1/4 to 1/2
    - Swiftech MCR320-Res
    - x2 Swiftech Hgh Flow 1/4 BSPP to 1/2in. ID (res)
    - Swiftech MCP655-B 12v DC
    - Durelene PVC tubing 1/2in. ID x 3/4in. OD (same company as Tygon)
    - Breeze Miniature Hose Clamp 7/16 in. to 25/32
    - Petra'sTech PT_Nuke
    - Ozarka Distilled water
    Main System Parts
    - Intel i7 920
    - Asus p6t deluxe
    - EVGA GTX 295
    - OCZ 6GB DDR3 1333 7-7-7-20
    Work Done so far
    - Pulled out everything from the case
    - Installed mounting for waterblock
    - Put motherboard back in place
    - Installed Radiator, CPU block and pump
    - Setup tubing and pulled back out
    - Installed hose clamps
    - Put back in to test if the tubing needed adjustment
    - Pulled back out
    Bathroom leak testing
    - Add water using Res port
    - Close off res port
    - Turn on pump using 18.5v laptop AC adapter
    - Open res port
    - top off fluid levels / close res port
    - Shake radiator a bit
    - Left water pumping for 10 hours
    - Check fluid levels - good no top off needed
    - Left water pumping 2 more hours / check for leaks
    - No leaks. Sealed up Waterblock and Radiator barbs with marine goop
    - Pump running another 18 hours until 3pm when I have time to install about 3pm today
    3 levels of water proofing on the barbs (I'm paranoid)
    - Plumbers tape on threads
    - hose clamps (I always had the best luck with the metal type)
    - marine goop (except for pump which has larger barbs than tubing)
    Installation notes for this afternoon.
    - DVD and rheostat moved down 1 slot to give room for radiator
    - HDD Drive cage moved up two slots to give room for pump
    - Pump will lay in the bottom. 1/4" Neopreme on the bottom + 1/4" on the sides to keep the pump from moving. I have tons of neopreme from last time when I did chilled liquid. Makes it easier to pull everything out to change the water.
    - Radiator elevated slightly near the fillport for air collection.
    - 3 or 6 fans on the radiator pulling cold air from the top
    - 120mm fan on the bottom pushing out
    - 120mm fan on drive cage pushing out
    - 120mm fan back behind CPU pushing out
    - 200mm side fan pulling cold air in
