My 120GB Vertex arrives today and I will be installing Vista X64 or Windows 7 X64 on it. Ive seen so many differing recommendations on whether or not to do a disk alignment with Vista or W7. Whats the final word here on XS?
7820X | Asrock X299 Taichi XE | Gigabyte 1080 Ti Xtreme | 32GB Memoriez | Corsair HXi1000 | 500GB 960 Evo
TheRookie and Tony from OCZ have a very good explanation here: http://www.ocztechnologyforum.com/fo...ad.php?t=48309
That should answer ALL your questions regarding the subject.
I completely disagree with you. Alignment is important (vs misaligned) and the results will likely not show in a synthetic benchmark but will show in real world performance.
http://download.microsoft.com/downlo...T558_WH08.pptx
Have a read at what Microsoft say.
alignment and properly formatting on the command line are vary important, but more important is making windows not cashe anything to the ssd
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
I aligned using diskpart from the Windows 7 CD and aligned to 64. So far its pretty impressive.
There was a single statement about performance of aligned vs unaligned. Not a whole lot of evidence to go with it, or even an explanation of what that statement means exactly. What kind of performance is he talking about? Where'd he get the 50% from? Howcome non-JMicron ssd don't seem to need to be aligned for max performance? Have any X25 owners experienced an increase in performance with alignment?"Misaligned partition can degrade device’s performance down to 50% caused by read-modify-write"
I think there needs to be some more in depth research into this with more sources than just a single slideshow from Microsoft.
I think Intel SSDs have built in knowledge of NTFS and ext2/3 to figure whether they are aligned or not and act accordingly.
It's also possible that Intel uses a very large base block, i.e. not 512 bytes but.. say 20KB. With larger sizes, the misalignment is less noticable.
Speaking of which, it seems Windows Server 2003 aligns to 64 sectors...
I asked the same question in a thread a week or two ago and everyone was saying that vista automatically aligns correctly if you install the os straight to the ssd. Dont know if that is actually true though.
??? vista & W7 both align a correct interger that being said thier is room for improvement .. slight as it may be .
xp on the other hand doesnt ... might try xp sp1 disk only it might ? it also lets you use more ram iirc(sp1 only) than xp sp2 or 3
[SIGPIC][/SIGPIC]
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
wasnt takling about speed , was talking about alignment lol
[SIGPIC][/SIGPIC]
FOXCONN MARS
Quattro 1000W
*REAL TEMP*
The 50% is worst case only and not very likely to happen.
Basically there's 4KB size areas on the SSD. If you're writing 4KB blocks to the SSD then it's best to line them up. The drive cannot do anything less than 4KB so for a 4KB operation that's not aligned it has to do two block operations, rather than one. Where it's a big file it still needs to do one extra operation, but since it's doing 10,000 already it makes almost no difference. That's where the 50% comes from.
Sure it's a bit theoretical, but I see no reason why it's not correct.
The reason it's so important on JMicron controllers is that they stutter if they can't cope with the workload they're asked to do, aligning the partition will reduce the workload for small files. All other SSDs should benefit from it.
So would I notice a big increase in performance if I change my x25-m alignment to 64kb instead of 32kb?
Not unless it's nearly 32 rather than actually 32.
is 64 the ideal alignment for Vista/Win7?
Kinda funny though, I installed windows7 beta 7000 on my ocz solid series 30gb, and formated the drive in the win7 installer. It is unaligned now, using 63kb size. Not a big problem to reformat but still I think it's strange![]()
In addition,
Diskpart rounds up and uses 'kb'.
Diskpar uses 'sectors' instead of 'kb' and is exacted. (conversion: 64 sectors = 32kb)
MainPC():
Q6600 + 8GB RAM + 160GB SSD + 1.5TB HDD + Visiontek HD4850 + Gigabyte P965-DS3 rev3.3
HTPC():
E4200 + 4GB RAM + 160GB SSD + Samsung F1 2x1TB RAID-0 + Asus EAH 3450 + Asus P5E-VM HDMI + KWorld ATSC-110 HDTV
Laptop():
CR-48
what about using Acronis to make a mirror copy of my drive now and putting it on a new SSD? would this screw things up or can i align it still? or should hook it up as an external and check firmware and align before making mirror copy.
got the Kingston SSDNow V Series SNV425-S2/64GB
http://www.newegg.com/Product/Produc...82E16820139132
FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
Asus Crosshair Formula 5 Am3+ bios v1703
G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
MSI 7950 TwinFrozr *1100/1500* Cat.14.9
OCZ ZX 850w psu
Lian-Li Lancool K62
Samsung 830 128g
2 x 1TB Samsung SpinpointF3, 2T Samsung
Win7 Home 64bit
My Rig
